| 这就是你发的链接中的代码 /**************** from pn53x-internal.h **********/
 // Register addresses
 #define PN53X_REG_Control_switch_rng 0x6106
 #define PN53X_REG_CIU_Mode 0x6301
 #define PN53X_REG_CIU_TxMode 0x6302
 #define PN53X_REG_CIU_RxMode 0x6303
 #define PN53X_REG_CIU_TxControl 0x6304
 #define PN53X_REG_CIU_TxAuto 0x6305
 #define PN53X_REG_CIU_TxSel 0x6306
 #define PN53X_REG_CIU_RxSel 0x6307
 #define PN53X_REG_CIU_RxThreshold 0x6308
 #define PN53X_REG_CIU_Demod 0x6309
 #define PN53X_REG_CIU_FelNFC1 0x630A
 #define PN53X_REG_CIU_FelNFC2 0x630B
 #define PN53X_REG_CIU_MifNFC 0x630C
 #define PN53X_REG_CIU_ManualRCV 0x630D
 #define PN53X_REG_CIU_TypeB 0x630E
 // #define PN53X_REG_- 0x630F
 // #define PN53X_REG_- 0x6310
 #define PN53X_REG_CIU_CRCResultMSB 0x6311
 #define PN53X_REG_CIU_CRCResultLSB 0x6312
 #define PN53X_REG_CIU_GsNOFF 0x6313
 #define PN53X_REG_CIU_ModWidth 0x6314
 #define PN53X_REG_CIU_TxBitPhase 0x6315
 #define PN53X_REG_CIU_RFCfg 0x6316
 #define PN53X_REG_CIU_GsNOn 0x6317
 #define PN53X_REG_CIU_CWGsP 0x6318
 #define PN53X_REG_CIU_ModGsP 0x6319
 #define PN53X_REG_CIU_TMode 0x631A
 #define PN53X_REG_CIU_TPrescaler 0x631B
 #define PN53X_REG_CIU_TReloadVal_hi 0x631C
 #define PN53X_REG_CIU_TReloadVal_lo 0x631D
 #define PN53X_REG_CIU_TCounterVal_hi 0x631E
 #define PN53X_REG_CIU_TCounterVal_lo 0x631F
 // #define PN53X_REG_- 0x6320
 #define PN53X_REG_CIU_TestSel1 0x6321
 #define PN53X_REG_CIU_TestSel2 0x6322
 #define PN53X_REG_CIU_TestPinEn 0x6323
 #define PN53X_REG_CIU_TestPinValue 0x6324
 #define PN53X_REG_CIU_TestBus 0x6325
 #define PN53X_REG_CIU_AutoTest 0x6326
 #define PN53X_REG_CIU_Version 0x6327
 #define PN53X_REG_CIU_AnalogTest 0x6328
 #define PN53X_REG_CIU_TestDAC1 0x6329
 #define PN53X_REG_CIU_TestDAC2 0x632A
 #define PN53X_REG_CIU_TestADC 0x632B
 // #define PN53X_REG_- 0x632C
 // #define PN53X_REG_- 0x632D
 // #define PN53X_REG_- 0x632E
 #define PN53X_REG_CIU_RFlevelDet 0x632F
 #define PN53X_REG_CIU_SIC_CLK_en 0x6330
 #define PN53X_REG_CIU_Command 0x6331
 #define PN53X_REG_CIU_CommIEn 0x6332
 #define PN53X_REG_CIU_DivIEn 0x6333
 #define PN53X_REG_CIU_CommIrq 0x6334
 #define PN53X_REG_CIU_DivIrq 0x6335
 #define PN53X_REG_CIU_Error 0x6336
 #define PN53X_REG_CIU_Status1 0x6337
 #define PN53X_REG_CIU_Status2 0x6338
 #define PN53X_REG_CIU_FIFOData 0x6339
 #define PN53X_REG_CIU_FIFOLevel 0x633A
 #define PN53X_REG_CIU_WaterLevel 0x633B
 #define PN53X_REG_CIU_Control 0x633C
 #define PN53X_REG_CIU_BitFraming 0x633D
 #define PN53X_REG_CIU_Coll 0x633E
 /**************** end pn53x-internal.h **********/
 #include <inttypes.h>
 #include <signal.h>
 #include <stdio.h>
 #include <stddef.h>
 #include <stdlib.h>
 #include <string.h>
 #include <nfc/nfc.h>
 #include <nfc/nfc-types.h>
 int pn53x_read_register(struct nfc_device *pnd, uint16_t ui16RegisterAddress, uint8_t *ui8Value);
 int pn53x_write_register(struct nfc_device *pnd, const uint16_t ui16RegisterAddress, const uint8_t ui8SymbolMask, const uint8_t ui8Value);
 static nfc_device *pnd = NULL;
 static nfc_context *context;
 int
 main(int argc, const char *argv[])
 // Display libnfc version
 const char *acLibnfcVersion = nfc_version();
 printf("%s uses libnfc %s\n", argv[0], acLibnfcVersion);
 nfc_target nt;
 int res = 0;
 nfc_init(&context);
 if (context == NULL) {
 printf("Unable to init libnfc (malloc)");
 exit(EXIT_FAILURE);
 pnd = nfc_open(context, NULL);
 if (pnd == NULL) {
 printf("%s", "Unable to open NFC device.");
 nfc_exit(context);
 exit(EXIT_FAILURE);
 if (nfc_initiator_init(pnd) < 0) {
 nfc_perror(pnd, "nfc_initiator_init");
 nfc_close(pnd);
 nfc_exit(context);
 exit(EXIT_FAILURE);
 printf("NFC reader: %s opened\n", nfc_device_get_name(pnd));
 printf("nfc_device_set_property_bool(NP_EASY_FRAMING)=%d\n",
 nfc_device_set_property_bool(pnd, NP_EASY_FRAMING, false));
 printf("pn53x_write_register(PN53X_REG_CIU_Mode)=%d\n",
 pn53x_write_register(pnd, PN53X_REG_CIU_Mode, 0xff, 0xff));
 printf("pn53x_write_register(PN53X_REG_CIU_TxAuto)=%d\n",
 pn53x_write_register(pnd, PN53X_REG_CIU_TxAuto, 0xff, 0x00));
 printf("pn53x_write_register(PN53X_REG_CIU_TxMode)=%d\n",
 pn53x_write_register(pnd, PN53X_REG_CIU_TxMode, 0xff, 0x03));
 printf("pn53x_write_register(PN53X_REG_CIU_RxMode)=%d\n",
 pn53x_write_register(pnd, PN53X_REG_CIU_RxMode, 0xff, 0x03));
 printf("pn53x_write_register(PN53X_REG_CIU_TypeB)=%d\n",
 pn53x_write_register(pnd, PN53X_REG_CIU_TypeB, 0xff, 0x03));
 printf("pn53x_write_register(PN53X_REG_CIU_Demod)=%d\n",
 pn53x_write_register(pnd, PN53X_REG_CIU_Demod, 0xff, 0x4d));
 printf("pn53x_write_register(PN53X_REG_CIU_GsNOn)=%d\n",
 pn53x_write_register(pnd, PN53X_REG_CIU_GsNOn, 0xff, 0xff));
 printf("pn53x_write_register(PN53X_REG_CIU_CWGsP)=%d\n",
 pn53x_write_register(pnd, PN53X_REG_CIU_CWGsP, 0xff, 0x3f));
 printf("pn53x_write_register(PN53X_REG_CIU_ModGsP)=%d\n",
 pn53x_write_register(pnd, PN53X_REG_CIU_ModGsP, 0xff, 0x18));
 printf("pn53x_write_register(PN53X_REG_CIU_RxThreshold)=%d\n",
 pn53x_write_register(pnd, PN53X_REG_CIU_RxThreshold, 0xff, 0x4d));
 printf("pn53x_write_register(PN53X_REG_CIU_ModWidth)=%d\n",
 pn53x_write_register(pnd, PN53X_REG_CIU_ModWidth, 0xff, 0x68));
 printf("pn53x_write_register(PN53X_REG_CIU_ManualRCV)=%d\n",
 pn53x_write_register(pnd, PN53X_REG_CIU_ManualRCV, 0xff, 0x10));
 uint8_t val;
 pn53x_read_register(pnd, PN53X_REG_CIU_Mode, &val); printf("PN53X_REG_CIU_Mode %d %d\n", val, 0xff);
 pn53x_read_register(pnd, PN53X_REG_CIU_TxAuto, &val); printf("PN53X_REG_CIU_TxAuto %d %d\n", val, 0x00);
 pn53x_read_register(pnd, PN53X_REG_CIU_TxMode, &val); printf("PN53X_REG_CIU_TxMode %d %d\n", val, 0x03);
 pn53x_read_register(pnd, PN53X_REG_CIU_RxMode, &val); printf("PN53X_REG_CIU_RxMode %d %d\n", val, 0x03);
 pn53x_read_register(pnd, PN53X_REG_CIU_TypeB, &val); printf("PN53X_REG_CIU_TypeB %d %d\n", val, 0x03);
 pn53x_read_register(pnd, PN53X_REG_CIU_Demod, &val); printf("PN53X_REG_CIU_Demod %d %d\n", val, 0x4d);
 pn53x_read_register(pnd, PN53X_REG_CIU_GsNOn, &val); printf("PN53X_REG_CIU_GsNOn %d %d\n", val, 0xff);
 pn53x_read_register(pnd, PN53X_REG_CIU_CWGsP, &val); printf("PN53X_REG_CIU_CWGsP %d %d\n", val, 0x3f);
 pn53x_read_register(pnd, PN53X_REG_CIU_ModGsP, &val); printf("PN53X_REG_CIU_ModGsP %d %d\n", val, 0x18);
 pn53x_read_register(pnd, PN53X_REG_CIU_RxThreshold, &val); printf("PN53X_REG_CIU_RxThreshold %d %d\n", val, 0x4d);
 pn53x_read_register(pnd, PN53X_REG_CIU_ModWidth, &val); printf("PN53X_REG_CIU_ModWidth %d %d\n", val, 0x68);
 pn53x_read_register(pnd, PN53X_REG_CIU_ManualRCV, &val); printf("PN53X_REG_CIU_ManualRCV %d %d\n", val, 0x10);
 uint8_t cmd_atqb[] = {0x05, 0, 0, 0x71, 0xff};
 uint8_t recv[384];
 int sz = nfc_initiator_transceive_bytes(pnd, cmd_atqb, sizeof(cmd_atqb), recv, sizeof(recv), -1);
 printf("ATQB got %d bytes\n", sz);
 uint8_t cmd_attrib[] = {0x1d  , 0x00  , 0x00  , 0x00  , 0x00  , 0x00  , 0x08  , 0x01  , 0x08, 0xf3, 0x10};
 sz = nfc_initiator_transceive_bytes(pnd, cmd_attrib, sizeof(cmd_attrib), recv, sizeof(recv), -1);
 printf("ATTRIB got %d bytes\n", sz);
 uint8_t cmd_uid[] = {0x00 , 0x36 , 0x00 , 0x00 , 0x08  , 0x57 , 0x44};
 sz = nfc_initiator_transceive_bytes(pnd, cmd_uid, sizeof(cmd_uid), recv, sizeof(recv), -1);
 printf("UID got %d bytes\n", sz);
 for (int i = 0; i < sz; ++i) {
 printf("%02x,", recv[i]);
 printf("\n");
 nfc_close(pnd);
 nfc_exit(context);
 exit(EXIT_SUCCESS);
