[DemoCode下载] M451的DSP内核FFT应用
1469|4
 楼主| yiyigirl2014 发表于 2018-6-28 15:18 | 显示全部楼层 |阅读模式
  1. /****************************************************************************
  2. * [url=home.php?mod=space&uid=288409]@file[/url]     main.c
  3. * [url=home.php?mod=space&uid=895143]@version[/url]  V1.0
  4. * $Date: 16/09/22 10:04a $
  5. * @brief
  6. *         Display how to use DSP FFT function
  7. *
  8. * @note
  9. * Copyright (C) 2016 Nuvoton Technology Corp. All rights reserved.
  10. *
  11. ******************************************************************************/
  12. #include <stdio.h>
  13. #include "M451Series.h"
  14. #include "arm_math.h"
  15. #define TEST_LENGTH_SAMPLES 2048 //Must be fftsize*2
  16. /* -------------------------------------------------------------------
  17. * External Input and Output buffer Declarations for FFT Bin Example
  18. * ------------------------------------------------------------------- */
  19. extern float32_t testInput_f32_10khz[TEST_LENGTH_SAMPLES];
  20. static float32_t testOutput[TEST_LENGTH_SAMPLES/2];
  21. /* ------------------------------------------------------------------
  22. * Global variables for FFT Bin Example
  23. * ------------------------------------------------------------------- */
  24. uint32_t fftSize = 1024;
  25. uint32_t ifftFlag = 0;
  26. uint32_t doBitReverse = 1;
  27. /* Reference index at which max energy of bin ocuurs */
  28. uint32_t refIndex = 213, testIndex = 0;
  29. arm_cfft_radix4_instance_f32 S;
  30. float32_t maxValue,Mainfreq;
  31. int CalTime;
  32. void SYS_Init(void)
  33. {
  34.            /*---------------------------------------------------------------------------------------------------------*/
  35.     /* Init System Clock        */
  36.     /*---------------------------------------------------------------------------------------------------------*/
  37.     /* Enable HIRC clock */
  38.     CLK_EnableXtalRC(CLK_PWRCTL_HIRCEN_Msk);
  39.     /* Waiting for HIRC clock ready */
  40.     CLK_WaitClockReady(CLK_STATUS_HIRCSTB_Msk);
  41.     /* Switch HCLK clock source to HIRC */
  42.     CLK_SetHCLK(CLK_CLKSEL0_HCLKSEL_HIRC, CLK_CLKDIV0_HCLK(1));
  43.     /* Enable HXT */
  44.     CLK_EnableXtalRC(CLK_PWRCTL_HXTEN_Msk);
  45.     /* Waiting for clock ready */
  46.     CLK_WaitClockReady(CLK_STATUS_HXTSTB_Msk);
  47.     /* Set core clock as PLL_CLOCK from PLL and SysTick source to HCLK/2*/
  48.     CLK_SetCoreClock(72000000);
  49.     CLK_SetSysTickClockSrc(CLK_CLKSEL0_STCLKSEL_HCLK_DIV2);
  50.     /* Enable peripheral clock */
  51.     CLK_EnableModuleClock(UART0_MODULE);
  52.     CLK_EnableModuleClock(TMR0_MODULE);
  53.     /* Peripheral clock source */
  54.     CLK_SetModuleClock(UART0_MODULE, CLK_CLKSEL1_TMR0SEL_HXT, CLK_CLKDIV0_UART(1));
  55.     CLK_SetModuleClock(TMR0_MODULE, CLK_CLKSEL1_TMR0SEL_HXT, 0);
  56. }
  57. void UART_Init(void)
  58. {
  59.     /* Set PD multi-function pins for UART0 RXD and TXD */
  60.     SYS->GPD_MFPL = SYS_GPD_MFPL_PD0MFP_UART0_RXD | SYS_GPD_MFPL_PD1MFP_UART0_TXD;
  61.     /* Reset UART module */
  62.     SYS_ResetModule(UART0_RST);
  63.     /* Configure UART0 and set UART0 Baudrate */
  64.     UART_Open(UART0, 115200);
  65. }
  66. /*---------------------------------------------------------------------------------------------------------*/
  67. /*  Main Function        */
  68. /*---------------------------------------------------------------------------------------------------------*/
  69. int32_t main(void)
  70. {
  71.         /* Unlock protected registers */
  72.     SYS_UnlockReg();
  73.     /* Init System, peripheral clock and multi-function I/O */
  74.     SYS_Init();
  75.     /* Lock protected registers */
  76.     SYS_LockReg();
  77.     /* Init UART for printf */
  78.     UART_Init();
  79.                 /* Measure FFT calcultion time */
  80.                 TIMER_Open(TIMER0, TIMER_CONTINUOUS_MODE, 1);
  81.                 TIMER_Start(TIMER0);
  82.
  83.                 /* Initialize the CFFT/CIFFT module */
  84.                 arm_cfft_radix4_init_f32(&S, fftSize,ifftFlag, doBitReverse);
  85.
  86.                 /* Process the data through the CFFT/CIFFT module */
  87.                 arm_cfft_radix4_f32(&S, testInput_f32_10khz);
  88.                 TIMER_Close(TIMER0);
  89.                 /* Process the data through the Complex Magnitude Module for calculating the magnitude at each bin */
  90.                 arm_cmplx_mag_f32(testInput_f32_10khz, testOutput,fftSize/2);
  91.                 /* Calculates maxValue and returns corresponding BIN value */
  92.                 arm_max_f32(testOutput, fftSize/2, &maxValue, &testIndex);
  93.                 CalTime=TIMER_GetCounter(TIMER0);
  94.                 /* Mainfreq=testindex*sample rate/fftsize */
  95.                 Mainfreq=testIndex*5000/fftSize;
  96.
  97.                 printf("Main frequency is %f\n",Mainfreq);
  98.                 printf("time is %d \n",CalTime);
  99.
  100.     while(1);
  101.
  102. }
 楼主| yiyigirl2014 发表于 2018-6-28 15:21 | 显示全部楼层
EC_M451_DSP_FFT_V1.0.zip (4.43 MB, 下载次数: 20)
Puremr 发表于 2018-6-28 16:37 | 显示全部楼层
M451不是ARM的内核吗?怎么变成DSP的内核了?
Puremr 发表于 2018-6-28 16:38 | 显示全部楼层
新唐NuMicro® M451基础系列是基于ARM® Cortex®-M4内核的新一代32位的微控制器,宽工作电压(2.5V ~ 5.5V),工业级温度(-40℃ ~ 105℃),内置22.1184MHz晶振(在25℃,5V时精度1%),可配置Data Flash,强抗干扰性(ESD 8KV、EFT 4KV),封装类型有LQFP48、LQFP64和LQFP100。
这不是DSP的内核吧。
zhuotuzi 发表于 2018-6-28 18:36 | 显示全部楼层
新唐NuMicro® M451基础系列是基于ARM® Cortex®-M4内核的新一代32位的微控制器,宽工作电压(2.5V ~ 5.5V) ...
含有浮点运算单元和DSP的
ARM® Cortex™-M4內核
    - 最高可运行至72 MHz
