步进机问题
1320|4
 楼主| learnc51 发表于 2017-11-17 10:44 | 显示全部楼层 |阅读模式
#include <reg52.h>
#define DataPort P0
sbit LATCH1=P2^2;
sbit LATCH2=P2^3;
unsigned char code dofly_DuanMa[10]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f};
unsigned char code dofly_WeiMa[]={0xfe,0xfd,0xfb,0xf7,0xef,0xdf,0xbf,0x7f};
unsigned char TempData[8];
sbit A1=P1^0;
sbit B1=P1^1;
sbit C1=P1^2;
sbit D1=P1^3;
#define Coil_AB1 {A1=1;B1=1;C1=0;D1=0;}
#define Coil_BC1 {A1=0;B1=1;C1=1;D1=0;}
#define Coil_CD1 {A1=0;B1=0;C1=1;D1=1;}
#define Coil_DA1 {A1=1;B1=0;C1=0;D1=1;}
#define Coil_A1 {A1=1;B1=0;C1=0;D1=0;}
#define Coil_B1 {A1=0;B1=1;C1=0;D1=0;}
#define Coil_C1 {A1=0;B1=0;C1=1;D1=0;}
#define Coil_D1 {A1=0;B1=0;C1=0;D1=1;}
#define Coil_OFF {A1=0;B1=0;C1=0;D1=0;}
unsigned char Speed;
void Display(unsigned char FirstBit,unsigned char Num);
void Init_Timer0(void);
void DelayUs2x(unsigned char t)
while(--t);
void DelayMs(unsigned char t)
while(t--)
     DelayUs2x(245);
         DelayUs2x(245);
void main()
unsigned int i=512;
Init_Timer0();
EA=1;
EX0=1;
IT0=1;
Speed=3;
TempData[0]=dofly_DuanMa[Speed/10];
TempData[1]=dofly_DuanMa[Speed%10];
Coil_OFF;
while(i--)
  {  Coil_A1
     DelayMs(Speed);
     Coil_AB1
     DelayMs(Speed);
         Coil_B1
     DelayMs(Speed);
         Coil_BC1
     DelayMs(Speed);
         Coil_C1
     DelayMs(Speed);
     Coil_CD1
     DelayMs(Speed);
         Coil_D1
     DelayMs(Speed);
     Coil_DA1
     DelayMs(Speed);
void ISR_INT0(void) interrupt 0
if(!INT0)
   DelayMs(10);
   if(!INT0)
     Speed++;
         if(Speed==20)
           Speed=3;
      static unsigned char i=0;
           DataPort=0;
       LATCH1=1;
       LATCH1=0;
       DataPort=dofly_WeiMa[i+FirstBit];
       LATCH2=1;
       LATCH2=0;
       DataPort=TempData[i];
       LATCH1=1;
       LATCH1=0;
           i++;
       if(i==Num)
              i=0;
TMOD |= 0x01;
EA=1;
ET0=1;
TR0=1;
PT0=1;
void Timer0_isr(void) interrupt 1
TH0=(65536-2000)/256;
TL0=(65536-2000)%256;
Display(0,8);
每次按键调整Speed大小后过一段时间步进机就自动复位初始Speed,这是哪里出错了吗
dirtwillfly 发表于 2017-11-17 14:19 | 显示全部楼层
建议画一下程序的控制流图,并且补充注释
gujiamao12345 发表于 2017-11-17 15:55 | 显示全部楼层
问题是啥?
cjseng 发表于 2017-11-18 12:51 | 显示全部楼层
主程序没有死循环
bearlinux 发表于 2017-11-27 17:54 | 显示全部楼层
应该是定时器中断里出了问题。
