- DCM_SP
- VHDL
- Library UNISIM;
- use UNISIM.vcomponents.all;
- -- DCM_SP: Digital Clock Manager Circuit
- -- Spartan-3A
- DCM_SP_inst : DCM_SP
- generic map (
- CLKDV_DIVIDE => 2.0, -- Divide by: 1.5,2.0,2.5,3.0,3.5,4.0,4.5,5.0,5.5,6.0,6.5
- -- 7.0,7.5,8.0,9.0,10.0,11.0,12.0,13.0,14.0,15.0 or 16.0
- CLKFX_DIVIDE => 1, -- Can be any interger from 1 to 32
- CLKFX_MULTIPLY => 4, -- Can be any integer from 1 to 32
- CLKIN_DIVIDE_BY_2 => FALSE, -- TRUE/FALSE to enable CLKIN divide by two feature
- CLKIN_PERIOD => 0.0, -- Specify period of input clock
- CLKOUT_PHASE_SHIFT => "NONE", -- Specify phase shift of "NONE", "FIXED" or "VARIABLE"
- CLK_FEEDBACK => "1X", -- Specify clock feedback of "NONE", "1X" or "2X"
- DESKEW_ADJUST => "SYSTEM_SYNCHRONOUS", -- "SOURCE_SYNCHRONOUS", "SYSTEM_SYNCHRONOUS" or
- -- an integer from 0 to 15
- DLL_FREQUENCY_MODE => "LOW", -- "HIGH" or "LOW" frequency mode for DLL
- DUTY_CYCLE_CORRECTION => TRUE, -- Duty cycle correction, TRUE or FALSE
- PHASE_SHIFT => 0, -- Amount of fixed phase shift from -255 to 255
- STARTUP_WAIT => FALSE) -- Delay configuration DONE until DCM_SP LOCK, TRUE/FALSE
- port map (
- CLK0 => CLK0, -- 0 degree DCM CLK ouptput
- CLK180 => CLK180, -- 180 degree DCM CLK output
- CLK270 => CLK270, -- 270 degree DCM CLK output
- CLK2X => CLK2X, -- 2X DCM CLK output
- CLK2X180 => CLK2X180, -- 2X, 180 degree DCM CLK out
- CLK90 => CLK90, -- 90 degree DCM CLK output
- CLKDV => CLKDV, -- Divided DCM CLK out (CLKDV_DIVIDE)
- CLKFX => CLKFX, -- DCM CLK synthesis out (M/D)
- CLKFX180 => CLKFX180, -- 180 degree CLK synthesis out
- LOCKED => LOCKED, -- DCM LOCK status output
- PSDONE => PSDONE, -- Dynamic phase adjust done output
- STATUS => STATUS, -- 8-bit DCM status bits output
- CLKFB => CLKFB, -- DCM clock feedback
- CLKIN => CLKIN, -- Clock input (from IBUFG, BUFG or DCM)
- PSCLK => PSCLK, -- Dynamic phase adjust clock input
- PSEN => PSEN, -- Dynamic phase adjust enable input
- PSINCDEC => PSINCDEC, -- Dynamic phase adjust increment/decrement
- RST => RST -- DCM asynchronous reset input
- -- End of DCM_SP_inst instantiation
- // DCM_SP: Digital Clock Manager Circuit
- // Spartan-3A
- DCM_SP #(
- .CLKDV_DIVIDE(2.0), // Divide by: 1.5,2.0,2.5,3.0,3.5,4.0,4.5,5.0,5.5,6.0,6.5
- // 7.0,7.5,8.0,9.0,10.0,11.0,12.0,13.0,14.0,15.0 or 16.0
- .CLKFX_DIVIDE(1), // Can be any integer from 1 to 32
- .CLKFX_MULTIPLY(4), // Can be any integer from 2 to 32
- .CLKIN_DIVIDE_BY_2("FALSE"), // TRUE/FALSE to enable CLKIN divide by two feature
- .CLKIN_PERIOD(0.0), // Specify period of input clock
- .CLKOUT_PHASE_SHIFT("NONE"), // Specify phase shift of NONE, FIXED or VARIABLE
- .CLK_FEEDBACK("1X"), // Specify clock feedback of NONE, 1X or 2X
- .DESKEW_ADJUST("SYSTEM_SYNCHRONOUS"), // SOURCE_SYNCHRONOUS, SYSTEM_SYNCHRONOUS or
- // an integer from 0 to 15
- .DLL_FREQUENCY_MODE("LOW"), // HIGH or LOW frequency mode for DLL
- .DUTY_CYCLE_CORRECTION("TRUE"), // Duty cycle correction, TRUE or FALSE
- .PHASE_SHIFT(0), // Amount of fixed phase shift from -255 to 255
- .STARTUP_WAIT("FALSE") // Delay configuration DONE until DCM LOCK, TRUE/FALSE
- ) DCM_SP_inst (
- .CLK0(CLK0), // 0 degree DCM CLK output
- .CLK180(CLK180), // 180 degree DCM CLK output
- .CLK270(CLK270), // 270 degree DCM CLK output
- .CLK2X(CLK2X), // 2X DCM CLK output
- .CLK2X180(CLK2X180), // 2X, 180 degree DCM CLK out
- .CLK90(CLK90), // 90 degree DCM CLK output
- .CLKDV(CLKDV), // Divided DCM CLK out (CLKDV_DIVIDE)
- .CLKFX(CLKFX), // DCM CLK synthesis out (M/D)
- .CLKFX180(CLKFX180), // 180 degree CLK synthesis out
- .LOCKED(LOCKED), // DCM LOCK status output
- .PSDONE(PSDONE), // Dynamic phase adjust done output
- .STATUS(STATUS), // 8-bit DCM status bits output
- .CLKFB(CLKFB), // DCM clock feedback
- .CLKIN(CLKIN), // Clock input (from IBUFG, BUFG or DCM)
- .PSCLK(PSCLK), // Dynamic phase adjust clock input
- .PSEN(PSEN), // Dynamic phase adjust enable input
- .PSINCDEC(PSINCDEC), // Dynamic phase adjust increment/decrement
- .RST(RST) // DCM asynchronous reset input
- // End of DCM_SP_inst instantiation
