[i.MX] [i.MX] i.MX6 Ubuntu12.04上编译LTIB 遇到的问题
992|0
 楼主| onlyfire 发表于 2016-9-7 09:22 | 显示全部楼层 |阅读模式
虚拟机 VituralBox
系统  Ubuntu12.04 32bit
错误提示 :
/usr/local/bin:/usr/bin:/bin:/usr/bin/X11:/usr/X11R6/bin:/my/own/exes
Package                Minimum ver   Installed info
zlib                   0             not installed
Died at ./ltib line 1409.
traceback:
main::host_checks:1409
  main:554
Started: Wed Sep  7 09:11:38 2016
Ended:   Wed Sep  7 09:11:38 2016
Elapsed: 0 seconds
Build Failed
Exiting on error or interrupt
sunny@sunny-VirtualBox:~/work/imx6/ltib/ltib$
这个问题 困扰来好久 ,打开 网上搜到的 解答,这部分和我的里面一样的
zlib         => sub { my @f = (glob('/usr/lib/libz.so*'),
                                   glob('/lib/libz.so*'),
                                   glob('/lib64/libz.so*'),
                                   glob('/usr/lib/i386-linux-gnu/libz.so*'),
                                   glob('/usr/lib32/libz.so*'),
                                   glob('/usr/lib/x86_64-linux-gnu/libz.so*') ); @f > 1 ? 1 : 0 },
    'zlib-devel' => sub { -f '/usr/include/zlib.h' },
后来 打来下patch 后重新编译  又出现下面的错误
Build path taken because: directory build, no prebuilt rpm,
Cowardly refusing to clobber existing directory:
/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-3.0.35-4.1.0
Remove this by hand if you really want to rebuild this package from scratch
Died at ./ltib line 1392.
traceback:
main::build_host_rpms:1392
  main::host_checks:1447
   main:554
Started: Wed Sep  7 09:48:22 2016
Ended:   Wed Sep  7 09:48:22 2016
Elapsed: 0 seconds
These packages failed to build:
elftosb
Build Failed
