销售!品牌 IC、接插件、连接器端子、继电器、二三极管
2493|0
 楼主| taiyandianzi 发表于 2009-12-29 10:37 | 显示全部楼层 |阅读模式
北京太延电子科技有限公司
我们提供种类齐全的电子器件:包括集成电路,连接器,继电器,电线电缆,开关,控制器,电源,冷却器件,测试设备,分立元件,音频,视频,通讯等产品,应用范围涉及民用、工业和军事领域。
地  址:北京市海淀区中关村西区善缘街1号立方庭大厦2-723室
联系人:魏芳
电  话:010-62416823
传  真:010-62416199-8008
E-Mail:ic@tai-yan.com
网  址:http://www.tai-yan.com/
Q Q :1003276497
部分产品:
型号          封装 年份 数量   E-Mail
PMB6256V1.1 INFINEON 2034464   info@cachips.com ??? 1-514-721-0891 Cachips
IRF7233TR IR 00+ 1603472   info@cachips.com ??? 1-514-721-0891 Cachips
ATMEGA166-4CGX ATMEL 06+ 1019960   info@cachips.com ??? 1-514-721-0891 Cachips
ISL6225CA INTERSIL03+ 936629   info@cachips.com ??? 1-514-721-0891 Cachips
M166Q039-4CGX ATMEL  650099   info@cachips.com ??? 1-514-721-0891 Cachips
AT45DB081A-CC ATMEL  545737   info@cachips.com ??? 1-514-721-0891 Cachips
AND642S10CTR ANADIGIC00+ 489818   info@cachips.com ??? 1-514-721-0891 Cachips
AS2916   ASTEC 01+ 456610   info@cachips.com ??? 1-514-721-0891 Cachips
U2786B-MFSG3 ATMEL 00+ 332080   info@cachips.com ??? 1-514-721-0891 Cachips
ISL6556BCB      INTERSIL03+ 319711   info@cachips.com ??? 1-514-721-0891 Cachips
LA5311M-TE-R SANYO 01+ 319034   info@cachips.com ??? 1-514-721-0891 Cachips
BSP752T INFINEON  317255   info@cachips.com ??? 1-514-721-0891 Cachips
SW-335 MACOM  302430   info@cachips.com ??? 1-514-721-0891 Cachips
SI9420DY-T1 SILCONIX 00+ 302430   info@cachips.com ??? 1-514-721-0891 Cachips
TPS76318DBVR TI 00+ 295314   info@cachips.com ??? 1-514-721-0891 Cachips
SI6969DQ-T1 SILCONIX 01+ 288198   info@cachips.com ??? 1-514-721-0891 Cachips
L4931CD25-TR ST  281675   info@cachips.com ??? 1-514-721-0891 Cachips
PMB5699V11 INFINEON  268510   info@cachips.com ??? 1-514-721-0891 Cachips
AT45BCM021D-SU ATMEL  267106   info@cachips.com ??? 1-514-721-0891 Cachips
AT49F001T-12PC ATMEL 98+ 257817   info@cachips.com ??? 1-514-721-0891 Cachips
4L-SPI F2 INFINEON  255996   info@cachips.com ??? 1-514-721-0891 Cachips
A2C22207 INFINEON  255996   info@cachips.com ??? 1-514-721-0891 Cachips
BSP772T INFINEON  255535   info@cachips.com ??? 1-514-721-0891 Cachips
7C193   252938   info@cachips.com ??? 1-514-721-0891 Cachips
16221256 PHILIPS  246925   info@cachips.com ??? 1-514-721-0891 Cachips
AN3117S-CE1 PANASONIC  246688   info@cachips.com ??? 1-514-721-0891 Cachips
TLE6250G INFINEON  240520   info@cachips.com ??? 1-514-721-0891 Cachips
EAR34-10 FUJI  237200   info@cachips.com ??? 1-514-721-0891 Cachips
JAN2N3725 NS  237200   info@cachips.com ??? 1-514-721-0891 Cachips
TDA8432/N5 PHILIPS 95+ 236500   info@cachips.com ??? 1-514-721-0891 Cachips
MC145406D PHILIPS 03+ 234828   info@cachips.com ??? 1-514-721-0891 Cachips
A2C20219 INFINEON  231270   info@cachips.com ??? 1-514-721-0891 Cachips
ATIC17D1 INFINEON  231270   info@cachips.com ??? 1-514-721-0891 Cachips
UAB-M3057-HTV3.3 INFINEON  229491   info@cachips.com ??? 1-514-721-0891 Cachips
HCPL-0631#500 AGILENT 00+ 229206   info@cachips.com ??? 1-514-721-0891 Cachips
BTS740S2 INFINEON  229064   info@cachips.com ??? 1-514-721-0891 Cachips
SI4505DY-T1 VISHAY 04+ 225280   info@cachips.com ??? 1-514-721-0891 Cachips
TUA6034TA1 INFINEON  224533   info@cachips.com ??? 1-514-721-0891 Cachips
PMB6259V1.1 INFINEON  224154   info@cachips.com ??? 1-514-721-0891 Cachips
PMB6610V2.1 INFINEON  224154   info@cachips.com ??? 1-514-721-0891 Cachips
CA3140MZ  07+ 222375   info@cachips.com ??? 1-514-721-0891 Cachips
TLE4278G INFINEON  213088   info@cachips.com ??? 1-514-721-0891 Cachips
TUA6020A2 INFINEON  209922   info@cachips.com ??? 1-514-721-0891 Cachips
NJM2169M JRC 00+ 207550   info@cachips.com ??? 1-514-721-0891 Cachips
LT1363CS8#TR LINEAR TECHNOLOGY 99+ 207550   info@cachips.com ??? 1-514-721-0891 Cachips
TS922IDT$KDK ST 01+ 204726   info@cachips.com ??? 1-514-721-0891 Cachips
MXTI12BE TI  201620   info@cachips.com ??? 1-514-721-0891 Cachips
MXT112BE TI  201620   info@cachips.com ??? 1-514-721-0891 Cachips
PMB7850EV3.1HM42 INFINEON  197706   info@cachips.com ??? 1-514-721-0891 Cachips
MC100ELT24DR2 ON 00+ 195097   info@cachips.com ??? 1-514-721-0891 Cachips
PMB2306TV2.2 SIEMENS  186735   info@cachips.com ??? 1-514-721-0891 Cachips
TLE6262G INFINEON  185559   info@cachips.com ??? 1-514-721-0891 Cachips
ISL6522CB INTERSIL 03+ 185418   info@cachips.com ??? 1-514-721-0891 Cachips
OEC12C885 ODIN 96+ 184753   info@cachips.com ??? 1-514-721-0891 Cachips
HFA3783IN INTERSIL  180212   info@cachips.com ??? 1-514-721-0891 Cachips
TLE4269GM INFINEON  178542   info@cachips.com ??? 1-514-721-0891 Cachips
BR1225/BE ROV 04+ 177900   info@cachips.com ??? 1-514-721-0891 Cachips
UPB562AC NEC 03+ 176654   info@cachips.com ??? 1-514-721-0891 Cachips
BTS840S2 INFINEON  176061   info@cachips.com ??? 1-514-721-0891 Cachips
2301AF-R13 M/A-COMINC 99+ 171970   info@cachips.com ??? 1-514-721-0891 Cachips
TLE4269G INFINEON  171377   info@cachips.com ??? 1-514-721-0891 Cachips
74LVCH16245AEV PHILIPS 04+ 166040   info@cachips.com ??? 1-514-721-0891 Cachips
U7004B-MFSG3 ATMEL 01+ 166028   info@cachips.com ??? 1-514-721-0891 Cachips
TFDU4100-TR3 VISHAY 00+ 161201   info@cachips.com ??? 1-514-721-0891 Cachips
GLT725608-15J3 G-LINK 00+ 157477   info@cachips.com ??? 1-514-721-0891 Cachips
LA8677 SANYO  155959   info@cachips.com ??? 1-514-721-0891 Cachips
AT45DB161-CC ATMEL  155887   info@cachips.com ??? 1-514-721-0891 Cachips
PT8A978BP PTC 02+ 154412   info@cachips.com ??? 1-514-721-0891 Cachips
