| 我刚学avr汇编,写了一个用一位数码管循环显示0-9的小程序,但仿真没达到预期效果,不知道是怎么回事,请各位指教!!! ;一位数码管循环显示数字0-9程序
 .include"m16def.inc"
 .def Time =r20
 .def count=r17     ;中断次数计数器
 .org $0000
 rjmp main
 .org $010
 rjmp time1_ovf
 tab:.db 0x3f,0x06,0x5B,0x4F,0x66,0x6D,0x7D,0x07,0x7F,0x6F ;0-9数字段码表,共阴极
 main:
 ldi r16,0xff
 out ddrd,r16
 ldi r16,0x00
 out tccr1a,r16
 ldi r16,0x1E
 out tcnt1l,r16 ;计数器1赋初值
 ldi r16,0xfb
 out tcnt1h,r16
 ldi r16,$04
 out timsk,r16 ;开定时器1溢出中断
 ldi r16,0x01   ;1分频
 out tccr1b,r16
 ;clr count
 ;clr time
 sei         ;开全局中断
 Display:
 ldi zh,high(tab*2)
 ldi zl,low(tab*2)
 add zl,Time     ;取数字段码
 lpm
 out portd,r0     ;段码从PD口输出
 rjmp Display     ;循环显示
 time1_ovf:
 ldi r16,0x1E
 out tcnt1l,r16
 ldi r16,0xfb
 out tcnt1h,r16
 inc count       ;中断100次,中断时间为10ms
 cpi count,100   ;100x10=1S
 brlo M         ;小于100则退出,继续等待中断
 clr count       ;达到100次则清零中断计数器
 inc Time
 cpi Time,9     ;小于9则退出
 brlo M
 clr Time       ;计数大于9则清零
 M:   reti
