初次使用PIC单片机,学习CAN总线,从网上找到这个程序,仿真时程序会停止在 while( TXB0CONbits.TXREQ){;},一直未发送完成,使用的是内部时钟,哪位大神帮忙看看,感激不尽!
- #include <p18cxxx.h>
- // CONFIG1L
- #pragma config RETEN = OFF // VREG Sleep Enable bit (Ultra low-power regulator is Disabled (Controlled by REGSLP bit))
- #pragma config INTOSCSEL = HIGH // LF-INTOSC Low-power Enable bit (LF-INTOSC in High-power mode during Sleep)
- #pragma config SOSCSEL = HIGH // SOSC Power Selection and mode Configuration bits (High Power SOSC circuit selected)
- #pragma config XINST = OFF // Extended Instruction Set (Disabled)
- // CONFIG1H
- #pragma config FOSC = INTIO2 // Oscillator (Internal RC oscillator)
- #pragma config PLLCFG = OFF // PLL x4 Enable bit (Disabled)
- #pragma config FCMEN = OFF // Fail-Safe Clock Monitor (Disabled)
- #pragma config IESO = OFF // Internal External Oscillator Switch Over Mode (Disabled)
- // CONFIG2L
- #pragma config PWRTEN = OFF // Power Up Timer (Disabled)
- #pragma config BOREN = SBORDIS // Brown Out Detect (Enabled in hardware, SBOREN disabled)
- #pragma config BORV = 3 // Brown-out Reset Voltage bits (1.8V)
- #pragma config BORPWR = ZPBORMV // BORMV Power level (ZPBORMV instead of BORMV is selected)
- // CONFIG2H
- #pragma config WDTEN = SWDTDIS // Watchdog Timer (WDT enabled in hardware; SWDTEN bit disabled)
- #pragma config WDTPS = 1048576 // Watchdog Postscaler (1:1048576)
- // CONFIG3H
- #pragma config CANMX = PORTB // ECAN Mux bit (ECAN TX and RX pins are located on RB2 and RB3, respectively)
- #pragma config MSSPMSK = MSK7 // MSSP address masking (7 Bit address masking mode)
- #pragma config MCLRE = ON // Master Clear Enable (MCLR Enabled, RE3 Disabled)
- // CONFIG4L
- #pragma config STVREN = ON // Stack Overflow Reset (Enabled)
- #pragma config BBSIZ = BB2K // Boot Block Size (2K word Boot Block size)
- // CONFIG5L
- #pragma config CP0 = OFF // Code Protect 00800-03FFF (Disabled)
- #pragma config CP1 = OFF // Code Protect 04000-07FFF (Disabled)
- #pragma config CP2 = OFF // Code Protect 08000-0BFFF (Disabled)
- #pragma config CP3 = OFF // Code Protect 0C000-0FFFF (Disabled)
- // CONFIG5H
- #pragma config CPB = OFF // Code Protect Boot (Disabled)
- #pragma config CPD = OFF // Data EE Read Protect (Disabled)
- // CONFIG6L
- #pragma config WRT0 = OFF // Table Write Protect 00800-03FFF (Disabled)
- #pragma config WRT1 = OFF // Table Write Protect 04000-07FFF (Disabled)
- #pragma config WRT2 = OFF // Table Write Protect 08000-0BFFF (Disabled)
- #pragma config WRT3 = OFF // Table Write Protect 0C000-0FFFF (Disabled)
- // CONFIG6H
- #pragma config WRTC = OFF // Config. Write Protect (Disabled)
- #pragma config WRTB = OFF // Table Write Protect Boot (Disabled)
- #pragma config WRTD = OFF // Data EE Write Protect (Disabled)
- // CONFIG7L
- #pragma config EBTR0 = OFF // Table Read Protect 00800-03FFF (Disabled)
- #pragma config EBTR1 = OFF // Table Read Protect 04000-07FFF (Disabled)
- #pragma config EBTR2 = OFF // Table Read Protect 08000-0BFFF (Disabled)
- #pragma config EBTR3 = OFF // Table Read Protect 0C000-0FFFF (Disabled)
- // CONFIG7H
- #pragma config EBTRB = OFF // Table Read Protect Boot (Disabled)
- /**************************************************************************8*/
- int CAN_FLAG;
- //unsigned int CAN_Delay_count=0;
- char CAN_Adress_H,CAN_Adress_L;
- void initcan()
- TRISB=(TRISB|0X08)&0XeB; //设置CANRX/RB3为输入,CANTX/RB2为输出
- //设置CAN的波特率为250K,在Fosc=8M时,Tbit=8us,假设BRP=01h
- //则TQ=[2*(1+BRP)]/Fosc=2*(1+1)/4=1us。
- //NOMINAL BIT RATE=8TQ,SJW=1,Sync_Seg=1TQ,Prog _Seg=1TQ,Phase_Seg1=3TQ,Phase_Seg2=3TQ
- CANCON=0X80; //请求进入CAN配置模式REQOP=100
- while(CANSTAT&0X80==0){;} //等待进入CAN配置模式OPMODE=100
- BRGCON1=0X01; //设置SJW和BRP,SJW=1TQ,BRP=01H
- BRGCON2=0X90; //设置Phase_Seg1=3TQ和Prog _Seg=1TQ
- BRGCON3=0X42; //设置Phase_Seg2=3TQ
- //设置发送邮箱0标识符号和发送的数据
- TXB0CON=0X03; //发送优先级为最高优先级,TXPRI=11
- TXB0SIDH=CAN_Adress_H; //设置发送缓冲器0的标准标识符,本程序采用标准识符
- TXB0SIDL=CAN_Adress_L&0XE0;
- TXB0DLC=0X08; //设置数据长度为8个字节
- TXB0D0=0X00; //写发送缓冲器数据区的数据
- TXB0D1=0X01;
- TXB0D2=0X02;
- TXB0D3=0X03;
- TXB0D4=0X04;
- TXB0D5=0X05;
- TXB0D6=0X06;
- TXB0D7=0X07;
- //设置接收邮箱0的标识符和初始化数据
- RXB0SIDH=CAN_Adress_H; //设置接收缓冲器0的标识符
- RXB0SIDL=CAN_Adress_L&0XE0;
- RXB0CON=0X20; //仅仅接收标准标识符的有效信息,FILHIT0=0表示RXB0采用filter0
- RXB0DLC=0X08; //设置接收缓冲器0的数据区长度
- RXB0D0=0X00; //初始化接收缓冲器0的数据区数据
- RXB0D1=0X00;
- RXB0D2=0X00;
- RXB0D3=0X00;
- RXB0D4=0X00;
- RXB0D5=0X00;
- RXB0D6=0X00;
- RXB0D7=0X00;
- //初始化接收滤波器0和接收屏蔽,
- RXF0SIDH=CAN_Adress_H;
- RXF0SIDL=CAN_Adress_L;
- RXM0SIDH=0XFF;
- RXM0SIDL=0XE0;
- //初始化CAN模块的I/O控制寄存器
- //CIOCON=0X00;
- //CIOCONbits.CLKSEL = 1;
- //使CAN进入某种工作模式模式
- CANCON=0X40; //=0X40,进入自测试模式;=0x00,正常操作模式
- //while(CANSTAT_0&0XE0!=0){;}
- while(CANSTAT&0X40==0){;}
- //初始化CAN的中断
- PIR5=0X00; //清所有中断标志
- PIE5=PIE5|0X01; //使能接收缓冲器0的接收中断
- IPR5=IPR5|0X01; //接收缓冲器0的接收中断为最高优先级
- #pragma interrupt can_isr
- #pragma code high_ISR=0x08
- void high_ISR()
- _asm
- goto can_isr
- _endasm
- #pragma code
- void can_isr()
- CAN_FLAG=1;
- PIR5bits.RXB0IF=0;
- RXB0CONbits.RXFUL=0;
- void delay()
- int i,j;
- for(i=0;i<500;i++)
- for(j=0;j<100;j++)
- void main()
- CAN_Adress_H=0X33;
- CAN_Adress_L=0XE0;
- INTCON=0x00; //禁止所有中断
- CAN_FLAG=0;
- initcan();
- RCONbits.IPEN=1;
- WDTCON=0; //=1,看门狗使能;=0,禁止看门狗
- INTCON=INTCON|0xc0; //使能中断
- while(1)
- if(CAN_FLAG==1)
- CAN_FLAG=0; //清接收到标志
- TXB0CONbits.TXREQ=0; //禁止发送
- TXB0D0=RXB0D0+1; //用接收数据加1来更新发送数据
- TXB0D1=RXB0D1+1;
- TXB0D2=RXB0D2+1;
- TXB0D3=RXB0D3+1;
- TXB0D4=RXB0D4+1;
- TXB0D5=RXB0D5+1;
- TXB0D6=RXB0D6+1;
- TXB0D7=RXB0D7+1;
- else
- TXB0CON=TXB0CON|0X08;
- while( TXB0CONbits.TXREQ){;} //等待发送完成
- // while(!TXB0IF) {;}
- //PORTB&=0xEF;
