[应用方案] 芯唐的开发板有没有同时带usb和can的
1232|8
 楼主| wang1216 发表于 2017-1-6 11:17 | 显示全部楼层 |阅读模式
如题!!!
yiyigirl2014 发表于 2017-1-6 21:04 | 显示全部楼层
楼主啊,在官方的主页上有个选型看到没?
yiyigirl2014 发表于 2017-1-6 22:04 | 显示全部楼层
帮你用选型工具随便找了个,如下:
The NuMicro® M453 CAN series 32-bit microcontroller (MCU) is embedded with the ARM® Cortex®-M4 core and operating at 2.5V ~ 5.5V and -40℃ ~ 105℃, and provides 22.1184 MHz internal oscillator (1% accuracy at 25℃, 5V) , Data Flash configurable and high immunity (8KV ESD, 4KV EFT) . Package types include LQFP48, LQFP64 and LQFP100.
Target Application:
Industrial Automation, PLCs, Inverters, Home Automation, Portable Data Collector, USB Accessories, Smart Card Reader, Motor Control, etc.
Key Features:
• Core
    - ARM® Cortex®-M4 with DSP and FPU
    - Max frequency of 72 MHz
    - Operating voltage: 2.5V to 5.5V
    - Temperature range: -40℃ ~ 105℃
• Memory
    - 128 KB of Flash Memory
    - 32 KB of SRAM
    - Data Flash configurable
• 12-bit ADC (up to 16 channels)
• 12-bit DAC
• 16-bit PWM (up to 12 channels)
• Timers
    - Four timers
    - RTC (optional)
• Connectivity
    - USB 2.0 OTG (optional)
    - CAN (optional)
    - Up to 5 UARTs
    - Up to three SPIs
    - Up to two I²Cs (up to 1 MHz)
    - Smart card interfaces (optional)
    - Up to two I²S interfaces
• Security
    - CRC engine
• Clock Control
    - 4 to 24 MHz external crystal oscillator
    - 32.768 kHz crystal oscillator
    - 22.1184 MHz internal RC oscillator
    - 10 kHz internal RC oscillator
dongnanxibei 发表于 2017-1-8 17:48 | 显示全部楼层
楼主选到合适的没。这个做什么项目用呢。
落叶行健ywm 发表于 2017-1-10 10:53 | 显示全部楼层
天灵灵地灵灵 发表于 2017-2-8 18:08 | 显示全部楼层
M453就满足你的需求。
