[应用相关] 使用STM8S105K6的ADC1出现问题
798|3
 楼主| Soraka 发表于 2017-3-19 20:24 | 显示全部楼层 |阅读模式
在使用STM8S105K6的ADC1的通道一进行AD转换时,转换出来的值不变且恒为2049,而10位AD最多只能到1024 ,程序反复检查也没有发现bug,我是开启了转换完成中断,在中断里面进行读取,ADC1的配置程序如下:
void ADC_Config()
  /*  Init GPIO for ADC1 */
  GPIO_Init(GPIOB, GPIO_PIN_1, GPIO_MODE_IN_FL_NO_IT);
  GPIO_Init(GPIOB, GPIO_PIN_2, GPIO_MODE_IN_FL_NO_IT);
  /* De-Init ADC peripheral*/
  ADC1_DeInit();
  /* Init ADC1 peripheral */
  ADC1_Init(ADC1_CONVERSIONMODE_SINGLE, ADC1_CHANNEL_1, ADC1_PRESSEL_FCPU_D18, \
            ADC1_EXTTRIG_TIM, DISABLE, ADC1_ALIGN_RIGHT, ADC1_SCHMITTTRIG_CHANNEL1,\
            DISABLE);
ADC1_ConversionConfig(ADC1_CONVERSIONMODE_SINGLE,
ADC1_CHANNEL_1,
                        ADC1_ALIGN_RIGHT);
/* Enable EOC interrupt */
  ADC1_ITConfig(ADC1_IT_EOCIE, ENABLE);
  /* Enable general interrupts */
  enableInterrupts();
  /*Start Conversion */
  ADC1_Cmd(ENABLE);
  ADC1_StartConversion();
转换值读出之后通过串口打印出来转换值的读取程序如下:
         /* start up converting every 500ms */
INTERRUPT_HANDLER(ADC1_IRQHandler, 22)
    /* In order to detect unexpected events during development,
        it is recommended to set a breakpoint on the following instruction.
         /* Debug code */
         if(ADC1_GetFlagStatus(ADC1_FLAG_EOC) == 0x80)
             printf("ADC CH1 VALUE IS:%d\n\r",ADC1_GetConversionValue());
//             printf("%d\n\r",ADC1_AIN1_Value);
             ADC1_ClearITPendingBit(ADC1_IT_EOC);
Garen2 发表于 2017-3-19 20:39 | 显示全部楼层
AD的时钟打开了吗
Ryze 发表于 2017-3-19 20:50 | 显示全部楼层
有几个外设时钟寄存器的,把要用的外设时钟都要打开
Varus 发表于 2017-3-19 21:01 | 显示全部楼层
STM8上电之后默认所有外设时钟都是打开的吧
