IAP (in-application programming): IAP is the ability to re-program the Flash memory
of a microcontroller while the user program is running.
• ICP (in-circuit programming): ICP is the ability to program the Flash memory of a
microcontroller using the JTAG protocol, the SWD protocol or the bootloader while the
device is mounted on the user application board.
可以。
