Cypress CY8CKIT-042-BLE PSoC4 蓝牙开发板 原装现货
1063|5
 楼主| szjlj168 发表于 2016-3-30 11:14 | 显示全部楼层 |阅读模式
Bluetooth Low Energy Made Easy:
The BLE Pioneer Kit supports system-level designs using PSoC Creator which includes numerous example projects to enable Bluetooth Low Energy mixed signal embedded designs.
The Bluetooth Low Energy v4.1 specification has been abstracted into the new BLE Component in PSoC Creator, allowing for easy drag-and-drop designs.
The kit has been designed to allow for maximum design flexibility enabling Arduino™ shields hardware compatibility and easy to use, FCC-certified PSoC 4 BLE and PRoC BLE Modules.
Low System Cost:
The BLE Pioneer Kit provides users easy access to the new PSoC 4 BLE and PRoC BLE devices, while maintaining the familiar CY8CKIT-042 PSoC 4 Pioneer Kitdesign footprint.
The kit includes a CY5670 - CySmart USB Dongle (BLE Dongle) that pairs with the CySmart master emulation tool, converting your Windows® PC into a powerful Bluetooth LE debug environment.
The kit has been designed to allow for easy development at a low cost. The kit design and layout allows for customers to easily develop embedded solutions that require both mixed-signal capabilities and a Bluetooth LE radio.
Lowest System Power:
The BLE Pioneer Kit has been designed to allow customers to develop low power designs.
The kit provides both power measurement jumpers and a coin cell holder and battery for low power evaluation.
The kit allows the user to evaluate lower power modes in a wide operating voltage range of 1.7 - 5.5 V.
Kit Contents:
BLE Pioneer Baseboard preloaded with CY8CKIT-142 PSoC 4 BLE module
CY5671 PRoC BLE Module
Quick start guide
USB Standard A to Mini-B cable
Four jumper wires (4 inch) and two proximity sensor wires (5 inch)
Coin cell (3V CR2032)
 楼主| szjlj168 发表于 2016-3-30 11:15 | 显示全部楼层
zhiyy 发表于 2016-3-30 11:51 | 显示全部楼层
多少钱,怎么购买
dianz 发表于 2016-3-30 12:36 | 显示全部楼层
这个是不是那个研讨会送的那个
 楼主| szjlj168 发表于 2016-3-31 09:44 | 显示全部楼层
多少钱,怎么购买
加我QQ:547838378,有现货
这个是不是那个研讨会送的那个
啥研讨会?
