[matlab] 范例:opencore组织RISCMCU IP Core全套最新代码 _port
2196|0
 楼主| sherry88 发表于 2010-8-30 11:05 | 显示全部楼层 |阅读模式
---- WISHBONE RISCMCU IP Core ----
---- This file is part of the RISCMCU project ----
---- http://www.opencores.org/projects/riscmcu/ ----
---- Description ----
---- Implementation of a RISC Microcontroller based on Atmel AVR ----
---- AT90S1200 instruction set and features with Altera Flex10k20 FPGA. ----
---- Author(s): ----
---- - Yap Zi He, yapzihe@hotmail.com ----
---- Copyright (C) 2001 Authors and OPENCORES.ORG ----
---- This source file may be used and distributed without ----
---- restriction provided that this copyright statement is not ----
---- removed from the file and that any derivative work contains ----
---- the original copyright notice and the associated disclaimer. ----
---- This source file is free software; you can redistribute it ----
---- and/or modify it under the terms of the GNU Lesser General ----
---- Public License as published by the Free Software Foundation; ----
---- either version 2.1 of the License, or (at your option) any ----
---- later version. ----
---- This source is distributed in the hope that it will be ----
---- useful, but WITHOUT ANY WARRANTY; without even the implied ----
---- warranty of MERCHANTABILITY or FITNESS FOR A PARTICULAR ----
---- PURPOSE. See the GNU Lesser General Public License for more ----
---- details. ----
---- You should have received a copy of the GNU Lesser General ----
---- Public License along with this source; if not, download it ----
---- from http://www.opencores.org/lgpl.shtml ----
library ieee;
use ieee.std_logic_1164.all;
entity v_port is
port( rd_port, wr_port, rd_ddr, wr_ddr, rd_pin : in std_logic;
clk, clrn : in std_logic;
c : inout std_logic_vector(7 downto 0);
pin : inout std_logic_vector(7 downto 0)
end v_port;
architecture ioport of v_port is
component v_port_bit
port( rd_port,wr_port,rd_ddr,wr_ddr,rd_pin : in std_logic;
clk,clrn : in std_logic;
c : inout std_logic;
end component;
begin
g1:
for i in 0 to 7 generate
u1 : v_port_bit
port map (rd_port, wr_port, rd_ddr, wr_ddr, rd_pin, clk, clrn, c(i), pin(i));
end generate;
end ioport;
