stm32 can如何测试?求大神指点
1199|6
 楼主| 雪中悍刀行 发表于 2017-3-28 17:16 | 显示全部楼层 |阅读模式
u8 CAN_Mode_Init(u8 tsjw,u8 tbs2,u8 tbs1,u16 brp,u8 mode){
          CAN_InitTypeDef        CAN_InitStructure;
          CAN_FilterInitTypeDef  CAN_FilterInitStructure;
    #if CAN_RX0_INT_ENABLE
              NVIC_InitTypeDef  NVIC_InitStructure;
    #endif
          RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO | RCC_APB2Periph_GPIOB, ENABLE);
          RCC_APB1PeriphClockCmd(RCC_APB1Periph_CAN1, ENABLE);
    //CAN_TX
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9;
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
    GPIO_Init(GPIOB, &GPIO_InitStructure);
    //CAN_RX
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8;
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU;
          GPIO_PinRemapConfig(GPIO_Remap1_CAN1, ENABLE);
          //CANµ¥ÔªÉèÖÃ
                CAN_InitStructure.CAN_TTCM=DISABLE;
                CAN_InitStructure.CAN_ABOM=DISABLE;
          CAN_InitStructure.CAN_AWUM=DISABLE;
          CAN_InitStructure.CAN_NART=ENABLE;        //
          CAN_InitStructure.CAN_RFLM=DISABLE;
          CAN_InitStructure.CAN_TXFP=DISABLE;
          CAN_InitStructure.CAN_Mode= mode;
          //ÉèÖò¨ÌØÂÊ
          CAN_InitStructure.CAN_SJW=tsjw;
          CAN_InitStructure.CAN_BS1=tbs1;
          CAN_InitStructure.CAN_BS2=tbs2;
          CAN_InitStructure.CAN_Prescaler=brp;
          CAN_Init(CAN1, &CAN_InitStructure);
                CAN_FilterInitStructure.CAN_FilterNumber=0;
                CAN_FilterInitStructure.CAN_FilterMode=CAN_FilterMode_IdMask;
          CAN_FilterInitStructure.CAN_FilterScale=CAN_FilterScale_32bit;
          CAN_FilterInitStructure.CAN_FilterIdHigh=0x0000;
          CAN_FilterInitStructure.CAN_FilterIdLow=0x0000;
          CAN_FilterInitStructure.CAN_FilterMaskIdHigh=0x0000;
          CAN_FilterInitStructure.CAN_FilterMaskIdLow=0x0000;
          CAN_FilterInitStructure.CAN_FilterFIFOAssignment=CAN_Filter_FIFO0;
          CAN_FilterInitStructure.CAN_FilterActivation=ENABLE;
          CAN_FilterInit(&CAN_FilterInitStructure);
#if CAN_RX0_INT_ENABLE   //#define CAN_RX0_INT_ENABLE  1
                CAN_ITConfig(CAN1,CAN_IT_FMP0,ENABLE);
                //CAN_ITConfig(CAN1,CAN_IT_FMP1,ENABLE);
          NVIC_InitStructure.NVIC_IRQChannel = USB_LP_CAN1_RX0_IRQn;
          NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
          NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;
          NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
          NVIC_Init(&NVIC_InitStructure);
#endif
        return 0;
 楼主| 雪中悍刀行 发表于 2017-3-28 17:17 | 显示全部楼层
void USB_LP_CAN1_RX0_IRQHandler(void){   //USB_LP_CAN1_RX0_IRQHandler   CAN1_RX1_IRQHandler
                int i=0;
    CanRxMsg RxMessage;
                CAN_Receive(CAN1, CAN_FIFO0, &RxMessage);
                for(i=0;i<8;i++){
                re_data[i]=RxMessage.Data[i];
                printf("receive£¡\n");
int main(void)
        int k;
        uart1_init(9600);         //´®¿Ú³õʼ»¯Îª9600
        k=CAN_Mode_Init(1,2,1,9,0);//CAN³õʼ»¯,²¨ÌØÂÊ36/(1+2+1)*9 = 1M
         printf("k=%d\n",k);
        while(1)
                        if(k==0){
                                Can_Send_Msg(canbuf,8);
                        //        k++;
                                //delay_ms(1000);
                                Can_Receive_Msg(re_data);
 楼主| 雪中悍刀行 发表于 2017-3-28 17:18 | 显示全部楼层
                int i=0;
    CanRxMsg RxMessage;
                for(i=0;i<8;i++){
                int i=0;
    CanRxMsg RxMessage;
                for(i=0;i<8;i++){
int main(void)
        int k;
         printf("k=%d\n",k);
        while(1)
                        if(k==0){
                        //        k++;
                                //delay_ms(1000);
一代掌门 发表于 2017-3-28 23:27 | 显示全部楼层
逻辑分析仪抓数据!
然后USB-CAN调试
@若水 发表于 2017-3-29 14:30 | 显示全部楼层
先用环回模式测试一下,看程序有没有问题,没有再测试接口芯片是否接对了
yklstudent 发表于 2017-3-29 16:50 | 显示全部楼层
你首先得有一个好的开发工具,比如周立功的USB转CAN工具
Prry 发表于 2017-3-30 00:09 | 显示全部楼层
买个usb转can工具,资金充足可以买周立功的,省钱可以买其他,完全兼容周立功的。我用到就是其他,x宝很多。
