/*---------------------------------------------------------------------------------------------------------*/ /* */ /* Copyright(c) 2015 Nuvoton Technology Corp. All rights reserved. */ /* */ /*---------------------------------------------------------------------------------------------------------*/ //*********************************************************************************************************** // Nuvoton Technology Corp. // E-mail: MicroC-8bit@nuvoton.com //*********************************************************************************************************** // Application: Use interrupt service routine // Set individual flag of each interrupt to execute ISR . // // Output : P0 show result // P1.4 flash when all interrupt pass // P2.1 flash when all interrupt pass // P0.7 flash when interrupt error //*********************************************************************************************************** #include <stdio.h> #include "N79E715.h" #include "Typedef.h" #include "Define.h" #include "Common.h" #include "Delay.h" #include "ISR.h" #include "Version.h" bit EA_Save_bit; //----------------------------------------------------------------------------------------------------------- void Interrupt_Error(void) { while(1) { P07 = 1; Delay1ms(500); P07 = 0; Delay1ms(500); } } //----------------------------------------------------------------------------------------------------------- void main(void) { uint16_t i; InitialUART0_Timer1(9600); // 9600 Baud Rate [url=home.php?mod=space&uid=72445]@[/url] 11.0592MHz Show_Version_Number_To_PC(); printf ("\n*=========================================================================="); printf ("\n* N79E715 Series Interrupt Sample Code."); printf ("\n*==========================================================================\n"); TR1 = 0; //Stop Timer1 for Interrupt Demo IE = 0x7F; EIE = 0xFF; EA = 1; //********************** INT0 Test *********************** P0 = 0xFF; IT0 = 1; set_IE0; // Trigger Interrupt PCON |= SET_BIT0; // Enter Idle Mode if(P0 != ~0x01) // Check ISR return value Interrupt_Error(); for(i = 0 ; i < 60000 ; i++); // Delay time //********************* Timer0 Test ********************** P0 = 0xFF; set_TF0; // Trigger Interrupt PCON |= SET_BIT0; // Enter Idle Mode if(P0 != ~0x02) // Check ISR return value Interrupt_Error(); for(i = 0 ; i < 60000 ; i++); // Delay time //********************** INT1 Test *********************** P0 = 0xFF; IT1 = 1; set_IE1; // Trigger Interrupt PCON |= SET_BIT0; // Enter Idle Mode if(P0 != ~0x03) // Check ISR return value Interrupt_Error(); for(i = 0 ; i < 60000 ; i++); // Delay time //********************* Timer1 Test ********************** P0 = 0xFF; set_TF1; // Trigger Interrupt PCON |= SET_BIT0; // Enter Idle Mode if(P0 != ~0x04) // Check ISR return value Interrupt_Error(); for(i = 0 ; i < 60000 ; i++); // Delay time //********************** UART0 Test ********************** P0 = 0xFF; set_RI; // Trigger Interrupt PCON |= SET_BIT0; // Enter Idle Mode if(P0 != ~0x05) // Check ISR return value Interrupt_Error(); for(i = 0 ; i < 60000 ; i++); // Delay time //********************* Timer2 Test ********************** P0 = 0xFF; set_TF2; // Trigger Interrupt PCON |= SET_BIT0; // Enter Idle Mode /* Check ISR return value */ if(P0 != ~0x06) // Check ISR return value Interrupt_Error(); for(i = 0 ; i < 60000 ; i++); // Delay time //********************** I2C Test ************************ P0 = 0xFF; set_SI; // Trigger Interrupt PCON |= SET_BIT0; // Enter Idle Mode if(P0 != ~0x07) // Check ISR return value Interrupt_Error(); for(i = 0 ; i < 60000 ; i++); // Delay time //********************** KBI Test ************************ P0 = 0xFF; set_KBIF0; // Trigger Interrupt PCON |= SET_BIT0; // Enter Idle Mode if(P0 != ~0x08) // Check ISR return value Interrupt_Error(); for(i = 0 ; i < 60000 ; i++); // Delay time //********************** BOD Test ************************ P0 = 0xFF; set_BOF; // Trigger Interrupt PCON |= SET_BIT0; // Enter Idle Mode if(P0 != ~0x09) // Check ISR return value Interrupt_Error(); for(i = 0 ; i < 60000 ; i++); // Delay time //********************** SPI Test ************************ P0 = 0xFF; // Trigger Interrupt set_SPIF; PCON |= SET_BIT0; // Enter Idle Mode if(P0 != ~0x0A) // Check ISR return value Interrupt_Error(); for(i = 0 ; i < 60000 ; i++); // Delay time //******************* Watch Dog Test ********************* P0 = 0xFF; set_WDTF; // Trigger Interrupt PCON |= SET_BIT0; // Enter Idle Mode if(P0 != ~0x0B) // Check ISR return value Interrupt_Error(); for(i = 0 ; i < 60000 ; i++); // Delay time //********************** ADC Test ************************/ P0 = 0xFF; set_ADCI; // Trigger Interrupt PCON |= SET_BIT0; // Enter Idle Mode if(P0 != ~0x0C) // Check ISR return value Interrupt_Error(); for(i = 0 ; i < 60000 ; i++); // Delay time //******************** Capture Test ********************** P0 = 0xFF; set_CAPF0; // Trigger Interrupt PCON |= SET_BIT0; // Enter Idle Mode if(P0 != ~0x0D) // Check ISR return value Interrupt_Error(); for(i = 0 ; i < 60000 ; i++); // Delay time //********************** PWM Test ************************ P0 = 0xFF; set_BKF; // Trigger Interrupt PCON |= SET_BIT0; // Enter Idle Mode if(P0 != ~0x0E) // Check ISR return value Interrupt_Error(); for(i = 0 ; i < 60000 ; i++); // Delay time EA = 0; // Disable all interrupt InitialUART0_Timer1(9600); // 9600 Baud Rate @ 11.0592MHz printf("\nInterrupt Test OK!"); while(1) { P14 = 1; P21 = 1; Delay1ms(500); P14 = 0; P21 = 0; Delay1ms(500); } } //----------------------------------------------------------------------------------------------------------- void INT0_ISR(void) interrupt 0 // Vector @ 0x03 { P0 = 0xFF-1; clr_IE0; } //----------------------------------------------------------------------------------------------------------- void Timer0_ISR(void) interrupt 1 // Vector @ 0x0B { P0 = 0xFF-2; clr_TF0; } //----------------------------------------------------------------------------------------------------------- void INT1_ISR(void) interrupt 2 // Vector @ 0x13 { P0 = 0xFF-3; clr_IE1; } //----------------------------------------------------------------------------------------------------------- void Timer1_ISR(void) interrupt 3 // Vector @ 0x1B { P0 = 0xFF-4; clr_TF1; } //----------------------------------------------------------------------------------------------------------- void UART0_ISR(void) interrupt 4 // Vector @ 0x23 { P0 = 0xFF-5; clr_RI; } //----------------------------------------------------------------------------------------------------------- void Timer2_ISR(void) interrupt 5 // Vector @ 0x2B { P0 = 0xFF-6; clr_TF2; } //----------------------------------------------------------------------------------------------------------- void I2C_ISR(void) interrupt 6 // Vector @ 0x33 { P0 = 0xFF-7; clr_SI; } //----------------------------------------------------------------------------------------------------------- void KBI_ISR(void) interrupt 7 // Vector @ 0x3B { P0 = 0xFF-8; clr_KBIF0; } //----------------------------------------------------------------------------------------------------------- void BOD_ISR(void) interrupt 8 // Vector @ 0x43 { P0 = 0xFF-9; clr_BOF; } //----------------------------------------------------------------------------------------------------------- void SPI_ISR(void) interrupt 9 // Vector @ 0x4B { P0 = 0xFF-10; clr_SPIF; } //----------------------------------------------------------------------------------------------------------- void WDT_ISR(void) interrupt 10 // Vector @ 0x53 { P0 = 0xFF-11; clr_WDTF; } //----------------------------------------------------------------------------------------------------------- void ADC_ISR(void) interrupt 11 // Vector @ 0x5B { P0 = 0xFF-12; clr_ADCI; } //----------------------------------------------------------------------------------------------------------- void Capture_ISR(void) interrupt 12 // Vector @ 0x63 { P0 = 0xFF-13; clr_CAPF0; } //----------------------------------------------------------------------------------------------------------- void PWM_Brake_ISR(void) interrupt 14 // Vector @ 0x73 { P0 = 0xFF-14; clr_BKF; } //-----------------------------------------------------------------------------------------------------------
收藏2 举报
本版积分规则 发表回复 回帖并转播 回帖后跳转到最后一页
人才类勋章
发帖类勋章
等级类勋章
时间类勋章
225
3848
18
扫码关注 21ic 官方微信
扫码关注嵌入式微处理器
扫码关注电源系统设计
扫码关注21ic项目外包
扫码浏览21ic手机版
本站介绍 | 申请友情链接 | 欢迎投稿 | 隐私声明 | 广告业务 | 网站地图 | 联系我们 | 诚聘英才
京公网安备 11010802024343号
