- * [url=home.php?mod=space&uid=288409]@file[/url] main.c
- * [url=home.php?mod=space&uid=895143]@version[/url] 2.0.0
- * [url=home.php?mod=space&uid=247401]@brief[/url] Use MKROM API to do internal ISP. This sample code is run at APROM,
- * this sample will load an image to LDROM, and than doing Secure boot
- * ISP to update APROM. After finish firmware update, remember to reset
- * the system.
- * The LDROM sample code is Secure boot ISP function.
- * [url=home.php?mod=space&uid=17282]@CopyRight[/url] (C) 2017 Nuvoton Technology Corp. All rights reserved.
- #include <stdio.h>
- #include "NuMicro.h"
- typedef void (FUNC_PTR)(void);
- extern uint32_t loaderImage1Base, loaderImage1Limit; /* symbol of image start and end */
- void SYS_Init(void)
- /* Unlock protected registers */
- SYS_UnlockReg();
- /* Set XT1_OUT(PF.2) and XT1_IN(PF.3) to input mode */
- PF->MODE &= ~(GPIO_MODE_MODE2_Msk | GPIO_MODE_MODE3_Msk);
- /* Enable External XTAL (4~24 MHz) */
- CLK_EnableXtalRC(CLK_PWRCTL_HXTEN_Msk);
- /* Waiting for 12MHz clock ready */
- CLK_WaitClockReady(CLK_STATUS_HXTSTB_Msk);
- /* Switch HCLK clock source to HXT */
- CLK_SetHCLK(CLK_CLKSEL0_HCLKSEL_HXT,CLK_CLKDIV0_HCLK(1));
- /* Set core clock as PLL_CLOCK from PLL */
- CLK_SetCoreClock(FREQ_192MHZ);
- /* Set both PCLK0 and PCLK1 as HCLK/2 */
- CLK->PCLKDIV = CLK_PCLKDIV_PCLK0DIV2 | CLK_PCLKDIV_PCLK1DIV2;
- /* Select IP clock source */
- CLK_SetModuleClock(UART0_MODULE, CLK_CLKSEL1_UART0SEL_HXT, CLK_CLKDIV0_UART0(1));
- /* Enable IP clock */
- CLK_EnableModuleClock(UART0_MODULE);
- /* Set GPB multi-function pins for UART0 RXD and TXD */
- SYS->GPB_MFPH &= ~(SYS_GPB_MFPH_PB12MFP_Msk | SYS_GPB_MFPH_PB13MFP_Msk);
- SYS->GPB_MFPH |= (SYS_GPB_MFPH_PB12MFP_UART0_RXD | SYS_GPB_MFPH_PB13MFP_UART0_TXD);
- * @brief Check User Configuration CONFIG0 bit 6 IAP boot setting. If it's not boot with IAP
- * mode, modify it and execute a chip reset to make it take effect.
- * [url=home.php?mod=space&uid=266161]@return[/url] Is boot with IAP mode or not.
- * @retval 0 Success.
- * @retval -1 Failed on reading or programming User Configuration.
- static int set_IAP_boot_mode(void)
- uint32_t au32Config[2]; /* User Configuration */
- if (FMC_ReadConfig(au32Config, 2) < 0) /* Read User Configuration CONFIG0 and CONFIG1. */
- printf("\nRead User Config failed!\n");
- return -1; /* Failed on reading User Configuration */
- if (au32Config[0] & 0x40) /* Check if it's boot from APROM/LDROM with IAP. */
- FMC_ENABLE_CFG_UPDATE(); /* Enable User Configuration update. */
- au32Config[0] &= ~0x40; /* Select IAP boot mode. */
- FMC_WriteConfig(au32Config, 2);/* Update User Configuration CONFIG0 and CONFIG1. */
- SYS->IPRST0 = SYS_IPRST0_CHIPRST_Msk; /* Perform chip reset to make new User Config take effect. */
- return 0; /* success */
- * @brief Load an image to specified flash address. The flash area must have been enabled by
- * caller. For example, if caller want to program an image to LDROM, FMC_ENABLE_LD_UPDATE()
- * must be called prior to calling this function.
- * @return Image is successfully programmed or not.
- * @retval -1 Program/verify failed.
- static int load_image_to_flash(uint32_t image_base, uint32_t image_limit, uint32_t flash_addr, uint32_t max_size)
- uint32_t i, j, u32Data, u32ImageSize, *pu32Loader;
- u32ImageSize = max_size; /* Give the maximum size of programmable flash area. */
- printf("Program image to flash address 0x%x...", flash_addr); /* information message */
- * program the whole image to specified flash area
- pu32Loader = (uint32_t *)image_base;
- for (i = 0; i < u32ImageSize; i += FMC_FLASH_PAGE_SIZE)
- FMC_Erase(flash_addr + i); /* erase a flash page */
- for (j = 0; j < FMC_FLASH_PAGE_SIZE; j += 4) /* program image to this flash page */
- FMC_Write(flash_addr + i + j, pu32Loader[(i + j) / 4]);
- printf("OK.\nVerify ...");
- /* Verify loader */
- u32Data = FMC_Read(flash_addr + i + j); /* read a word from flash memory */
- if (u32Data != pu32Loader[(i+j)/4]) /* check if the word read from flash be matched with original image */
- printf("data mismatch on 0x%x, [0x%x], [0x%x]\n", flash_addr + i + j, u32Data, pu32Loader[(i+j)/4]);
- return -1; /* image program failed */
- if (i + j >= u32ImageSize) /* check if it reach the end of image */
- break;
- printf("OK.\n");
- int32_t main (void)
- FUNC_PTR *func; /* function pointer */
- SYS_Init();
- UART_Open(UART0, 115200);
- printf("\n");
- printf("+-----------------------------------------+\n");
- printf("| M480 update firmware by HSUSBD |\n");
- SYS_UnlockReg(); /* Unlock register lock protect */
- FMC_Open(); /* Enable FMC ISP function */
- * Check if User Configuration CBS is boot with IAP mode.
- * If not, modify it.
- if (set_IAP_boot_mode() < 0)
- printf("Failed to set IAP boot mode!\n");
- FMC_Close(); /* Disable FMC ISP function */
- while(1);
- FMC_ENABLE_LD_UPDATE(); /* Enable LDROM update capability */
- * The binary image of LDROM code is embedded in this sample.
- * load_image_to_flash() will program this LDROM code to LDROM.
- if (load_image_to_flash((uint32_t)&loaderImage1Base, (uint32_t)&loaderImage1Limit, FMC_LDROM_BASE, FMC_LDROM_SIZE) != 0)
- printf("Load image to LDROM failed!\n");
- while(1);
- FMC_DISABLE_LD_UPDATE(); /* Disable LDROM update capability */
- printf("\n\nChange VECMAP and branch to LDROM...\n");
- printf("\nAfter update the firmware, please press the reset button...\n");
- while (!(UART0->FIFOSTS & UART_FIFOSTS_TXEMPTY_Msk)); /* Wait for UART3 TX FIFO cleared */
- /* NOTE!
- * Before change VECMAP, user MUST disable all interrupts.
- * The following code CANNOT locate in address 0x0 ~ 0x200.
- /* FMC_SetVectorPageAddr(FMC_LDROM_BASE) */
- FMC->ISPCMD = FMC_ISPCMD_VECMAP; /* ISP command */
- FMC->ISPADDR = FMC_LDROM_BASE; /* Vector remap address */
- FMC->ISPTRG = FMC_ISPTRG_ISPGO_Msk; /* Trigger ISP command */
- while (FMC->ISPTRG & FMC_ISPTRG_ISPGO_Msk) ; /* Wait for ISP command done. */
- * The reset handler address of an executable image is located at offset 0x4.
- * Thus, this sample get reset handler address of LDROM code from FMC_LDROM_BASE + 0x4.
- func = (FUNC_PTR *)*(uint32_t *)(FMC_LDROM_BASE + 4);
- * Branch to the LDROM code's reset handler in way of function call.
- func();
- while(1);
- /*** (C) COPYRIGHT 2017 Nuvoton Technology Corp. ***/
