[i.MX] 编译LTIB /L2.6.35_1.1.0_130130出现错误
752|1
 楼主| 13831541556 发表于 2016-8-10 17:43 | 显示全部楼层 |阅读模式
vmuser@Linux-host:~/L2.6.35_1.1.0_130130_source/source/ltib$ ./ltib
Don't have HTTP::Request::Common
Don't have LWP::UserAgent
Cannot test proxies, or remote file availability without both
HTTP::Request::Common and LWP::UserAgent
ltib cannot be run because one or more of the host packages needed to run it
are either missing or out of date or not in ltib's standard path.  Please
install/upgrade these packages on your host.  If you have your own utilities
in non-standard paths, please add an entry into the .ltibrc file for example:
%path_std
/usr/local/bin:/usr/bin:/bin:/usr/bin/X11:/usr/X11R6/bin:/my/own/exes
Package                Minimum ver   Installed info
zlib                   0             not installed
Died at ./ltib line 1409.
traceback:
main::host_checks:1409
  main:554
Started: Wed Aug 10 17:42:03 2016
Ended:   Wed Aug 10 17:42:05 2016
Elapsed: 2 seconds
Build Failed
Exiting on error or interrupt
 楼主| 13831541556 发表于 2016-8-10 17:45 | 显示全部楼层
请问如何处理,ZLIB我已经安装上了,安装网上的教程也没改对,还有Don't have HTTP::Request::Common
Don't have LWP::UserAgent是需要安装Http吗?
