[Kinetis] MCG设置问题
1020|0
 楼主| _nividia 发表于 2016-10-11 08:57 | 显示全部楼层 |阅读模式
TI, pc, IO, ui, ni
目前使用的IC型号是KL26Z256,外部晶振使用的是8M。通过Procssor Expert software软件得到的启动代码如下。
  /*** !!! Here you can place your own code before PE initialization using property "User code before PE initialization" on the build options tab. !!! ***/
  /* Disable the WDOG module */
  /* SIM_COPC: ??=0,??=0,??=0,??=0,??=0,??=0,??=0,??=0,??=0,??=0,??=0,??=0,??=0,??=0,??=0,??=0,??=0,??=0,??=0,??=0,??=0,??=0,??=0,??=0,??=0,??=0,??=0,??=0,COPT=0,COPCLKS=0,COPW=0 */
  SIM->COPC = (uint32_t)((0x00<<2)&0xc);//SIM_COPC_COPT(0x00);
  /* System clock initialization */
  /* SIM_CLKDIV1: OUTDIV1=0,??=0,??=0,??=0,??=0,??=0,??=0,??=0,??=0,??=0,OUTDIV4=3,??=0,??=0,??=0,??=0,??=0,??=0,??=0,??=0,??=0,??=0,??=0,??=0,??=0,??=0,??=0,??=0 */
  SIM->CLKDIV1 = (uint32_t)(((0x00<<28)&0XF0000000)|((0x03<<16)&0x70000));  ///(SIM_CLKDIV1_OUTDIV1(0x00) | SIM_CLKDIV1_OUTDIV4(0x03)); /* Set the system prescalers to safe value */
  /* SIM_SCGC5: PORTA=1 */
  SIM->SCGC5 |= 0x200;//SIM_SCGC5_PORTA_MASK;   /* Enable clock gate for ports to enable pin routing */
  if ((PMC->REGSC & 0x8) != 0x0U) {
    /* PMC_REGSC: ACKISO=1 */
    PMC->REGSC |= 0x8; /* Release IO pads after wakeup from VLLS mode. */
  /* SIM_CLKDIV1: OUTDIV1=4,??=0,??=0,??=0,??=0,??=0,??=0,??=0,??=0,??=0,OUTDIV4=0,??=0,??=0,??=0,??=0,??=0,??=0,??=0,??=0,??=0,??=0,??=0,??=0,??=0,??=0,??=0,??=0 */
  SIM->CLKDIV1 = (uint32_t)(((0x04<<28)&0XF0000000)|((0x00<<16)&0x70000));//(SIM_CLKDIV1_OUTDIV1(0x04) | SIM_CLKDIV1_OUTDIV4(0x00)); /* Update system prescalers */
  /* SIM_SOPT2: PLLFLLSEL=1 */
  SIM->SOPT2 |= 0x10000;//SIM_SOPT2_PLLFLLSEL_MASK; /* Select PLL as a clock source for various peripherals */
  /* SIM_SOPT1: OSC32KSEL=3 */
  SIM->SOPT1 |= (uint32_t)((0x03<<18)&0xc0000);//SIM_SOPT1_OSC32KSEL(0x03); /* LPO 1kHz oscillator drives 32 kHz clock for various peripherals */
  /* SIM_SOPT2: TPMSRC=1 */
  SIM->SOPT2 = (uint32_t)((SIM->SOPT2 & (uint32_t)~(uint32_t)(
               (0x02<<24)&0x3000000//SIM_SOPT2_TPMSRC(0x02)
              )) | (uint32_t)(
               (0x01<<24)&0x3000000//SIM_SOPT2_TPMSRC(0x01)
              ));                      /* Set the TPM clock */
  /* PORTA_PCR18: ISF=0,MUX=0 */
  PORTA->PCR18 &= (uint32_t)~(uint32_t)(0x1000000 | ((0x07<<8)&0x700));
  /* PORTA_PCR19: ISF=0,MUX=0 */
  PORTA->PCR19 &= (uint32_t)~(uint32_t)(0x1000000 | ((0x07<<8)&0x700));
  /* Switch to FBE Mode */
  /* MCG_C2: LOCRE0=0,RANGE0=2,HGO0=0,EREFS0=1,LP=0,IRCS=0 */
  MCG->C2 = (uint8_t)((MCG->C2 & (uint8_t)~(uint8_t)(
            0x80 |
            ((0x01<<4)&0x30)| //MCG_C2_RANGE0(0x01) |
            0x80 |
            0x2 |
            0x1
           )) | (uint8_t)(
            ((0x02<<4)&0x30) |
            0x4
  /* OSC0_CR: ERCLKEN=1,??=0,EREFSTEN=0,??=0,SC2P=0,SC4P=0,SC8P=0,SC16P=0 */
  OSC0->CR = 0x80;
  /* MCG_C1: CLKS=2,FRDIV=3,IREFS=0,IRCLKEN=1,IREFSTEN=0 */
  MCG->C1 = ((uint8_t)((0x02<<6)&0xc0) | (uint8_t)((0x03<<3)&0x38) | 0x2);
  /* MCG_C4: DMX32=0,DRST_DRS=0 */
  MCG->C4 &= (uint8_t)~(uint8_t)((0x80 | ((0x03<<5)&0x60)));
  /* MCG_C5: ??=0,PLLCLKEN0=0,PLLSTEN0=0,PRDIV0=1 */
  MCG->C5 = (0x01<<0)&0x1F;//MCG_C5_PRDIV0(0x01);
  /* MCG_C6: LOLIE0=0,PLLS=0,CME0=0,VDIV0=1 */
  MCG->C6 = (0x01<<0)&0x1F;//MCG_C6_VDIV0(0x01);
  while((MCG->S & 0x10) != 0x00U) { /* Check that the source of the FLL reference clock is the external reference clock. */
  while((MCG->S & 0x0CU) != 0x08U) {    /* Wait until external reference clock is selected as MCG output */
  /* Switch to PBE Mode */
  /* MCG_C6: LOLIE0=0,PLLS=1,CME0=0,VDIV0=1 */
  MCG->C6 = (0x40 | ((0x01<<0)&0x1F));
  while((MCG->S & 0x40) == 0x00U) { /* Wait until locked */
  /* Switch to PEE Mode */
  /* MCG_C1: CLKS=0,FRDIV=3,IREFS=0,IRCLKEN=1,IREFSTEN=0 */
  MCG->C1 = (((0x00<<6)&0xC0)| ((0x03<<3)&0x38) | 0x2);
  while((MCG->S & 0x0CU) != 0x0CU) {    /* Wait until output of the PLL is selected */
jlink调试过程,发现运行到
的时候出现了死等,MCG->S状态寄存器值为零,一直没有返回。我查看数据手册,参数设置的值应该没有问题。出现状态寄存器死等的原因会是什么呢?求解。
