请教各位大侠:MSP430F4250读写存储器问题
757|0
 楼主| 稳流源 发表于 2018-2-8 11:29 | 显示全部楼层 |阅读模式
MSP430一个内部信息存储器读写一直不成功,调试时总是停在读取数据的中间,不知道原因在哪?附上程序请教各位,不胜感激!
#define SegmentStart 0x01000  //Segment = 0x01000~0x010FF
#define SegmentSize 255 //SegmentA + SegmentB = 256
void WriteSegment_256 (char index,char *value,char size);
char ReadSegment_256(char index);
void main(void)
  volatile unsigned int i;
  WDTCTL = WDTPW + WDTHOLD;                 // Stop WDT
  FLL_CTL0 |= XCAP14PF;                     // Configure load caps
  for (i = 0; i < 10000; i++);              // Delay for 32 kHz crystal to
  SD16CTL = SD16REFON+SD16SSEL0;            // 1.2V ref, SMCLK
  SD16CCTL0 |= SD16SNGL + SD16DF;                    // Single conv
  //SD16CCTL0 |= SD16SNGL;                    // Single conv
   SD16INCTL0 |= SD16INCH0+SD16INTDLY_0;
while (1)
   value=ReadSegment_256(1);
     for (i = 0; i < 0x900; i++);             // Delay
    char str1[3]={0xAA,0xBB,0xCC};
   WriteSegment_256(0,str1,3);
  for(char i=0;i<255;i++)
    _NOP();
// char str2[3]={0xBB,0xAA,0xCC};
// WriteSegment_256(0,str2,3);
//读取片内存储的数据
  char *flash_ptr = ((char *) SegmentStart) + index;
  return *flash_ptr;
//把数组写入数据到片内FLASH,必须先全部擦除再写入
//参数index:保存数组的位置
//参数value:数组的指针
//参数size:数组的大小
  char buffer[SegmentSize],i=0;
  char *flash_ptr = (char *) SegmentStart;
  //先读取原FLASH数组
  for(i=0;i<SegmentSize;i++)
    buffer[i]=ReadSegment_256(i);
  //擦除FLASH,必须
  FCTL1 = FWKEY + ERASE;                    // Set Erase bit
  FCTL3 = FWKEY;                            // Clear Lock bit
  *flash_ptr = 0;                           // Dummy write to erase Flash segment
  //把整个数组都写入FLASH
  FCTL1 = FWKEY + WRT;                      // Set WRT bit for write operation
  for(i=0;i<size;i++)//修改原数组
    buffer[index+i]=value[i];
  for(i=0; i<SegmentSize; i++)//写入数据到FLASH
    *(flash_ptr++) = buffer[i];
  FCTL1 = FWKEY;                            // Clear WRT bit
  FCTL3 = FWKEY + LOCK;                     // Set LOCK bit
