[开发工具] 初学PIC单片机,这种是烧写成功了么
2276|4
 楼主| bjy1991 发表于 2018-8-2 18:04 | 显示全部楼层 |阅读模式
Connecting to MPLAB PICkit 4...
Currently loaded versions:
Application version............00.02.01
FPGA version...................ff.ff.ff
Script version.................00.02.23
Script build number............45a591cbc0
Application build number.......0123456789
PICKit 4 is supplying power to the target (3.30 volts).
Target Device ID (0x6180) is an Invalid Device ID. Please check your connections to the Target Device.
Erasing...
The following memory area(s) will be programmed:
program memory: start address = 0x0, end address = 0x3f
program memory: start address = 0x7fc0, end address = 0x7fff
configuration memory
Programming/Verify complete
Target Device ID (0x6180) is an Invalid Device ID. Please check your connections to the Target Device. 这个问题怎么解决
df_flying 发表于 2018-8-3 16:40 | 显示全部楼层
烧写OK了, 下面的提示选对LF 和F 就不用管,提示你别将LF(3.3)的芯片 选成了F(5)的。
gouzj 发表于 2018-10-20 22:50 | 显示全部楼层
烧写OK了
Cjy_JDxy 发表于 2018-11-3 15:05 | 显示全部楼层
Target Device ID (0x6180) is an Invalid Device ID. Please check your connections to the Target Devic ...
看看是不是接触不好,或者断电重插
