// MSP430x26x Demo - 8x8 Signed Multiply Accumulate
// Description: Hardware multiplier is used to multiply two numbers.
// The calculation is automatically initiated after the second operand is
// loaded. A second multiply accumulate operation is performed after that.
// Results are stored in RESLO and RESHI. SUMEXT contains the extended sign of
// result.
// ACLK = 32.768kHz, MCLK = SMCLK = default DCO
// MSP430F261x/241x
// --|RST |
// B. Nisarga
// Texas Instruments Inc.
// September 2007
// Built with CCE Version: 3.2.0 and IAR Embedded Workbench Version: 3.42A
#include
void main(void)
unsigned char value1,value2;
WDTCTL = WDTPW+WDTHOLD; // Stop WDT
MPY = 0x1234; // Load 1st operand - unsigned mult
OP2 = 0x5678; // Load second operand
value1 = 0x12; // Load first operand - signed MAC
value2 = 0x96; // Load second operand
// Sign-extend the values
if (value1 >=0x80)
MACS = 0xFF00 | value1;
else
MACS = value1;
if (value2 >=0x80)
OP2 = 0xFF00 | value2;
else
OP2 = value2;
_BIS_SR(LPM4_bits); // LPM4
