[资料分享] TI新产品介绍-LMH1208 12G UHD-SDI Dual Cable Driver
776|0
 楼主| xyz549040622 发表于 2017-3-29 20:38 | 显示全部楼层 |阅读模式
描述
LMH1208 device is a 12G UHD-SDI low power dual output cable driver. It supports SMPTE        video rates up to 11.88 Gbps, enabling UHD video for 4K/8K applications. The additional equalized        100-Ω driver output on the host-side can be used for monitoring or signal distribution        purposes.
The programmable PCB input equalizer provides high frequency boost to reduce inter symbol        interference (ISI) induced by PCB board trace. The integrated 75-Ω termination and return loss        network at both cable driver outputs facilitate overall system design in meeting stringent SMPTE        return loss requirements.
Input Signal Detect determines the presence of a valid signal at the input of the cable        driver. This sensing feature may be used to alert the user of a system fault and activate a Power        Save Mode, reducing the power consumption of the cable driver. The LMH1208 provides selectable slew        rates for data rates up to 11.88 Gbps. The output slew rate and amplitude can be controlled by pin,        SPI, or SMBus control.
The LMH1208 is powered from a single 2.5-V supply. It is offered in a small footprint 5        mm × 5 mm 32-pin WQFN package. The LMH1208 is pin compatible with the LMH1228 (12G Dual Cable        Driver with Integrated Reclocker).
特性
  • Supports ST-2082-1 (12G), ST-2081-1 (6G), ST-424 (3G), ST-292 (HD), and ST-259        (SD)
  • Compatible With DVB-ASI and AES10 (MADI)
  • Dual Differential Output Cable Drivers
  • On-Chip 75-Ω        Termination and Return Loss Compensation Network
  • Host-Side Equalized 100-Ω Loop-Back Output
  • Programmable Slew Rate Control on 75-Ω Outputs
  • Programmable Pre-Emphasis and Output Amplitude on 75-Ω        Outputs
  • Programmable De-Emphasis and Output Amplitude on        100-Ω Output
  • Polarity Inversion on 75-Ω and 100-Ω Outputs
  • Automatic Power Save in Absence of Input Signal
    • Power Consumption: 25 mW (Typical)
  • Power-Down Control Through ENABLE        Pin
  • Single 2.5-V Supply
    • Power Consumption: 255 mW (Typical)
  • Programmable Through Pins, SPI, or SMBus        Interface
  • –40°C to +85°C Operating Temperature        Range
  • 5-mm × 5-mm, 32-pin WQFN        Package
个人签名:qq群: 嵌入式系统arm初学者 224636155←← +→→点击-->小 i 精品课全集,21ic公开课~~←←→→点击-->小 i 精品课全集,给你全方位的技能策划~~←←
2841
