[STM32F4] (转)STM32F4的IO设置测试
882|2
 楼主| renzheshengui 发表于 2018-8-16 09:35 | 显示全部楼层 |阅读模式
本文博客链接:http://blog.csdn.net/jdh99,作者:jdh,转载请注明.
环境:
主机:WIN7
开发环境:MDK4.72
MCU:STM32F407VGT6
说明:
目标板上有一个LED,有一个按键,按键实现LED状态翻转.
LED:PE2,低电平亮,高电平灯灭
按键:PC13,低电平按下,高电平松开
源代码:
main.c
  • *                                                          主文件
  • *                                                (c)copyright 2014,jdh
  • *                                                  All Right Reserved
  • *新建日期:2014/3/25 by jdh
  • *                                                        头文件
  • #include "main.h"
  • #include "stm32f4xx_rcc.h"
  • #include "stm32f4xx_gpio.h"
  • *                                                        全局变量
  • static __IO uint32_t TimingDelay;
  • *                                                        函数定义
  • void Delay(__IO uint32_t nTime);
  • *                                                        函数
  • int main(void)
  •     //定义IO初始化结构体
  •         GPIO_InitTypeDef GPIO_InitStructure;
  •     //系统时钟:1ms滴答1次
  •     if (SysTick_Config(SystemCoreClock / 1000))
  •         while (1);
  •     //设置LED的IO口
  •     //初始化时钟
  •     RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOE, ENABLE);
  •     //管脚模式:输出口
  •     GPIO_InitStructure.GPIO_Mode = GPIO_Mode_OUT;
  •     //类型:推挽模式
  •         GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
  •     //上拉下拉设置:不使能
  •         GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL;
  •     //IO口速度
  •         GPIO_InitStructure.GPIO_Speed = GPIO_Speed_100MHz;
  •     //管脚指定
  •         GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2;
  •     //初始化
  •         GPIO_Init(GPIOE, &GPIO_InitStructure);
  •     //设置按键的IO口
  •     //初始化时钟
  •     RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOC, ENABLE);
  •     //管脚模式:输出口
  •     GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN;
  •     //类型:推挽模式
  •     //上拉下拉设置:不使能
  •     //IO口速度
  •     //管脚指定
  •         GPIO_InitStructure.GPIO_Pin = GPIO_Pin_13;
  •     //初始化
  •         GPIO_Init(GPIOC, &GPIO_InitStructure);
  •     while (1)
  •         //GPIO_SetBits(GPIOE,GPIO_Pin_2);
  •         //Delay(500);
  •         //GPIO_ResetBits(GPIOE,GPIO_Pin_2);
  •         //Delay(500);
  •         //按键检测
  •         if (GPIO_ReadInputDataBit(GPIOC,GPIO_Pin_13) == 0)
  •             GPIO_ToggleBits(GPIOE,GPIO_Pin_2);
  •             Delay(500);
  •   * @brief  Inserts a delay time.
  •   * @param  nTime: specifies the delay time length, in milliseconds.
  •   * @retval None
  •   TimingDelay = nTime;
  •   while(TimingDelay != 0);
  •   * @brief  Decrements the TimingDelay variable.
  •   * @param  None
  •   * @retval None
  • void TimingDelay_Decrement(void)
  •   if (TimingDelay != 0x00)
  •     TimingDelay--;
  • #ifdef  USE_FULL_ASSERT
  •   * @brief  Reports the name of the source file and the source line number
  •   *         where the assert_param error has occurred.
  •   * @param  file: pointer to the source file name
  •   * @param  line: assert_param error line source number
  •   * @retval None
  • void assert_failed(uint8_t* file, uint32_t line)
  •   /* User can add his own implementation to report the file name and line number,
  •      ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
  •   /* Infinite loop */
  •   while (1)
  • #endif
  • /******************* (C) COPYRIGHT 2011 STMicroelectronics *****END OF FILE****/
wakayi 发表于 2018-8-16 09:49 | 显示全部楼层
非常简单有效的小程序
 楼主| renzheshengui 发表于 2018-8-17 09:24 | 显示全部楼层
非常简单有效的小程序
非常感谢夸奖
