PSoC1 用什么工具来调试?
2438|3
 楼主| Obama 发表于 2010-10-18 17:25 | 显示全部楼层 |阅读模式
官方发布的miniprog3,其说明中提到:提供对PSoC1,PSoC3,PSoC5的编程,以及PSoC3和PSoC5的调试。
那PSoC1用什么来调试?
原文:
'The PSoC® MiniProg3 Program and Debug Kit is an all-in-one programmer for PSoC 1, PSoC 3 and PSoC 5 architectures as well as a debug tool for PSoC 3 and PSoC 5 architectures.  Included with the kit is a 10-pin ribbon cable for connecting to standard 10-pin JTAG header interfaces utilized for our PSoC 3 and PSoC 5 architectures while the device itself supports the 5-pin ISSP programming header for PSoC 1 architectures.  Please note, this kit only contains the MiniProg3 and supporting cables; it is intended to provide you with an additional program/debug capability to meet your needs."
Go_PSoC 发表于 2010-10-18 22:37 | 显示全部楼层
PSoC1用CY3215
三杯两盏酒 发表于 2010-10-19 20:35 | 显示全部楼层
那其他系列的和PSOC1一样吗?
Go_PSoC 发表于 2010-10-20 10:57 | 显示全部楼层
3# 三杯两盏酒
正如楼主所说,其他系列(3/5)用miniprog3即可
