[产品供应] MS8413 192kHz Digital Audio Receiver/Converter(D/A)
1643|0
 楼主| soundbaraudio 发表于 2017-9-22 10:37 | 显示全部楼层 |阅读模式
MS8413 is a monolithic CMOS device that receives
and decodes one of four stereo pairs of digital audio data
according to the IEC60958,S/PDIF,EIAJ CP1201,or
AES3 interface standards. MS8413 includes
interpolation, multi-bit D/A conversion and output
analog filtering. The MS8413 contains on-chip digital
de-emphasis, operates from a single +3.3 V or +5 V
power supply. These features are ideal for DVD players
& recorders, digital televisions.
The MS8413 is available in a 28-pin SSOP package.
Complete EIAJ CP1201, IEC-60958, AES3,
S/PDIF-Compatible Receiver
n +3.3 V or +5 V Power Supply
n 4:1 S/PDIF Input MUX
n 32 kHz to 192 kHz Sample Frequency Range
n Low-Jitter Clock Recovery
n Single-ended or differential input
n Multi-bit Delta-Sigma Modulator
n 24-bit Conversion
n 105 dB Dynamic Range
n -90 dB THD+N
n Low Clock-Jitter Sensitivity
n On-chip Digital De-emphasis
杭州瑞盟科技有限公司
锦宏世纪科技有限公司
MS8416/MS8413/MS4344 如需取样或者技术支持请咨询联系:
莫先生 15112476010
