- * [url=home.php?mod=space&uid=288409]@file[/url] main.c
- * [url=home.php?mod=space&uid=895143]@version[/url] V3.00
- * $Revision: 2 $
- * $Date: 14/12/25 10:24a $
- * [url=home.php?mod=space&uid=247401]@brief[/url] Show how to read/program embedded flash by ISP function.
- * @note
- * Copyright (C) 2014 Nuvoton Technology Corp. All rights reserved.
- #include <stdio.h>
- #include "M0518.h"
- #define PLLCON_SETTING CLK_PLLCON_50MHz_HXT
- #define PLL_CLOCK 50000000
- #define APROM_TEST_BASE 0x3000
- #define APROM_TEST_END 0xF000
- #define DATA_FLASH_TEST_BASE 0xF000
- #define DATA_FLASH_TEST_END 0x11000
- #define TEST_PATTERN 0x5A5A5A5A
- #define CONFIG0_DFEN 0x01
- #define CONFIG0_DFVSEN 0x04
- void SYS_Init(void)
- /* Init System Clock */
- /* Enable Internal RC 22.1184MHz clock */
- CLK_EnableXtalRC(CLK_PWRCON_OSC22M_EN_Msk);
- /* Waiting for Internal RC clock ready */
- CLK_WaitClockReady(CLK_CLKSTATUS_OSC22M_STB_Msk);
- /* Switch HCLK clock source to Internal RC and HCLK source divide 1 */
- CLK_SetHCLK(CLK_CLKSEL0_HCLK_S_HIRC, CLK_CLKDIV_HCLK(1));
- /* Enable external XTAL 12MHz clock */
- CLK_EnableXtalRC(CLK_PWRCON_XTL12M_EN_Msk);
- /* Waiting for external XTAL clock ready */
- CLK_WaitClockReady(CLK_CLKSTATUS_XTL12M_STB_Msk);
- /* Set core clock as PLL_CLOCK from PLL */
- CLK_SetCoreClock(PLL_CLOCK);
- /* Enable UART module clock */
- CLK_EnableModuleClock(UART0_MODULE);
- /* Select UART module clock source */
- CLK_SetModuleClock(UART0_MODULE, CLK_CLKSEL1_UART_S_HXT, CLK_CLKDIV_UART(1));
- /* Init I/O Multi-function */
- /* Set GPB multi-function pins for UART0 RXD and TXD */
- SYS->GPB_MFP = SYS_GPB_MFP_PB0_UART0_RXD | SYS_GPB_MFP_PB1_UART0_TXD;
- void UART_Init()
- /* Init UART */
- UART_Open(UART0, 115200);
- static int SetDataFlashBase(uint32_t u32DFBA)
- uint32_t au32Config[2];
- /* Read current User Configuration */
- FMC_ReadConfig(au32Config, 1);
- /* Just return when Data Flash has been enabled */
- if(!(au32Config[0] & 0x1))
- return 0;
- /* Enable User Configuration Update */
- FMC_EnableConfigUpdate();
- /* Erase User Configuration */
- FMC_Erase(FMC_CONFIG_BASE);
- /* Write User Configuration to Enable Data Flash */
- /* Note: DFVSEN = 1, DATA Flash Size is 4K bytes
- DFVSEN = 0, DATA Flash Size is based on CONFIG1 */
- au32Config[0] &= ~(CONFIG0_DFEN | CONFIG0_DFVSEN);
- au32Config[1] = u32DFBA;
- if(FMC_WriteConfig(au32Config, 2))
- return -1;
- printf("\nSet Data Flash base as 0x%x.\n", FMC_ReadDataFlashBaseAddr());
- /* Perform chip reset to make new User Config take effect */
- SYS->IPRSTC1 |= SYS_IPRSTC1_CHIP_RST_Msk;
- return 0;
- int32_t FillDataPattern(uint32_t u32StartAddr, uint32_t u32EndAddr, uint32_t u32Pattern)
- uint32_t u32Addr;
- for(u32Addr = u32StartAddr; u32Addr < u32EndAddr; u32Addr += 4)
- FMC_Write(u32Addr, u32Pattern);
- return 0;
- int32_t VerifyData(uint32_t u32StartAddr, uint32_t u32EndAddr, uint32_t u32Pattern)
- uint32_t u32Addr;
- uint32_t u32Data;
- u32Data = FMC_Read(u32Addr);
- if(u32Data != u32Pattern)
- printf("\nFMC_Read data verify failed at address 0x%x, read=0x%x, expect=0x%x\n", u32Addr, u32Data, u32Pattern);
- return -1;
- return 0;
- int32_t FlashTest(uint32_t u32StartAddr, uint32_t u32EndAddr, uint32_t u32Pattern)
- uint32_t u32Addr;
- for(u32Addr = u32StartAddr; u32Addr < u32EndAddr; u32Addr += FMC_FLASH_PAGE_SIZE)
- printf(" Flash test address: 0x%x \r", u32Addr);
- // Erase page
- FMC_Erase(u32Addr);
- // Verify if page contents are all 0xFFFFFFFF
- if(VerifyData(u32Addr, u32Addr + FMC_FLASH_PAGE_SIZE, 0xFFFFFFFF) < 0)
- printf("\nPage 0x%x erase verify failed!\n", u32Addr);
- return -1;
- // Write test pattern to fill the whole page
- if(FillDataPattern(u32Addr, u32Addr + FMC_FLASH_PAGE_SIZE, u32Pattern) < 0)
- printf("Failed to write page 0x%x!\n", u32Addr);
- return -1;
- // Verify if page contents are all equal to test pattern
- if(VerifyData(u32Addr, u32Addr + FMC_FLASH_PAGE_SIZE, u32Pattern) < 0)
- printf("\nData verify failed!\n ");
- return -1;
- return -1;
- printf("\r Flash Test Passed. \n");
- return 0;
- int main()
- uint32_t i, u32Data;
- /* Unlock protected registers */
- SYS_UnlockReg();
- SYS_Init();
- UART_Init();
- This sample code is used to show how to use StdDriver API to implement ISP functions.
- printf("\n\n");
- printf("+----------------------------------------+\n");
- printf("| M0518 FMC Sample Code |\n");
- //SYS_UnlockReg();
- /* Enable FMC ISP function */
- FMC_Open();
- if(SetDataFlashBase(DATA_FLASH_TEST_BASE) < 0)
- printf("Failed to set Data Flash base address!\n");
- goto lexit;
- /* Read BS */
- printf(" Boot Mode ............................. ");
- if(FMC_GetBootSource() == 0)
- printf("[APROM]\n");
- else
- printf("[LDROM]\n");
- printf(" WARNING: The driver sample code must execute in AP mode!\n");
- goto lexit;
- u32Data = FMC_ReadCID();
- printf(" Company ID ............................ [0x%08x]\n", u32Data);
- u32Data = FMC_ReadDID();
- printf(" Device ID ............................. [0x%08x]\n", u32Data);
- u32Data = FMC_ReadPID();
- printf(" Product ID ............................ [0x%08x]\n", u32Data);
- for(i = 0; i < 3; i++)
- u32Data = FMC_ReadUID(i);
- printf(" Unique ID %d ........................... [0x%08x]\n", i, u32Data);
- for(i = 0; i < 4; i++)
- u32Data = FMC_ReadUCID(i);
- printf(" Unique Customer ID %d .................. [0x%08x]\n", i, u32Data);
- /* Read User Configuration */
- printf(" User Config 0 ......................... [0x%08x]\n", FMC_Read(FMC_CONFIG_BASE));
- printf(" User Config 1 ......................... [0x%08x]\n", FMC_Read(FMC_CONFIG_BASE + 4));
- /* Read Data Flash base address */
- u32Data = FMC_ReadDataFlashBaseAddr();
- printf(" Data Flash Base Address ............... [0x%08x]\n", u32Data);
- printf("\n\nLDROM test =>\n");
- FMC_EnableLDUpdate();
- if(FlashTest(FMC_LDROM_BASE, FMC_LDROM_BASE + FMC_LDROM_SIZE, TEST_PATTERN) < 0)
- printf("\n\nLDROM test failed!\n");
- goto lexit;
- FMC_DisableLDUpdate();
- printf("\n\nAPROM test =>\n");
- FMC_EnableAPUpdate();
- if(FlashTest(APROM_TEST_BASE, APROM_TEST_END, TEST_PATTERN) < 0)
- printf("\n\nAPROM test failed!\n");
- goto lexit;
- FMC_DisableAPUpdate();
- printf("\n\nData Flash test =>\n");
- if(FlashTest(DATA_FLASH_TEST_BASE, DATA_FLASH_TEST_END, TEST_PATTERN) < 0)
- printf("\n\nUHB test failed!\n");
- goto lexit;
- lexit:
- /* Disable FMC ISP function */
- FMC_Close();
- /* Lock protected registers */
- SYS_LockReg();
- printf("\nFMC Sample Code Completed.\n");
- while(1);
- /*** (C) COPYRIGHT 2014 Nuvoton Technology Corp. ***/
