NXP ARM 代理商
1881|0
 楼主| wangle12 发表于 2011-5-24 17:12 | 显示全部楼层 |阅读模式
NXP, ARM, AN, TI, TE
基于CM0的LPC122x系列已经发布
http://ics.nxp.com/products/lpc1000/lpc12xx/
  • Cortex-M0 core with a 45 CoreMark™ benchmark score at 30MHz
  • 32 to 128KB flash memory with 512B erase sector and 8KB increments
  • 2 to 8KB SRAM with over 50 memory options for flash and SRAM
  • DMA, CRC - supports all peripherals communications
  • Up to 55 GPIOs
  • 4x timers (32-bit and 16-bit)
  • I2C with Fast-mode Plus, SPI, 2x UART (RS-485/IrDA)
  • 10-bit 8-channel ADC
  • 2x analog comparators
  • Windowed watchdog timer and IEC-60730 Class B compliant
  • I/O configurator with programmable glitch filter
  • 1% accuracy, internal 12MHz oscillator
  • 32-bit Real Time Clock (RTC)
  • 2×UARTs
提供开发板    价格170RMB 有需要请联系
021-63547010
steven.hu@moly-tech.com
