[DemoCode下载] N76E003时钟切换
1486|4
 楼主| 643757107 发表于 2018-7-31 16:59 | 显示全部楼层 |阅读模式
  1. /*---------------------------------------------------------------------------------------------------------*/
  2. /*        */
  3. /* Copyright(c) 2017 Nuvoton Technology Corp. All rights reserved.                                         */
  4. /*        */
  5. /*---------------------------------------------------------------------------------------------------------*/
  6. //***********************************************************************************************************
  7. //  Nuvoton Technoledge Corp.
  8. //  Website: http://www.nuvoton.com
  9. //  E-Mail : MicroC-8bit@nuvoton.com
  10. //  Date   : Apr/21/2017
  11. //***********************************************************************************************************
  12. //***********************************************************************************************************
  13. //  File Function: N76E003 System clock select demo code
  14. //***********************************************************************************************************
  15. #include "N76E003.h"
  16. #include "SFR_Macro.h"
  17. #include "Function_define.h"
  18. #include "Common.h"
  19. #include "Delay.h"
  20. //========================================================================
  21. //  The test process:
  22. //        1. Power on is run as default HIRC, show LED Fsys tickle faster
  23. //         2. toggle P3.0 to GND.
  24. //        2. call modify Fsys code to LIRC.
  25. //        3. LED tickle speed slowly than before.
  26. //========================================================================
  27. void main(void)
  28. {
  29. /* Note
  30.   MCU power on system clock is HIRC (16 MHz)
  31.         Please keep P3.0 HIGH before you want to modify Fsys to LIRC
  32. */
  33.
  34.           Set_All_GPIO_Quasi_Mode;                           // In Common.h define
  35.     set_CLOEN;        // Also can check P1.1 CLO pin for clock to find the Fsys change.
  36.                 set_P30;
  37.                 while (P30)        // when P3.0 keep high, clock out HIRC
  38.                 {
  39.                                 clr_GPIO1;        // Check LED output tickle time
  40.         Timer0_Delay1ms(200);
  41.         set_GPIO1;
  42.         Timer0_Delay1ms(200);
  43.                 }
  44.
  45. ////------------------------------------------------------------------------------------------------------
  46. ///*********************************** Change system closk source ***************************************/
  47. ////------------------------------------------------------------------------------------------------------
  48.
  49. ////***** HIRC enable part *****
  50. //                set_HIRCEN;        //step1: enable HIRC clock source run
  51. //                while((CKSWT&SET_BIT5)==0);                                //step2: check ready
  52. //                clr_OSC1;        //step3: switching system clock source if needed
  53. //                clr_OSC0;
  54. //                while((CKEN&SET_BIT0)==1);                                //step4: check system clock switching OK or NG
  55. //
  56. ////***** LIRC enable part*****
  57. ////** Since LIRC is always enable, switch to LIRC directly
  58.                 set_OSC1;        //step3: switching system clock source if needed
  59.                 clr_OSC0;
  60.                 while((CKEN&SET_BIT0)==1);                                //step4: check system clock switching OK or NG
  61.                 clr_HIRCEN;
  62.
  63. ////--------------------------------------------------------------------------------------------------------
  64.
  65. /*
  66.   Now Fsys = LIRC , LED tickle slowly.
  67. */
  68.     while(1)
  69.     {
  70.                                 clr_GPIO1;        // Check LED output tickle time
  71.         clr_P00;
  72.         set_GPIO1;
  73.         set_P00;
  74.     }
  75. /* =================== */
  76. }
从默认的时钟切换到低频时钟。
mintspring 发表于 2018-7-31 19:01 | 显示全部楼层
切换后功耗是不是更低。
玛尼玛尼哄 发表于 2018-7-31 19:17 | 显示全部楼层
不同时钟用处不同。
yiy 发表于 2018-7-31 20:04 | 显示全部楼层
没有板子啊。等我做刚
