- #include <msp430x42x0.h>
- #include <MSP430_IIC.h>
- #include "math.h"
- #include <math.h>
- #include <ymath.h>
- void LCD_CHECK(void);
- void Disp_BCD( unsigned long Value);
- #define a 0x01
- #define b 0x02
- #define c 0x04
- #define d 0x80
- #define e 0x40
- #define f 0x10
- #define g 0x20
- #define PI 3.141592653589793238462643
- const char char_gen[] =
- { // definitions for digits
- a+b+c+d+e+f, // Displays "0"
- b+c, // Displays "1"
- a+b+d+e+g, // Displays "2"
- a+b+c+d+g, // Displays "3"
- b+c+f+g, // Displays "4"
- a+c+d+f+g, // Displays "5"
- a+c+d+e+f+g, // Displays "6"
- a+b+c, // Displays "7"
- a+b+c+d+e+f+g, // Displays "8"
- a+b+c+d+f+g, // Displays "9"
- // 0, // Blank
- // 0, // Blank
- // 0, // Blank
- // 0, // Blank
- // 0, // Blank
- // 0 // Blank
- a+b+f+g, //a
- c+d+e+f+g, //b
- a+d+e+f, //c
- b+c+d+e+g, //d
- a+d+e+f+g, //e
- a+e+f+g, //f
- //主函数部分
- void main(void)
- volatile unsigned int i;
- WDTCTL = WDTPW + WDTHOLD; // Stop WDT
- FLL_CTL0 |= XCAP14PF; // Set load cap for 32k xtal
- // LFXT1 startup delay、
- do
- IFG1 &= ~OFIFG; // Clear OSCFault flag
- for (i = 0x47FF; i > 0; i--); // Time for flag to set
- while (IFG1 & OFIFG); // OSCFault flag still set?
- // Basic Timer
- BTCTL = BT_ADLY_1000; // 1s BT Interrupt
- IE2 |= BTIE; // Enable BT interrupt
- // Ports
- // Ports
- P1OUT = 0; // All P1.x reset
- P1IES = 0xC0; // P1.0, P1.1 中断边缘选择为从高到低。其他为低到高
- P1DIR |=0x3F; // P1.0/1 = input (switches)p1.7 p1.6为输入,其他为输出
- P6OUT = 0; // All P6.x reset
- P6DIR = 0xFF; // All P6.x outputs
- P5SEL = 0x1C; // Set COM pins for LCD
- P1IE |=BIT6+BIT7;
- // LCD_A
- LCDACTL = LCDON + LCD4MUX + LCDFREQ_128; // 4mux LCD, ACLK/128,LCDFREQ_128选择lcd的频率
- LCDAPCTL0 = 0x0F; // Segs S0-S15 = outputs
- LCDAVCTL0 = LCDCPEN; // Enable LCDA charge pump选择内部电荷泵
- LCDAVCTL1 = VLCD_3_26; // to 3.26V
- LCD_CHECK();
- Init_QMC5883();
- // repeat forever
- while (1)
- IFG2 &= ~BTIFG; // Clear pending interrupt,无中断等待
- IE2 |= BTIE;
- // Enable BT interrupt
- // wait for event, hold CPU in low-power mode 3
- __bis_SR_register(LPM3_bits + GIE);//进入低功耗模式3,同时打开通用中断使能位
- __disable_interrupt();
- IE2 &= ~BTIE; // Disable BT interrupt
- // LCD Test Code LCD 测试程序
- void LCD_CHECK()
- int j;
- const unsigned int delay = 10000; // SW delay for LCD stepping
- for( j = 0; j < 7; j ++)
- LCDMEM[j] = 0; // Clear LCD
- for( j = 0; j < 7; j ++) //共0~7个寄存器
- LCDMEM[j] = 0xFF; // All segments on
- for (i = delay; i>0; i--); // Delay
- //***************************十进制数的显示********************************//
- //void Disp_BCD(int Value)
- LCDM1=0x00;
- LCDM2=0x00;
- LCDM3=0x00;
- LCDM4=0x00;
- LCDM5=0x00;
- LCDM6=0x00;
- char *pLCD = (char *)&LCDM1;//指向lcd显示存储区
- int ge = 0;
- while(Value!=0)
- ge=Value%10;
- *pLCD++ = char_gen[ge];
- Value = Value/10;
- void Disp_BCD_X(unsigned long Value)
- int i;
- for (i = 0; i < 6; i++) // Process 7 digits
- *pLCD++ = char_gen[Value & 0x0f]; // Segments to LCD
- Value >>= 4; // Process next digit
- //******************************角度计算********************************//
- #pragma vector=BASICTIMER_VECTOR
- __interrupt void basic_timer(void)
- unsigned int x,y;
- double angle_f;
- unsigned long angle;
- unsigned long temp;
- int temp_x,temp_y,temp_xe,temp_ye;
- double Axis_x,Axis_y;
- double result;
- Init_QMC5883();
- while(1)
- Read_NByte_Randomaddress(inbuffer,6,0x03);
- // Read_NByte_Randomaddress(inbuffer,6,0x00);
- // Read_1Byte_Randomaddress(inbuffer,1,0x12);
- x=(inbuffer[1]<<8)|inbuffer[0];//Combine MSB and LSB of X Data output register
- y=(inbuffer[5]<<8)|inbuffer[4]; //Combine MSB and LSB of Y Data output register
- Disp_BCD_X(y);
- if(x>0xf800) x-=0xf800;
- if(y>0xf800) y-=0xf800;
- // x=0x0000;
- // y=0x0689;
- //angle_f=atan2((double)y,(double)x)*(180/3.14159265)+180;//单位:角度 (0~360)
- temp_x=x&0x8000;
- temp_y=y&0x8000;
- Axis_x=x&0x7fff;//去除符号位
- Axis_y=y&0x7fff;//去除符号位
- //angle_f= atan2( Axis_y,Axis_x)* (180 / PI);
- if( temp_y==0x8000)//y是负数
- if(temp_x==0x8000)//若x是负数
- angle_f= atan2( Axis_y,Axis_x) * (180 /PI)+180;
- else
- angle_f= 360-atan2( Axis_y,Axis_x) * (180 / PI);
- else//y是正数
- if( temp_x==0x8000)//若x是负数
- angle_f= 180-atan2( Axis_y,Axis_x) * (180 / PI);
- else
- angle_f= atan2( Axis_y,Axis_x) * (180 / PI);
- angle=angle_f*1000;
- //Disp_BCD( angle);
- LCDM4|=0x08;
- // Disp_BCD(Axis_y);
- // Disp_BCD(Axis_x);
