关于lpc2368的MAM设置
2464|1
 楼主| li_g888 发表于 2010-7-29 18:04 | 显示全部楼层 |阅读模式
最近搞lpc2368,在设置MAM时不能设置,而且是程序死在那里,我的系统时钟是48(程序测得)兆,按datasheet上说应该设置成3,可就是不行,只能设置为5.6.7,而我把它写到09年版本的2368上确可以设置,我现在用的是1014版,应该是新版啊,请大家赐教,今晚回家等答案。。。。。
static  void  MAM_Init (void)
    CPU_INT32U  clk_freq;
    clk_freq = BSP_CPU_ClkFreq();                               /* Get the current core clock frequency                     */
  debug_init();  //调试状态初始化 串口0
DEBUG("MAMTIM0 %d",MAMTIM);
    DEBUG("clk_freq0 %d",clk_freq);
    MAMCR    = 0;                                               /* Disable MAM functionality                                */
    if (clk_freq < 20000000) {                                  /* Compare current clock frequency with MAM modes           */
        MAMTIM = 1;                                             /* Set MAM fetch cycles to 1 processor clock in duration    */
    if (clk_freq < 40000000) {
        MAMTIM = 2;                                             /* Set MAM fetch cycles to 2 processor clock in duration    */
    if (clk_freq >= 40000000) {
        MAMTIM = 3;                                             /* Set MAM fetch cycles to 3 processor clock in duration    */
DEBUG("MAMTIM1 %d",MAMTIM);
    DEBUG("clk_freq1 %d",clk_freq);
    MAMCR = 2;                                                  /* Enable full MAM functionality                            */
 楼主| li_g888 发表于 2010-7-30 15:05 | 显示全部楼层
没人赐教啊
