我就搞不懂了,没发送0怎么出来0 了,大家看看
2690|4
 楼主| 416775364TP 发表于 2011-4-4 14:41 | 显示全部楼层 |阅读模式
VB串口传数据,0不知道怎么跑来的程序如下:
Private Sub openclosecmd_Click()
If MSComm1.PortOpen = True Then
        MSComm1.PortOpen = False
        openclosecmd.Caption = "打开串口"
       'open_close.Caption = "打开串口"
        Label3.ForeColor = RGB(0, 0, 0)
        Label3.Caption = "已关闭"
        Shape1.FillColor = RGB(255, 255, 0)
        Shape1.FillStyle = 0
        Exit Sub
   End If
  If MSComm1.PortOpen = False Then
    openclosecmd.Caption = "关闭串口"
   'open_close.Caption = "关闭串口"
     Label3.ForeColor = RGB(255, 0, 0)
     Label3.Caption = "已开启"
     Shape1.FillColor = RGB(255, 0, 0)
Exit Sub
End If
End Sub
Private Sub Command3_Click(Index As Integer)
Dim sendData1(1) As Byte
Dim X As String
Select Case Index
        Case 0
               X = MsgBox("串口未打开,请打开串口", 16)
               Exit Sub
               End If
               MSComm1.OutBufferCount = 0
               sendData1(1) = &H1
               MSComm1.Output = sendData1
        Case 1
               Exit Sub
               End If
               sendData1(1) = &H2
        Case 2
               Exit Sub
               End If
               sendData1(1) = &H3
        Case 3
               Exit Sub
               End If
               sendData1(1) = &H4
        Case 4
               Exit Sub
               End If
               sendData1(1) = &H5
        Case 5
               Exit Sub
               End If
               sendData1(1) = &H6
        Case 6
               Exit Sub
               End If
               sendData1(1) = &H7
        Case 7
               Exit Sub
               End If
               sendData1(1) = &H8
        Case 8
               Exit Sub
               End If
               sendData1(1) = &H9
        Case 9
               Exit Sub
               End If
               sendData1(1) = &HA
        Case 10
               Exit Sub
               End If
               sendData1(1) = &HB
        Case 11
               Exit Sub
               End If
               sendData1(1) = &HC
        Case 12
               Exit Sub
               End If
               sendData1(1) = &HD
        Case 13
               Exit Sub
               End If
               sendData1(1) = &HE
        Case 14
               Exit Sub
               End If
               sendData1(1) = &HF
        Case 15
               Exit Sub
               End If
               sendData1(1) = &H10
       End Select
End Sub
Private Sub Form_Load()
    MSComm1.CommPort = 1 '设置串口为com4
    MSComm1.Settings = "9600,n,8,1" '通讯参数 波特率 奇偶校验 数据位 停止位
   ' MSComm1.InputMode = comInputModeBinary '二进制接收
    'MSComm1.PortOpen = True '打开串口
    'MSComm1.InBufferCount = 0 '清空接收缓冲区
    'MSComm1.RThreshold = 1 '缓冲区中接收到一个字符,就产生一次OnComm事件
     MSComm1.OutBufferSize = 1
End Sub
 楼主| 416775364TP 发表于 2011-4-4 14:59 | 显示全部楼层
:'(来个人看下,自己找了很久没找到问题出在哪儿
huangqi412 发表于 2011-4-4 20:58 | 显示全部楼层
额,这个不应该在砍单片机版问吧。。。换个地方问可能就有回答了
coody 发表于 2011-4-5 00:24 | 显示全部楼层
恭喜,发现Windows的BUG了
 楼主| 416775364TP 发表于 2011-4-5 10:08 | 显示全部楼层
:'(搬家到哪儿,如果单个按键的话就不出问题,一组合就出问题,无语ing。
认证:兴储世纪科技股份有限公司+软件工程师
简介:本人从事电源行业10年有余,主要从事过UPS软件开发及维护、车载OBC软件开发、300-3000W高频逆变器软件开发、工频逆控一体机软件开发、便携式交直流电源软件开发.
72
