LPC1778-EVB KEIL linking errors
1465|0
 楼主| shun88 发表于 2017-12-13 14:56 | 显示全部楼层 |阅读模式
linking...
..\Output\070Inch-AFM-NoStr.axf: Warning: L6170W: Mapping symbol #33 '$t' in .bss(GUIAA_Lib_d5.o:7) identifies code, but is in a section not marked as executable.
..\Output\070Inch-AFM-NoStr.axf: Warning: L6170W: Mapping symbol #31 '$t' in .bss(GUI_Timer_d5.o:7) identifies code, but is in a section not marked as executable.
..\Output\070Inch-AFM-NoStr.axf: Warning: L6170W: Mapping symbol #7 '$t' in .bss(GUI__ManageCache_d5.o:7) identifies code, but is in a section not marked as executable.
..\Output\070Inch-AFM-NoStr.axf: Warning: L6170W: Mapping symbol #19 '$t' in .bss(GUI_Curs1_d5.o:8) identifies code, but is in a section not marked as executable.
..\Output\070Inch-AFM-NoStr.axf: Warning: L6170W: Mapping symbol #89 '$t' in .bss(GUI_SetAlpha_d5.o:7) identifies code, but is in a section not marked as executable.
..\Output\070Inch-AFM-NoStr.axf: Warning: L6170W: Mapping symbol #19 '$t' in .bss(GUI__Alpha_d5.o:7) identifies code, but is in a section not marked as executable.
..\Output\070Inch-AFM-NoStr.axf: Error: L6405E: No .ANY selector matches GUI_SetAlpha_d5.o(.bss).
..\Output\070Inch-AFM-NoStr.axf: Error: L6405E: No .ANY selector matches GUI__ManageCache_d5.o(.bss).
..\Output\070Inch-AFM-NoStr.axf: Error: L6405E: No .ANY selector matches GUIAA_Lib_d5.o(.bss).
..\Output\070Inch-AFM-NoStr.axf: Error: L6405E: No .ANY selector matches GUI__Alpha_d5.o(.bss).
..\Output\070Inch-AFM-NoStr.axf: Error: L6405E: No .ANY selector matches GUI_Timer_d5.o(.bss).
..\Output\070Inch-AFM-NoStr.axf: Error: L6405E: No .ANY selector matches GUI_Curs1_d5.o(.bss).
Not enough information to list image symbols.
Not enough information to list the image map.
Finished: 2 information, 6 warning and 6 error messages.
