SecureCRT窗口里的这些文字信息是什么意思?求大神解惑
2990|1
 楼主| rankey 发表于 2016-9-22 13:53 | 显示全部楼层 |阅读模式
内容1:
|root@sabresd_6dq:/ # [ 1920.472362] binder: release proc 4221, transaction 709936, not freed
[ 1934.120738] binder: 3868: binder_alloc_buf, no vma
[ 1934.126417] binder: 2683:3080 transaction failed 29201, size 232-4
[ 1934.133085] binder: release proc 3344, transaction 710708, not freed
[ 1934.140476] binder: release proc 3344, transaction 710709, not freed
[ 1935.045774] init: untracked pid 3908 exited
内容2:
  [ 2398.853042] binder: release 3159:8579 transaction 553812 out, still active
[ 2402.931744] binder: 3248:3350 transaction failed 29189, size 2444-4
    求助的其他细节内容是这样:CPU:I.MX6DL/SOO 双核1GHz. Memory: 379MB 1222MB 240MB=1841MB total . 设置2个USB 1.0 130万摄像头 和一个mipi总线式摄像头ov5640。
    硬件系统运行在安卓4.3版本。
    在运行公司开发的APP,直播功能时,前10几分钟,3个摄像头的切换正常。 再运行一段时间后,切换摄像头就卡画面,就是直播画面卡在原来的摄像头画面。
    我用cureCRT软件通过串口方式查看,在按切换键后,串口窗口提示切换过去了。另外,退到安卓主页面,点击相机,有时提示“相机无法连接”,有时提示"图库已停止运行"。
   内容1和内容2的这些提示,是串口窗口发出的。本人也看不懂。故来这里请教。
 楼主| rankey 发表于 2016-9-22 13:58 | 显示全部楼层
以下是SecureCRT打印信息:
[   36.882869] request_suspend_state: wakeup (0->0) at 36647489673 (2016-09-21 04:54:27.329148005 UTC)  //唤醒PAD
[   36.915612] imx-ipuv3 imx-ipuv3.0: IPU DMFC DP HIGH RESOLUTION: 1(0,1), 5B(2~5), 5F(6,7)
[   37.005504] cpufreq_interactive_input_connect: connect to cyttsp5_mt
[   37.020036] dhd_set_suspend: Remove extra suspend setting
[   68.023917] 111111111111111
[   68.035781] 2222222222222222
[   68.039190] 3333333333333333
[   68.047639] 4444444444444444
[   68.050715] aaaaaaaaaaaaaaa
[   68.053649] bbbbbbbbbbbbbbb
[   68.058399] cccccccccccccccccc
[   68.061806] zzzzzzzzzzzzzzzzzz
[   68.065506] afdfdfdasfdsaf
[   68.072585] 123455
[   68.076161] yyyyyyyyyyyyyyyyyyyyyy
[   68.079784] vvvvvvvvvvvvvvvvvvvvv , alt->desc.bNumEndpoints = 1             //建立直播,直播画面为USB_左摄像头
[   68.085864] uuuuuuuuuuuuuuuuuuuuu
[   68.091076] ddddddddddddddddddd
[   68.104278] eeeeeeeeeeeeeeeeeee
[   68.108364] iiiiiiiiiiiiiiiiii
[   68.112480] jjjjjjjjjjjjjjjjjjjjjj
[   68.118158] 5555555555555555
[   71.559270] 111111111111111
[   71.581679] zzzzzzzzzzzzzzzzzz
[   71.587212] afdfdfdasfdsaf
[   71.598245] 123455
[   71.598256] yyyyyyyyyyyyyyyyyyyyyy
[   71.598335] vvvvvvvvvvvvvvvvvvvvv , alt->desc.bNumEndpoints = 0
[   71.598342] uuuuuuuuuuuuuuuuuuuuu
[   71.598913] 111111111111111
[   71.598927] zzzzzzzzzzzzzzzzzz
[   71.598933] afdfdfdasfdsaf
[   71.628409] 123455
[   71.628417] yyyyyyyyyyyyyyyyyyyyyy
[   71.628422] vvvvvvvvvvvvvvvvvvvvv , alt->desc.bNumEndpoints = 0
[   71.628426] uuuuuuuuuuuuuuuuuuuuu
[   72.814851] =============================================ov5640_mirror
[   73.627873] =============================================ov5640_mirror        //  切换到主摄像头
130|root@sabresd_6dq:/ # cat /sys/devices/virtual/thermal/thermal_zone0/temp     //14:39  查询CPU温度,返回54℃。
54
54
54
130|root@sabresd_6dq:/ # cat /sys/devices/virtual/thermal/thermal_zone0/temp   //25:20 查询CPU温度,返回54℃,主摄像头画面正常。
54
54
root@sabresd_6dq:/ # [ 1850.447178] binder: release proc 3381, transaction 944904, not freed     //29:45
[ 1850.454370] binder: release proc 3381, transaction 944905, not freed
130|root@sabresd_6dq:/ # cat /sys/devices/virtual/thermal/thermal_zone0/temp        //40:06 查询CPU温度,返回55℃,主摄像头画面正常。
55
55
root@sabresd_6dq:/ # cat /sys/devices/virtual/thermal/thermal_zone0/temp     //01:04:36 查询CPU温度,返回55℃,主摄像头画面正常。
55
130|root@sabresd_6dq:/ # [ 5291.355859] init: untracked pid 3905 exited     //01:10:00  ----01:31:00之间,出现了这个提示。
130|root@sabresd_6dq:/ # cat /sys/devices/virtual/thermal/thermal_zone0/temp  //01:42:03   查询CPU温度,返回55℃。
55
55
        //01:44:08 按一下切换键,直接卡死画面,串口窗口也没反应
