[NUC120] nuc120开发板学习之定时器中断方式实现每秒输出数字加1
4052|4
 楼主| mtxmxt 发表于 2011-8-16 10:56 | 显示全部楼层 |阅读模式
上次用软件延时实现了LED灯的渐亮渐暗,用软件延时的实际用处不大,故开始定时器的学习。准备实现利用定时器中断方式实现每秒输出数字加1。
 楼主| mtxmxt 发表于 2011-8-16 10:59 | 显示全部楼层
上传定时器的学习笔记
 楼主| mtxmxt 发表于 2011-8-16 11:01 | 显示全部楼层
程序源码
/* Copyright(c) 2009 Nuvoton Technology Corp. All rights reserved.                                         */
#include <stdio.h>
/*  Include hear file        */
#include "NUC1xx.h"
#include "DrvGPIO.h"
  Define variable
        static uint32_t TimerCOUN=0;
  Function subroutine
void Delay(uint32_t delayCnt)
    while(delayCnt--)
        __NOP();
        __NOP();
uint32_t GetTDR(void)
        return         TIMER0->TDR;
  Interrupt subroutine
void TMR0_IRQHandler(void) // Timer0 interrupt subroutine
        TIMER0->TISR.TIF =1;
        TimerCOUN++;
  MAIN function
int32_t main (void)
        uint32_t TEMP=0;
        /* SYSCLK =>12Mhz*/
        UNLOCKREG();
    SYSCLK->PWRCON.XTL12M_EN = 1;
        LOCKREG();
        /*set GPI0 output*/
        DrvGPIO_Open(E_GPA,2, E_IO_OUTPUT);
        DrvGPIO_Open(E_GPA,3, E_IO_OUTPUT);
        DrvGPIO_Open(E_GPA,4, E_IO_OUTPUT);
        DrvGPIO_Open(E_GPA,5, E_IO_OUTPUT);
        NVIC_DisableIRQ(TMR0_IRQn);        //Disable Timer0 interrupt
        outpw(&TIMER0->TCSR ,0 );        //Disable Timer0
        /* Step 1. Enable and Select Timer clock source */
        SYSCLK->CLKSEL1.TMR0_S = 7;        //Select 22Mhz for Timer0 clock source
    SYSCLK->APBCLK.TMR0_EN =1;        //Enable Timer0 clock source
        /* Step 2. Select Operation mode */
        TIMER0->TCSR.MODE=1;                //Select periodic mode for operation mode
        /* Step 3. Select Time out period = (Period of timer clock input) * (8-bit Prescale + 1) * (24-bit TCMP)*/
        TIMER0->TCSR.PRESCALE=0;        // Set Prescale [0~255]
        TIMER0->TCMPR = 2765;                // Set TCMPR [0~16777215]
        // (1/22118400)*(0+1)*(2765)= 125.01usec or 7999.42Hz
        /* Step 4. Enable interrupt */
        TIMER0->TCSR.IE = 1;
        TIMER0->TISR.TIF = 1;                //Write 1 to clear for safty
        NVIC_EnableIRQ(TMR0_IRQn);        //Enable Timer0 Interrupt
        /* Step 5. Enable Timer module */
        TIMER0->TCSR.CRST = 1;                //Reset up counter
        TIMER0->TCSR.CEN = 1;                //Enable Timer0
          TIMER0->TCSR.TDR_EN=1;                // Enable TDR function
        while(1)
                        if (TimerCOUN>8000)         //Wait 1 seconds
                                TEMP++;
                                 TimerCOUN=0;
                        DrvGPIO_SetPortBits(E_GPA, ~(TEMP<<2));
 楼主| mtxmxt 发表于 2011-8-16 11:02 | 显示全部楼层
上传工程文件
lixiaoxu2meng 发表于 2011-8-16 11:03 | 显示全部楼层
顶一个
