Link Error:#208
3320|3
 楼主| 楼亮亮 发表于 2007-11-23 21:38 | 显示全部楼层 |阅读模式
link, TE, se, ST, ni
&nbsp;&nbsp;&nbsp;各位高手,我在有仿真器调试程序时老是出现以下提示&nbsp;情各位高手相助<br /><br />MedWin&nbsp;v2.39&nbsp;Translating&nbsp;F:单片机大三上i2ciczhu2.c......pass&nbsp;!<br />MedWin&nbsp;V2.39&nbsp;Linking......<br />&nbsp;&nbsp;&nbsp;&nbsp;BL51&nbsp;BANKED&nbsp;LINKER/LOCATER&nbsp;V5.03&nbsp;-&nbsp;SN:&nbsp;Eval&nbsp;Version<br />&nbsp;&nbsp;&nbsp;&nbsp;COPYRIGHT&nbsp;KEIL&nbsp;ELEKTRONIK&nbsp;GmbH&nbsp;1987&nbsp;-&nbsp;2002<br />&nbsp;&nbsp;&nbsp;&nbsp;zhu2.obj&nbsp;TO&nbsp;test.Omf&nbsp;RAMSIZE(128)&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;***&nbsp;WARNING&nbsp;L16:&nbsp;UNCALLED&nbsp;SEGMENT,&nbsp;IGNORED&nbsp;FOR&nbsp;OVERLAY&nbsp;PROCESS<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;SEGMENT:&nbsp;?PR?CHUSHI?ZHU2<br />&nbsp;&nbsp;&nbsp;&nbsp;******************************************************************************<br />&nbsp;&nbsp;&nbsp;&nbsp;*&nbsp;RESTRICTED&nbsp;VERSION&nbsp;WITH&nbsp;0800H&nbsp;BYTE&nbsp;CODE&nbsp;SIZE&nbsp;LIMIT;&nbsp;USED:&nbsp;11DCH&nbsp;BYTE&nbsp;(223%)&nbsp;*<br />&nbsp;&nbsp;&nbsp;&nbsp;******************************************************************************<br />&nbsp;&nbsp;&nbsp;&nbsp;Program&nbsp;Size:&nbsp;data=32.0&nbsp;xdata=0&nbsp;code=4581<br />&nbsp;&nbsp;&nbsp;&nbsp;LINK/LOCATE&nbsp;RUN&nbsp;COMPLETE.&nbsp;&nbsp;1&nbsp;WARNING(S),&nbsp;&nbsp;0&nbsp;ERROR(S)<br />&nbsp;&nbsp;&nbsp;&nbsp;***&nbsp;WARNING&nbsp;L16:&nbsp;UNCALLED&nbsp;SEGMENT,&nbsp;IGNORED&nbsp;FOR&nbsp;OVERLAY&nbsp;PROCESS<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;SEGMENT:&nbsp;?PR?CHUSHI?ZHU2<br />&nbsp;&nbsp;&nbsp;&nbsp;***&nbsp;FATAL&nbsp;ERROR&nbsp;L250:&nbsp;CODE&nbsp;SIZE&nbsp;LIMIT&nbsp;IN&nbsp;RESTRICTED&nbsp;VERSION&nbsp;EXCEEDED<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;MODULE:&nbsp;&nbsp;C:KEILC51LIBC51S.LIB&nbsp;(-----)<br />&nbsp;&nbsp;&nbsp;&nbsp;Link&nbsp;Error:#208<br />Project[test]:&nbsp;Link&nbsp;failure&nbsp;!<br />
ahong007 发表于 2007-11-24 11:27 | 显示全部楼层
是不是路径出现中文字符?
 楼主| 楼亮亮 发表于 2007-11-24 12:29 | 显示全部楼层
还是同样的问题
谢谢哦,我修改了一下路径,但是还是这种情况,前几天都是好好的,就这两天不行的了,请各位高手来指点一下
高勇 发表于 2007-11-24 12:47 | 显示全部楼层
看看
看看你选的器件,是否被修改。
