[STM32F4] 问个串口的问题
920|5
 楼主| xiaox314 发表于 2017-9-12 14:40 | 显示全部楼层 |阅读模式
M4的片子,初始化串口后,就一直中断,发现是TXE 和TC一直为1,后续测试只要开启UART1的时钟,这2位就一直是1,请问香水城主是什么原因会引起此现象?
 楼主| xiaox314 发表于 2017-9-12 14:50 | 显示全部楼层
使用的是IAR的编译器,这个有关系吗?坛子里有其他人遇到此种情况的人有么?
yklstudent 发表于 2017-9-12 15:01 | 显示全部楼层
上你串口初始化的代码
 楼主| xiaox314 发表于 2017-9-12 15:10 | 显示全部楼层
void USARTConfig(void)
    USART_InitTypeDef     USART_InitStructure;
    GPIO_InitTypeDef      GPIO_InitStructure;
    NVIC_InitTypeDef      NVIC_InitStructure;
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1, ENABLE);   //APB2  USART1
    RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOA,ENABLE);
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9|GPIO_Pin_10;   //PA9--TX  PA10--RX
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;
    GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
    GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL;
    GPIO_Init(GPIOA, &GPIO_InitStructure);
    GPIO_PinAFConfig(GPIOA,GPIO_PinSource9,GPIO_AF_USART1);
    GPIO_PinAFConfig(GPIOA,GPIO_PinSource10,GPIO_AF_USART1);
    NVIC_PriorityGroupConfig(NVIC_PriorityGroup_1);
    NVIC_InitStructure.NVIC_IRQChannel  = USART1_IRQn;
    NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
    NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;
    NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
    NVIC_Init(&NVIC_InitStructure);
    USART_DeInit(USART1);
    USART_InitStructure.USART_BaudRate = 9600;
    USART_InitStructure.USART_WordLength = USART_WordLength_8b;
    USART_InitStructure.USART_StopBits = USART_StopBits_1;
    USART_InitStructure.USART_Parity = USART_Parity_No;
    USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;
    USART_InitStructure.USART_Mode = USART_Mode_Rx ;//|USART_Mode_Tx
    USART_Init(USART1, &USART_InitStructure);
//                USART_ITConfig(USART1,USART_IT_RXNE,ENABLE);
//                USART_ClearITPendingBit(USART1, USART_IT_RXNE);
//                USART_ITConfig(USART1,USART_IT_TC,ENABLE);
//             USART_ClearITPendingBit(USART1, USART_IT_TC);
                USART_Cmd(USART1,ENABLE);
Xflyan 发表于 2017-9-12 15:11 | 显示全部楼层
不发数据的情况下,这两个位就是1的
所以默认发送中断是关闭的,只有在数据发送的情况下才打开发送中断
 楼主| xiaox314 发表于 2017-9-12 16:00 | 显示全部楼层
不发数据的情况下,这两个位就是1的
所以默认发送中断是关闭的,只有在数据发送的情况下才打开发送中断 ...
恩,仔细看了寄存器,复位值,如你所说
