STC12系列单片机的串口2的使用
1284|0
 楼主| dzzpec 发表于 2018-6-7 20:40 | 显示全部楼层 |阅读模式
为什么,我用STC12系列单片机的串口2不能进行正常通行
#include <STC12C5A60S2.h>
#include "SerialPort.h"
void SendData2(unsigned char dat);
void SendStr2(char *str);
void main(void)
        unsigned int i;
        UartInit2();
        UartInit();
        while(1)
                SendStr2("dxsl");
                for(i=0; i<20000; i++);
void UartIsr(void) interrupt 4
        unsigned char receiveData;
        receiveData = SBUF;                                         //³öÈ¥½ÓÊÕµ½µÄÊý¾Ý
        RI = 0;                                                   //Çå³ý½ÓÊÕÖжϱê־λ
        SendData(receiveData);
void UartIsr2(void) interrupt 8
        S2CON &= ~S2RI;
        receiveData = S2BUF;
        SendData2(receiveData);
下面是SerialPort.c文件
void UartInit(void)
//¾§ÕñƵÂÊΪ12MHz£¬Ñ¡¶¨´®¿Ú²¨ÌØÂÊΪ4800bps£¬ÔòSMODÖ»ÄÜΪ1£¬×°ÔسõֵΪ0xf3
        SCON = 0x50;
        PCON = 0x80;        //²¨ÌØÂʼӱ¶
        TMOD |= 0x20;
//        TH1 = TL1 = 0xf4;
        TH1 = TL1 = 0xfd;                                                        //Éè¶¨ÖØÔØÖµ0xf3    //-(FOSC/12/32/BAUD);
        TR1 =1;        //¶¨Ê±Æ÷ 1 ´ò¿ª
        ES = 1;        //´®¿ÚÖжϴò¿ª
        EA = 1;
void SendData(unsigned char dat)
        SBUF = dat;
        while(!TI);
        TI = 0;
void SendStr(char *str)
        while(*str)
                SendData(*str++);
void UartInit2(void)
        S2CON = 0x50;                                                //°Ëλ¹¤×÷ģʽһ
        BRT = 0xfd;                                                        //¶ÀÁ¢²¨ÌØÂÊ
        AUXR |= 0x10;                                                //²¨ÌØÂʼӱ¶£¬ BRT´ò¿ª
        IE2 = 0x01;                                                        //ÔÊÐí´®¿Ú2ÖжÏES2=1
        EA = 1;
        S2BUF = dat;
        while(!(S2CON & S2TI));
        S2CON &= ~S2TI;
        while(*str)
                SendData2(*str++);
