[STM32F1] STM32F103和CC1101通信
2176|9
 楼主| zhangjy 发表于 2016-6-25 17:32 | 显示全部楼层 |阅读模式
STM32连接CC1101模块连接的时候,程序一直死在
    // Wait for GDO0 to be set -> sync transmitted
    while (!GD0_BIT);
    // Wait for GDO0 to be cleared -> end of packet
    while (GD0_BIT);
;我想请教一下,CS, SI, SO, SCLK, GD0, GD2,这几个引脚是不是都要加上拉电阻??
mmuuss586 发表于 2016-6-25 20:12 | 显示全部楼层
不用加,使用STM32内部上拉即可;
 楼主| zhangjy 发表于 2016-6-26 08:48 | 显示全部楼层
有谁帮我看看源代码有没有问题?
 楼主| zhangjy 发表于 2016-6-26 08:50 | 显示全部楼层
* 文件名  :rf1100se.c
* 描述    :
* 实验平台 :
* 硬件连接:
* 库版本  :
#include "stm32f10x.h"
#include "stm32f10x_it.h"
#include "stm32f10x_rcc.h"
#include "misc.h"
#define  INT8U    unsigned char
#define  INT16U   unsigned int
#define  uclong   unsigned long
//==================================主出从入====================================
#define  MOSI_0     GPIO_ResetBits(GPIOB, GPIO_Pin_3)
#define  MOSI_1     GPIO_SetBits(GPIOB, GPIO_Pin_3)
//===================================SPI时钟端口================================
#define  SCK_0      GPIO_ResetBits(GPIOA, GPIO_Pin_11)
#define  SCK_1      GPIO_SetBits(GPIOA, GPIO_Pin_11)
//==================================SPI使能端口=================================
#define  CSN_0      GPIO_ResetBits(GPIOA, GPIO_Pin_12)
#define  CSN_1      GPIO_SetBits(GPIOA, GPIO_Pin_12)
#define  MOSO_BIT   GPIO_ReadInputDataBit(GPIOB,GPIO_Pin_15)
#define  GD0_BIT   GPIO_ReadInputDataBit(GPIOB,GPIO_Pin_14)
#define  WRITE_BURST         0x40        //连续写入
#define  READ_SINGLE         0x80        //读
#define  READ_BURST          0xC0        //连续读
#define  BYTES_IN_RXFIFO     0x7F          //接收缓冲区的有效字节数
#define  CRC_OK              0x80         //CRC校验通过位标志
// CC1100-CC1101  所有相关寄存器映射
#define CCxxx0_IOCFG2       0x00        // GDO2 output pin configuration
#define CCxxx0_IOCFG1       0x01        // GDO1 output pin configuration
#define CCxxx0_IOCFG0       0x02        // GDO0 output pin configuration
#define CCxxx0_FIFOTHR      0x03        // RX FIFO and TX FIFO thresholds
#define CCxxx0_SYNC1        0x04        // Sync word, high INT8U
#define CCxxx0_SYNC0        0x05        // Sync word, low INT8U
#define CCxxx0_PKTLEN       0x06        // Packet length
#define CCxxx0_PKTCTRL1     0x07        // Packet automation control
#define CCxxx0_PKTCTRL0     0x08        // Packet automation control
#define CCxxx0_ADDR         0x09        // Device address
#define CCxxx0_CHANNR       0x0A        // Channel number
#define CCxxx0_FSCTRL1      0x0B        // Frequency synthesizer control
#define CCxxx0_FSCTRL0      0x0C        // Frequency synthesizer control
#define CCxxx0_FREQ2        0x0D        // Frequency control word, high INT8U
#define CCxxx0_FREQ1        0x0E        // Frequency control word, middle INT8U
#define CCxxx0_FREQ0        0x0F        // Frequency control word, low INT8U
#define CCxxx0_MDMCFG4      0x10        // Modem configuration
#define CCxxx0_MDMCFG3      0x11        // Modem configuration
#define CCxxx0_MDMCFG2      0x12        // Modem configuration
#define CCxxx0_MDMCFG1      0x13        // Modem configuration
#define CCxxx0_MDMCFG0      0x14        // Modem configuration
#define CCxxx0_DEVIATN      0x15        // Modem deviation setting
#define CCxxx0_MCSM2        0x16        // Main Radio Control State Machine configuration
#define CCxxx0_MCSM1        0x17        // Main Radio Control State Machine configuration
#define CCxxx0_MCSM0        0x18        // Main Radio Control State Machine configuration
#define CCxxx0_FOCCFG       0x19        // Frequency Offset Compensation configuration
#define CCxxx0_BSCFG        0x1A        // Bit Synchronization configuration
#define CCxxx0_AGCCTRL2     0x1B        // AGC control
#define CCxxx0_AGCCTRL1     0x1C        // AGC control
#define CCxxx0_AGCCTRL0     0x1D        // AGC control
#define CCxxx0_WOREVT1      0x1E        // High INT8U Event 0 timeout
#define CCxxx0_WOREVT0      0x1F        // Low INT8U Event 0 timeout
#define CCxxx0_WORCTRL      0x20        // Wake On Radio control
#define CCxxx0_FREND1       0x21        // Front end RX configuration
#define CCxxx0_FREND0       0x22        // Front end TX configuration
#define CCxxx0_FSCAL3       0x23        // Frequency synthesizer calibration
#define CCxxx0_FSCAL2       0x24        // Frequency synthesizer calibration
#define CCxxx0_FSCAL1       0x25        // Frequency synthesizer calibration
#define CCxxx0_FSCAL0       0x26        // Frequency synthesizer calibration
#define CCxxx0_RCCTRL1      0x27        // RC oscillator configuration
#define CCxxx0_RCCTRL0      0x28        // RC oscillator configuration
#define CCxxx0_FSTEST       0x29        // Frequency synthesizer calibration control
#define CCxxx0_PTEST        0x2A        // Production test
#define CCxxx0_AGCTEST      0x2B        // AGC test
#define CCxxx0_TEST2        0x2C        // Various test settings
#define CCxxx0_TEST1        0x2D        // Various test settings
#define CCxxx0_TEST0        0x2E        // Various test settings
// Strobe commands
#define CCxxx0_SRES         0x30        // Reset chip.
#define CCxxx0_SFSTXON      0x31        // Enable and calibrate frequency synthesizer (if MCSM0.FS_AUTOCAL=1).
                                        // If in RX/TX: Go to a wait state where only the synthesizer is
                                        // running (for quick RX / TX turnaround).
#define CCxxx0_SXOFF        0x32        // Turn off crystal oscillator.
#define CCxxx0_SCAL         0x33        // Calibrate frequency synthesizer and turn it off
                                        // (enables quick start).
#define CCxxx0_SRX          0x34        // Enable RX. Perform calibration first if coming from IDLE and
                                        // MCSM0.FS_AUTOCAL=1.
#define CCxxx0_STX          0x35        // In IDLE state: Enable TX. Perform calibration first if
                                        // MCSM0.FS_AUTOCAL=1. If in RX state and CCA is enabled:
                                        // Only go to TX if channel is clear.
#define CCxxx0_SIDLE        0x36        // Exit RX / TX, turn off frequency synthesizer and exit
                                        // Wake-On-Radio mode if applicable.
#define CCxxx0_SAFC         0x37        // Perform AFC adjustment of the frequency synthesizer
#define CCxxx0_SWOR         0x38        // Start automatic RX polling sequence (Wake-on-Radio)
#define CCxxx0_SPWD         0x39        // Enter power down mode when CSn goes high.
#define CCxxx0_SFRX         0x3A        // Flush the RX FIFO buffer.
#define CCxxx0_SFTX         0x3B        // Flush the TX FIFO buffer.
#define CCxxx0_SWORRST      0x3C        // Reset real time clock.
#define CCxxx0_SNOP         0x3D        // No operation. May be used to pad strobe commands to two
                                        // INT8Us for simpler software.
#define CCxxx0_PARTNUM      0x30
#define CCxxx0_VERSION      0x31
#define CCxxx0_FREQEST      0x32
#define CCxxx0_LQI          0x33
#define CCxxx0_RSSI         0x34
#define CCxxx0_MARCSTATE    0x35
#define CCxxx0_WORTIME1     0x36
#define CCxxx0_WORTIME0     0x37
#define CCxxx0_PKTSTATUS    0x38
#define CCxxx0_VCO_VC_DAC   0x39
#define CCxxx0_TXBYTES      0x3A
#define CCxxx0_RXBYTES      0x3B
#define CCxxx0_PATABLE      0x3E
#define CCxxx0_TXFIFO       0x3F
#define CCxxx0_RXFIFO       0x3F
//*****更多功率参数设置可详细参考DATACC1100英文文档中第48-49页的参数表**********
//INT8U PaTabel[8] = {0x04 ,0x04 ,0x04 ,0x04 ,0x04 ,0x04 ,0x04 ,0x04};  //-30dBm   功率最小
INT8U PaTabel[8] = {0x60 ,0x60 ,0x60 ,0x60 ,0x60 ,0x60 ,0x60 ,0x60};  //0dBm
//INT8U PaTabel[8] = {0xC0 ,0xC0 ,0xC0 ,0xC0 ,0xC0 ,0xC0 ,0xC0 ,0xC0};   //10dBm     功率最大
//=======================定义RF1100-1101寄存器结构体数组 =================================
typedef struct S_RF_SETTINGS
    INT8U FSCTRL2;
    INT8U FSCTRL1;   // Frequency synthesizer control.
    INT8U FSCTRL0;   // Frequency synthesizer control.
    INT8U FREQ2;     // Frequency control word, high INT8U.
    INT8U FREQ1;     // Frequency control word, middle INT8U.
    INT8U FREQ0;     // Frequency control word, low INT8U.
    INT8U MDMCFG4;   // Modem configuration.
    INT8U MDMCFG3;   // Modem configuration.
    INT8U MDMCFG2;   // Modem configuration.
    INT8U MDMCFG1;   // Modem configuration.
    INT8U MDMCFG0;   // Modem configuration.
    INT8U CHANNR;    // Channel number.
    INT8U DEVIATN;   // Modem deviation setting (when FSK modulation is enabled).
    INT8U FREND1;    // Front end RX configuration.
    INT8U FREND0;    // Front end RX configuration.
    INT8U MCSM0;     // Main Radio Control State Machine configuration.
    INT8U FOCCFG;    // Frequency Offset Compensation Configuration.
    INT8U BSCFG;     // Bit synchronization Configuration.
    INT8U AGCCTRL2;  // AGC control.
    INT8U AGCCTRL1;  // AGC control.
    INT8U AGCCTRL0;  // AGC control.
    INT8U FSCAL3;    // Frequency synthesizer calibration.
    INT8U FSCAL2;    // Frequency synthesizer calibration.
    INT8U FSCAL1;    // Frequency synthesizer calibration.
    INT8U FSCAL0;    // Frequency synthesizer calibration.
    INT8U FSTEST;    // Frequency synthesizer calibration control
    INT8U TEST2;     // Various test settings.
    INT8U TEST1;     // Various test settings.
    INT8U TEST0;     // Various test settings.
    INT8U IOCFG2;    // GDO2 output pin configuration
    INT8U IOCFG0;    // GDO0 output pin configuration
    INT8U PKTCTRL1;  // Packet automation control.
    INT8U PKTCTRL0;  // Packet automation control.
    INT8U ADDR;      // Device address.
    INT8U PKTLEN;    // Packet length.
} RF_SETTINGS;
//==========================CC1100-1101寄存器配置===============================
const RF_SETTINGS rfSettings =
    0x00,
    0x08,   // FSCTRL1   Frequency synthesizer control.
    0x00,   // FSCTRL0   Frequency synthesizer control.
    0x10,   // FREQ2     Frequency control word, high byte.
    0xA7,   // FREQ1     Frequency control word, middle byte.
    0x62,   // FREQ0     Frequency control word, low byte.
    0x5B,   // MDMCFG4   Modem configuration.
    0xF8,   // MDMCFG3   Modem configuration.
    0x03,   // MDMCFG2   Modem configuration.
    0x22,   // MDMCFG1   Modem configuration.
    0xF8,   // MDMCFG0   Modem configuration.
    0x00,   // CHANNR    Channel number.
    0x47,   // DEVIATN   Modem deviation setting (when FSK modulation is enabled).
    0xB6,   // FREND1    Front end RX configuration.
    0x10,   // FREND0    Front end RX configuration.
    0x18,   // MCSM0     Main Radio Control State Machine configuration.
    0x1D,   // FOCCFG    Frequency Offset Compensation Configuration.
    0x1C,   // BSCFG     Bit synchronization Configuration.
    0xC7,   // AGCCTRL2  AGC control.
    0x00,   // AGCCTRL1  AGC control.
    0xB2,   // AGCCTRL0  AGC control.
    0xEA,   // FSCAL3    Frequency synthesizer calibration.
    0x2A,   // FSCAL2    Frequency synthesizer calibration.
    0x00,   // FSCAL1    Frequency synthesizer calibration.
    0x11,   // FSCAL0    Frequency synthesizer calibration.
    0x59,   // FSTEST    Frequency synthesizer calibration.
    0x81,   // TEST2     Various test settings.
    0x35,   // TEST1     Various test settings.
    0x09,   // TEST0     Various test settings.
    0x0B,   // IOCFG2    GDO2 output pin configuration.   0x0B
    0x06,   // IOCFG0D   GDO0 output pin configuration. Refer to SmartRF?Studio User Manual for detailed pseudo register explanation. 0x06
    0x04,   // PKTCTRL1  Packet automation control.
    0x05,   // PKTCTRL0  Packet automation control.
    0x00,   // ADDR      Device address.
    0xff    // PKTLEN    Packet length.最大
void RF1100_IO_set(void)
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA,ENABLE);
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB,ENABLE);
        //SO
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_15;
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU;
        GPIO_Init(GPIOB, &GPIO_InitStructure);
        //GD0
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_14;
        //SI
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_3;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
        //SCLK
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_11;
  GPIO_Init(GPIOA, &GPIO_InitStructure);
        //CS
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_12;
//函数名:delay(unsigned int s)
//输入:时间
//输出:无
//功能描述:普通廷时,内部用
void delay(unsigned int s)
        unsigned int i;
        for(i=0; i<s; i++);
        for(i=0; i<s; i++);
//========================延时约5ms=============================================
void Delay5ms(void)
    INT16U i=40000;
    while (i != 0)
        i--;
void halWait(INT16U timeout)
char i;
    do {
       for(i=0; i<20; i++);
    } while (--timeout);
//函数名:SpisendByte(INT8U dat)
//输入:发送的数据
//输出:无
//功能描述:SPI发送一个字节
INT8U SpiTxRxByte(INT8U dat)
//----------------------以下是模拟SPI时序方式-----------------------------------
        INT8U i,temp;
        temp = 0;
        SCK_0 ;
        for(i=0; i<8; i++)
                if(dat & 0x80)
                   MOSI_1;
                else
                   MOSI_0;
                dat <<= 1;
                SCK_1;
                temp <<= 1;
        if(MOSO_BIT)temp++;  //读取MISO状态
                SCK_0 ;
        return temp;
//函数名:void RESET_CC1100(void)
//输入:无
//输出:无
//功能描述:复位CC1100
        CSN_0 ;
        while(MOSO_BIT); // (P1IN & 0x40);
    SpiTxRxByte(CCxxx0_SRES);                 //写入复位命令
        CSN_1;
//函数名:void POWER_UP_RESET_CC1100(void)
//输入:无
//输出:无
//功能描述:上电复位CC1100
        CSN_1;
        halWait(1);
        CSN_0 ;
        halWait(1);
        CSN_1;
        halWait(41);
        RESET_CC1100();                   //复位CC1100
//函数名:void halSpiWriteReg(INT8U addr, INT8U value)
//输入:地址和配置字
//输出:无
//功能描述:SPI写寄存器
    CSN_0;
    while(MOSO_BIT); // (P1IN& 0x40);
    SpiTxRxByte(addr);                //写地址
    SpiTxRxByte(value);                //写入配置
    CSN_1;
//函数名:void halSpiWriteBurstReg(INT8U addr, INT8U *buffer, INT8U count)
//输入:地址,写入缓冲区,写入个数
//输出:无
//功能描述:SPI连续写配置寄存器
    INT8U i, temp;
    temp = addr | WRITE_BURST;
    CSN_0;
    SpiTxRxByte(temp);
    for (i = 0; i < count; i++)
        SpiTxRxByte(buffer[i]);
    CSN_1;
//函数名:void halSpiStrobe(INT8U strobe)
//输入:命令
//输出:无
//功能描述:SPI写命令
    CSN_0;
    SpiTxRxByte(strobe);                //写入命令
    CSN_1;
//函数名:INT8U halSpiReadReg(INT8U addr)
//输入:地址
//输出:该寄存器的配置字
//功能描述:SPI读寄存器
        INT8U temp, value;
    temp = addr|READ_SINGLE;//读寄存器命令
        CSN_0;
        while(MOSO_BIT); //(P1IN & 0x40);
        SpiTxRxByte(temp);
        value = SpiTxRxByte(0);
        CSN_1;
        return value;
//函数名:void halSpiReadBurstReg(INT8U addr, INT8U *buffer, INT8U count)
//输入:地址,读出数据后暂存的缓冲区,读出配置个数
//输出:无
//功能描述:SPI连续写配置寄存器
    INT8U i,temp;
        temp = addr | READ_BURST;                //写入要读的配置寄存器地址和读命令
    CSN_0;
        SpiTxRxByte(temp);
        buffer[i] = SpiTxRxByte(0);
    CSN_1;
//输入:地址
//输出:该状态寄存器当前值
//功能描述:SPI读状态寄存器
INT8U halSpiReadStatus(INT8U addr)
    INT8U value,temp;
        temp = addr | READ_BURST;                //写入要读的状态寄存器的地址同时写入读命令
    CSN_0;
    SpiTxRxByte(temp);
        CSN_1;
        return value;
 楼主| zhangjy 发表于 2016-6-26 08:58 | 显示全部楼层
//函数名:void halRfWriteRfSettings(RF_SETTINGS *pRfSettings)
//输入:无
//输出:无
//功能描述:配置CC1100的寄存器
void halRfWriteRfSettings(void)
    halSpiWriteReg(CCxxx0_FSCTRL0,  rfSettings.FSCTRL2);//自已加的
    halSpiWriteReg(CCxxx0_FSCTRL1,  rfSettings.FSCTRL1);
    halSpiWriteReg(CCxxx0_FSCTRL0,  rfSettings.FSCTRL0);
    halSpiWriteReg(CCxxx0_FREQ2,    rfSettings.FREQ2);
    halSpiWriteReg(CCxxx0_FREQ1,    rfSettings.FREQ1);
    halSpiWriteReg(CCxxx0_FREQ0,    rfSettings.FREQ0);
    halSpiWriteReg(CCxxx0_MDMCFG4,  rfSettings.MDMCFG4);
    halSpiWriteReg(CCxxx0_MDMCFG3,  rfSettings.MDMCFG3);
    halSpiWriteReg(CCxxx0_MDMCFG2,  rfSettings.MDMCFG2);
    halSpiWriteReg(CCxxx0_MDMCFG1,  rfSettings.MDMCFG1);
    halSpiWriteReg(CCxxx0_MDMCFG0,  rfSettings.MDMCFG0);
    halSpiWriteReg(CCxxx0_CHANNR,   rfSettings.CHANNR);
    halSpiWriteReg(CCxxx0_DEVIATN,  rfSettings.DEVIATN);
    halSpiWriteReg(CCxxx0_FREND1,   rfSettings.FREND1);
    halSpiWriteReg(CCxxx0_FREND0,   rfSettings.FREND0);
    halSpiWriteReg(CCxxx0_MCSM0 ,   rfSettings.MCSM0 );
    halSpiWriteReg(CCxxx0_FOCCFG,   rfSettings.FOCCFG);
    halSpiWriteReg(CCxxx0_BSCFG,    rfSettings.BSCFG);
    halSpiWriteReg(CCxxx0_AGCCTRL2, rfSettings.AGCCTRL2);
    halSpiWriteReg(CCxxx0_AGCCTRL1, rfSettings.AGCCTRL1);
    halSpiWriteReg(CCxxx0_AGCCTRL0, rfSettings.AGCCTRL0);
    halSpiWriteReg(CCxxx0_FSCAL3,   rfSettings.FSCAL3);
    halSpiWriteReg(CCxxx0_FSCAL2,   rfSettings.FSCAL2);
    halSpiWriteReg(CCxxx0_FSCAL1,   rfSettings.FSCAL1);
    halSpiWriteReg(CCxxx0_FSCAL0,   rfSettings.FSCAL0);
    halSpiWriteReg(CCxxx0_FSTEST,   rfSettings.FSTEST);
    halSpiWriteReg(CCxxx0_TEST2,    rfSettings.TEST2);
    halSpiWriteReg(CCxxx0_TEST1,    rfSettings.TEST1);
    halSpiWriteReg(CCxxx0_TEST0,    rfSettings.TEST0);
    halSpiWriteReg(CCxxx0_IOCFG2,   rfSettings.IOCFG2);
    halSpiWriteReg(CCxxx0_IOCFG0,   rfSettings.IOCFG0);
    halSpiWriteReg(CCxxx0_PKTCTRL1, rfSettings.PKTCTRL1);
    halSpiWriteReg(CCxxx0_PKTCTRL0, rfSettings.PKTCTRL0);
    halSpiWriteReg(CCxxx0_ADDR,     rfSettings.ADDR);
    halSpiWriteReg(CCxxx0_PKTLEN,   rfSettings.PKTLEN);
//函数名:void halRfSendPacket(INT8U *txBuffer, INT8U size)
//输入:发送的缓冲区,发送数据个数
//输出:无
//功能描述:CC1100发送一组数据
    halSpiWriteReg(CCxxx0_TXFIFO, size);
    halSpiWriteBurstReg(CCxxx0_TXFIFO, txBuffer, size);        //写入要发送的数据
    halSpiStrobe(CCxxx0_STX);                //进入发送模式发送数据
    while (!GD0_BIT);
    while (GD0_BIT);
        halSpiStrobe(CCxxx0_SFTX);
void setRxMode(void)
    halSpiStrobe(CCxxx0_SRX);                //进入接收状态
INT8U halRfReceivePacket(INT8U *rxBuffer, INT8U *length)
    INT8U status[2];
    INT8U packetLength;
        INT8U i=(*length)*4;  // 具体多少要根据datarate和length来决定
        delay(580);
        //while (P2IN & 0x80)
                delay(100);
                --i;
                if(i<1)
                   return 0;
    if ((halSpiReadStatus(CCxxx0_RXBYTES) & BYTES_IN_RXFIFO)) //如果接的字节数不为0
        packetLength = halSpiReadReg(CCxxx0_RXFIFO);//读出第一个字节,此字节为该帧数据长度
        if (packetLength <= *length)                 //如果所要的有效数据长度小于等于接收到的数据包的长度
            halSpiReadBurstReg(CCxxx0_RXFIFO, rxBuffer, packetLength); //读出所有接收到的数据
            *length = packetLength;                                //把接收数据长度的修改为当前数据的长度
            // Read the 2 appended status bytes (status[0] = RSSI, status[1] = LQI)
            halSpiReadBurstReg(CCxxx0_RXFIFO, status, 2);         //读出CRC校验位
                        halSpiStrobe(CCxxx0_SFRX);                //清洗接收缓冲区
            return (status[1] & CRC_OK);                        //如果校验成功返回接收成功
     else
            return 0;
        else
        return 0;
void RF110SE_Init(void)
        RF1100_IO_set();
        POWER_UP_RESET_CC1100();
        halRfWriteRfSettings();
        halSpiWriteBurstReg(CCxxx0_PATABLE, PaTabel, 8);
        delay(2000);
int main(void)
        unsigned char leng =8;        // 8字节, 如果需要更长的数据包,请正确设置
        unsigned char TxBuf[8];
  SystemInit();        //配置系统时钟为 72M
  RF110SE_Init();
        TxBuf[0] = 0x01; TxBuf[1] = 0x02; TxBuf[2] = 0x03; TxBuf[3] = 0x04;
        TxBuf[4] = 0x05; TxBuf[5] = 0x06; TxBuf[6] = 0x07; TxBuf[3] = 0x08;
        leng = 8;
  while (1)
                        halRfSendPacket(TxBuf,leng);        // Transmit Tx buffer data
                        delay(2000);
 楼主| zhangjy 发表于 2016-6-26 08:59 | 显示全部楼层
我用芯片是STM32F103C8,请各位高手帮我看看
neomissing 发表于 2016-6-26 09:51 | 显示全部楼层
    while (!GD0_BIT);
    while (GD0_BIT);
这两个代码改为延时10ms即可,用上面的代码很容易死机,我的程序就是这样做的
 楼主| zhangjy 发表于 2016-6-26 18:57 | 显示全部楼层
谢谢,我测试一下看看;延时可靠吗?我买了CC1101SE模块的开发板,CPU用MSP430,我看了他们的DEMO程序就是这样用的,我测试了一下,很可靠,不知道为什么到了STM32F103就一直死机了
neomissing 发表于 2016-6-26 19:32 | 显示全部楼层
可靠,我用的是MSP430,产品中一直这样用,那个失败一次就会死机,所以不建议用那种
Varus 发表于 2016-6-26 20:54 | 显示全部楼层
STM32内部有上拉,配置寄存器就行
