-  * [url=home.php?mod=space&uid=288409]@file[/url]     main.c
-  * [url=home.php?mod=space&uid=895143]@version[/url]  V2.00
-  * $Revision: 2 $
-  * $Date: 14/12/15 4:01p $
-  * @brief
-  *           Change system clock to different PLL frequency and output system clock from CLKO pin..
-  * @note
-  * Copyright (C) 2011 Nuvoton Technology Corp. All rights reserved.
- #include <stdio.h>
- #include "NUC100Series.h"
- #define PLL_CLOCK       50000000
- #define SIGNATURE       0x125ab234
- #define FLAG_ADDR       0x20003FFC
- /* Define functions prototype        */
- int32_t main(void);
- /*  Brown Out Detector IRQ Handler        */
- void BOD_IRQHandler(void)
-     /* Clear BOD Interrupt Flag */
-     SYS_CLEAR_BOD_INT_FLAG();
-     printf("Brown Out is Detected\n");
- /*  Simple calculation test function        */
- #define PI_NUM  256
- int32_t f[PI_NUM + 1];
- uint32_t piTbl[19] =
-     3141,
-     5926,
-     5358,
-     9793,
-     2384,
-     6264,
-     3383,
-     2795,
-     288,
-     4197,
-     1693,
-     9937,
-     5105,
-     8209,
-     7494,
-     4592,
-     3078,
-     1640,
-     6284
- int32_t piResult[19];
- int32_t pi(void)
-     int32_t i, i32Err;
-     int32_t a = 10000, b = 0, c = PI_NUM, d = 0, e = 0, g = 0;
-     for(; b - c;)
-         f[b++] = a / 5;
-     i = 0;
-     for(; d = 0, g = c * 2; c -= 14,/*printf("%.4d\n",e+d/a),*/ piResult[i++] = e + d / a, e = d % a)
-         if(i == 19)
-             break;
-         for(b = c; d += f[b] * a, f[b] = d % --g, d /= g--, --b; d *= b);
-     i32Err = 0;
-     for(i = 0; i < 19; i++)
-         if(piTbl[i] != piResult[i])
-             i32Err = -1;
-     return i32Err;
- void Delay(uint32_t x)
-     int32_t i;
-     for(i = 0; i < x; i++)
-         __NOP();
-         __NOP();
- uint32_t g_au32PllSetting[] =
-     CLK_PLLCON_PLL_SRC_HXT | CLK_PLLCON_NR(3) | CLK_PLLCON_NF(25) | CLK_PLLCON_NO_4,  /* PLL = 25MHz */
-     CLK_PLLCON_PLL_SRC_HXT | CLK_PLLCON_NR(3) | CLK_PLLCON_NF(29) | CLK_PLLCON_NO_4,  /* PLL = 29MHz */
-     CLK_PLLCON_PLL_SRC_HXT | CLK_PLLCON_NR(3) | CLK_PLLCON_NF(33) | CLK_PLLCON_NO_4,  /* PLL = 33MHz */
-     CLK_PLLCON_PLL_SRC_HXT | CLK_PLLCON_NR(3) | CLK_PLLCON_NF(37) | CLK_PLLCON_NO_4,  /* PLL = 37MHz */
-     CLK_PLLCON_PLL_SRC_HXT | CLK_PLLCON_NR(3) | CLK_PLLCON_NF(41) | CLK_PLLCON_NO_4,  /* PLL = 41MHz */
-     CLK_PLLCON_PLL_SRC_HXT | CLK_PLLCON_NR(3) | CLK_PLLCON_NF(45) | CLK_PLLCON_NO_4,  /* PLL = 45MHz */
-     CLK_PLLCON_PLL_SRC_HXT | CLK_PLLCON_NR(3) | CLK_PLLCON_NF(49) | CLK_PLLCON_NO_4   /* PLL = 49MHz */
- void SYS_PLL_Test(void)
-     int32_t  i;
-     /* PLL clock configuration test        */
-     printf("\n-------------------------[ Test PLL ]-----------------------------\n");
-     for(i = 0; i < sizeof(g_au32PllSetting) / sizeof(g_au32PllSetting[0]) ; i++)
-         /* Switch HCLK clock source to HXT and HCLK source divide 1 */
-         CLK_SetHCLK(CLK_CLKSEL0_HCLK_S_HXT, CLK_CLKDIV_HCLK(1));
-         /* Set PLL to power down mode and PLL_STB bit in CLKSTATUS register will be cleared by hardware. */
-         CLK_DisablePLL();
-         /* Set PLL frequency */
-         CLK->PLLCON = g_au32PllSetting[i];
-         /* Waiting for PLL clock ready */
-         CLK_WaitClockReady(CLK_CLKSTATUS_PLL_STB_Msk);
-         /* Switch HCLK clock source to PLL */
-         CLK_SetHCLK(CLK_CLKSEL0_HCLK_S_PLL, CLK_CLKDIV_HCLK(1));
-         printf("  Change system clock to %d Hz ...................... ", SystemCoreClock);
-         /* Output selected clock to CKO, CKO Clock = HCLK / 2^(1 + 1) */
-         CLK_EnableCKO(CLK_CLKSEL2_FRQDIV_S_HCLK, 1, 0);
-         /* The delay loop is used to check if the CPU speed is increasing */
-         Delay(0x400000);
-         if(pi())
-             printf("[FAIL]\n");
-         else
-             printf("[OK]\n");
-         /* Disable CKO clock */
-         CLK_DisableCKO();
- void SYS_Init(void)
-     /* Init System Clock        */
-     /* Enable Internal RC 22.1184MHz clock */
-     CLK_EnableXtalRC(CLK_PWRCON_OSC22M_EN_Msk);
-     /* Waiting for Internal RC clock ready */
-     CLK_WaitClockReady(CLK_CLKSTATUS_OSC22M_STB_Msk);
-     /* Switch HCLK clock source to Internal RC and HCLK source divide 1 */
-     CLK_SetHCLK(CLK_CLKSEL0_HCLK_S_HIRC, CLK_CLKDIV_HCLK(1));
-     /* Enable external XTAL 12MHz clock */
-     CLK_EnableXtalRC(CLK_PWRCON_XTL12M_EN_Msk);
-     /* Waiting for external XTAL clock ready */
-     CLK_WaitClockReady(CLK_CLKSTATUS_XTL12M_STB_Msk);
-     /* Set core clock as PLL_CLOCK from PLL */
-     CLK_SetCoreClock(PLL_CLOCK);
-     /* Enable UART module clock */
-     CLK_EnableModuleClock(UART0_MODULE);
-     /* Select UART module clock source */
-     CLK_SetModuleClock(UART0_MODULE, CLK_CLKSEL1_UART_S_HXT, CLK_CLKDIV_UART(1));
-     /* Init I/O Multi-function        */
-     /* Set GPB multi-function pins for UART0 RXD and TXD, and Clock Output */
-     SYS->GPB_MFP &= ~(SYS_GPB_MFP_PB0_Msk | SYS_GPB_MFP_PB1_Msk | SYS_GPB_MFP_PB12_Msk);
-     SYS->ALT_MFP &= ~SYS_ALT_MFP_PB12_Msk;
-     SYS->GPB_MFP |= (SYS_GPB_MFP_PB0_UART0_RXD | SYS_GPB_MFP_PB1_UART0_TXD | SYS_GPB_MFP_PB12_CLKO);
-     SYS->ALT_MFP |=  SYS_ALT_MFP_PB12_CLKO;
- void UART0_Init()
-     /* Init UART        */
-     /* Reset UART0 peripheral */
-     SYS_ResetModule(UART0_RST);
-     /* Configure UART0 and set UART0 Baudrate */
-     UART_Open(UART0, 115200);
- /* MAIN function        */
-     uint32_t u32data;
-     /* In end of main function, program issued CPU reset and write-protection will be disabled. */
-     if(SYS_IsRegLocked() == 0)
-         SYS_LockReg();
-     /* Unlock protected registers */
-     SYS_UnlockReg();
-     /* Init System, peripheral clock and multi-function I/O */
-     SYS_Init();
-     /* Lock protected registers */
-     SYS_LockReg();
-     /* Init UART0 for printf */
-     UART0_Init();
-     printf("\n\nCPU [url=home.php?mod=space&uid=72445]@[/url] %dHz\n", SystemCoreClock);
-         This sample code will show some function about system manager controller and clock controller:
-         1. Read PDID
-         2. Get and clear reset source
-         3. Setting about BOD
-         4. Change system clock depended on different PLL settings
-         5. Output system clock from CKO pin, and the output frequency = system clock / 4
-     printf("+----------------------------------------+\n");
-     printf("|    NUC100 System Driver Sample Code    |\n");
-     if(M32(FLAG_ADDR) == SIGNATURE)
-         printf("  CPU Reset success!\n");
-         M32(FLAG_ADDR) = 0;
-         printf("  Press any key to continue ...\n");
-         getchar();
-     /* Misc system function test        */
-     /* Read Part Device ID */
-     printf("Product ID 0x%x\n", SYS_ReadPDID());
-     /* Get reset source from last operation */
-     u32data = SYS_GetResetSrc();
-     printf("Reset Source 0x%x\n", u32data);
-     /* Clear reset source */
-     SYS_ClearResetSrc(u32data);
-     /* Unlock protected registers for Brown-Out Detector settings */
-     SYS_UnlockReg();
-     /* Check if the write-protected registers are unlocked before BOD setting and CPU Reset */
-         printf("Protected Address is Unlocked\n");
-     /* Enable Brown-Out Detector, and set Brown-Out Detector voltage 2.7V */
-     SYS_EnableBOD(SYS_BODCR_BOD_INTERRUPT_EN, SYS_BODCR_BOD_VL_2_7V);
-     /* Enable BOD IRQ */
-     NVIC_EnableIRQ(BOD_IRQn);
-     /* Enable Low Voltage Reset function */
-     SYS_ENABLE_LVR();
-     /* Run PLL Test */
-     SYS_PLL_Test();
-     /* Write a signature work to SRAM to check if it is reset by software */
-     M32(FLAG_ADDR) = SIGNATURE;
-     printf("\n\n  >>> Reset CPU <<<\n");
-     /* Waiting for message send out */
-     UART_WAIT_TX_EMPTY(UART0);
-     /* Switch HCLK clock source to Internal RC 22.1184MHz clock and HCLK source divide 1 */
-     /* Set PLL to Power down mode and HW will also clear PLL_STB bit in CLKSTATUS register */
-     CLK_DisablePLL();
-     /* Reset CPU */
-     SYS_ResetCPU();
