MSP430F2013 SD16
2802|1
 楼主| goodmoodnow 发表于 2010-8-7 09:37 | 显示全部楼层 |阅读模式
请问谁用过MSP430F2013 SD16,我把相关的寄存器都配置了,但是转换还是不准,而且随着输入电压增大,感觉误差越大,请各位帮我看看,谢谢了
oid int_clk()
        BCSCTL1 &= ~XTS;                //打开LFXT1并处于低频模式
        BCSCTL1 = RSEL0 + RSEL1 + RSEL2;//标称频率 RSELx = 7
        DCOCTL = DCO0 + DCO1;           //内部DCOx = 3 频率在(2.2 V/3 V) 0.80-1.50MHz之间
        DCOCTL = MOD0 + MOD1;           //调整频率
                                                         //(默认)MCLK时钟源为DCOCLK,SMCLK时钟源为DCOCLK
        do
            IFG1 &= ~OFIFG;             //清除振荡错误标志
            for(i = 0; i < 100; i++)
              _NOP();   //延时等待
        while ((IFG1 & OFIFG) != 0); //如果标志为1继续循环等待
        IFG1 &= ~OFIFG;
void int_adc()
        P1SEL |= 0X03;                            // 选择P1.0&P1.1第二功能
        SD16AE |= SD16AE1 + SD16AE0;              // SD16 External Input Enable P1.0&P1.1
        SD16CTL = SD16REFON+SD16SSEL_1;           // 1.2V ref, SMCLK
      //  SD16CTL &= ~SD16VMIDON + ~SD16LP;         // SD16 Switch Vmid Buffer off and not Low Power Mode Enable
        SD16CCTL0 |= SD16SNGL +  SD16IE + SD16UNI + SD16OSR_256;  // Single conv, enable interrupt,Unipolar(1) Mode,Channel x OverSampling Ratio 256
        SD16INCTL0 |= SD16INTDLY_0 + SD16INCH_0 + SD16GAIN_1;  // SD16 Interrupt after 4.Conversion,SD16 Input Channel select A0 ,Input Pre-Amplifier Gain Select *1
        for (i = 0; i < 0x3600; i++);             // Delay for 1.2V ref startup
 楼主| goodmoodnow 发表于 2010-8-7 14:38 | 显示全部楼层
请问有谁知道SD16 数字量与模拟量之间转换的数学表达式吗?
