[应用方案] NV32F100 控制74HC595 ,数码管显示
1190|1
 楼主| tang87633187 发表于 2018-7-27 10:53 | 显示全部楼层 |阅读模式
void delay( int t )
{    int k,j;
            for(k=0;k<t;k++)
       for(j=0;j<1000;j++)
void SCLK(char i)
{  if(i==1)
            GPIO_PinSet(GPIO_PTC0);
          else
            GPIO_PinClear(GPIO_PTC0);
        void RCLK(char i)
{  if(i==1)
            GPIO_PinSet(GPIO_PTC1);
          else
            GPIO_PinClear(GPIO_PTC1);
        void DIO(char i)
{  if(i==1)
            GPIO_PinSet(GPIO_PTD5);
          else
            GPIO_PinClear(GPIO_PTD5);
         void H595_Conver( int data)
        { char t;
                  RCLK(0);
                for(t=0;t<16;t++)
                {  if((data&0x8000)==0x8000)
                            DIO(1);
                          else
                                        DIO(0);
                           SCLK(1);
                                  data=data<<1;
                           SCLK(0);
                  RCLK(1);
char led[10]={ 0x3F,0x06,0x5B,0x4F,0x66,0x6D,0x7D,0x07,0x7F,0x6F};
int main (void);
void RTC_Task(void);
* Global functions
int main (void)
{ char temp;
        char i;
        int j,k;
    /*ϵͳ³õʼ*/
    sysinit();
    cpu_identify();
    RTC_ConfigType  sRTCConfig;
    RTC_ConfigType  *pRTCConfig = &sRTCConfig;
    printf("\nRunning the GPIO_demo project.\n");
    /*ÅäÖÃRTCµÄÖÐ¶ÏÆµÂÊΪ1Hz*/
    pRTCConfig->u16ModuloValue = 9;
    pRTCConfig->bInterruptEn   = RTC_INTERRUPT_ENABLE;     /*ʹÄÜÖжÏ*/
    pRTCConfig->bClockSource   = RTC_CLKSRC_1KHZ;          /*ʱÖÓԴƵÂÊΪ1khz*/
    pRTCConfig->bClockPresaler = RTC_CLK_PRESCALER_100;    /*·ÖƵϵÊýΪ100*/
    RTC_SetCallback(RTC_Task);
    RTC_Init(pRTCConfig);
                 GPIO_PinInit(GPIO_PTC0, GPIO_PinOutput);
                 GPIO_PinInit(GPIO_PTC1, GPIO_PinOutput);
                 GPIO_PinInit(GPIO_PTD5, GPIO_PinOutput);
         while(1)
                for(i=0;i<8;i++)
                 {  H595_Conver( ((0xff-led)<<8)|(0x01<<(7-i)));
       delay(2);
xujunyi3611 发表于 2018-8-26 17:29 | 显示全部楼层
为什么有很多乱码呢?奇怪
