void SPI_configuration()
SPI_InitTypeDef SPI_InitStructure;
DMA_InitTypeDef DMA_InitStructure;
SPI_Cmd(SPI2, DISABLE);
SPI_I2S_DeInit(SPI2);
//----------SPI_SLAVE configuration-------
SPI_InitStructure.SPI_Direction = SPI_Direction_2Lines_FullDuplex;
SPI_InitStructure.SPI_Mode = SPI_Mode_Slave;
SPI_InitStructure.SPI_DataSize = SPI_DataSize_16b;
SPI_InitStructure.SPI_CPOL = SPI_CPOL_Low;
SPI_InitStructure.SPI_CPHA = SPI_CPHA_1Edge;
SPI_InitStructure.SPI_NSS = SPI_NSS_Hard;
SPI_InitStructure.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_2; //36M/xx......
SPI_InitStructure.SPI_FirstBit = SPI_FirstBit_MSB;
SPI_InitStructure.SPI_CRCPolynomial = 7;
SPI_Init(SPI2, &SPI_InitStructure);
DMA_DeInit(DMA1_Channel5); //Tx
DMA_InitStructure.DMA_PeripheralBaseAddr = SPI_SLAVE_DR_Base;
DMA_InitStructure.DMA_MemoryBaseAddr = (u32)SPI_SLAVE_Buffer_Tx; DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralDST;
DMA_InitStructure.DMA_BufferSize = BufferSize;
DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;
DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;
DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord;
DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord;
DMA_InitStructure.DMA_Mode = DMA_Mode_Normal;
DMA_InitStructure.DMA_Priority = DMA_Priority_High;
DMA_Priority_Low;
DMA_InitStructure.DMA_M2M = DMA_M2M_Disable;
DMA_Init(DMA1_Channel5, &DMA_InitStructure);
DMA_DeInit(DMA1_Channel4); //Rx
DMA_InitStructure.DMA_MemoryBaseAddr = (u32)SPI_SLAVE_Buffer_Rx;//Rx
DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralSRC; DMA_InitStructure.DMA_BufferSize = BufferSize;
DMA_InitStructure.DMA_Priority = DMA_Priority_VeryHigh;
DMA_Init(DMA1_Channel4, &DMA_InitStructure);
SPI_Cmd(SPI2, ENABLE);
/* Enable SPI_SLAVE Tx request */
SPI_I2S_DMACmd(SPI2, SPI_I2S_DMAReq_Tx, ENABLE);
SPI_I2S_DMACmd(SPI2, SPI_I2S_DMAReq_Rx, ENABLE); //;;;;
DMA_Cmd(DMA1_Channel5, ENABLE);
DMA_Cmd(DMA1_Channel4, ENABLE);
DMA_ITConfig(DMA1_Channel5, DMA_IT_TE, ENABLE); //Tx
DMA_ITConfig(DMA1_Channel4, DMA_IT_TC, ENABLE); //Rx..need
代码如上,如果我以8位的方式传输,就没有问题
