To clone an existing project:
From the File menu, select New Project. You can only clone a Chip-level project. Select Chip-level.
Select a name and location for your new project and click OK.
In the Clone project box click Browse and find the .CMX or .SOC file of the project you want to clone.
Choose whether you want to choose a new base device or not. If you do, select View Catalog to select a new device and Click OK.
If you choose to use the same target device, select Use the same target device radio button and click OK.
