[M0] TM16 AUTO STOP
641|0
 楼主| 344864311 发表于 2018-10-16 15:29 | 显示全部楼层 |阅读模式
top, pi, ni, se
定时器 可编程计数器 自动停止模式功能。
#include "MG32x02z__Common_DRV.H"
#include "MG32x02z_DRV.H"
void ChipInit(void);
#define Simple_CKO_Period           12000
#define Simple_CKO_Number           1000
void Sample_TM16_AutoStop(void)
    TM_TimeBaseInitTypeDef TM_TimeBase_InitStruct;
    //===Set CSC init====
    //MG32x02z_CSC_Init.h(Configuration Wizard)
    //Select CK_HS source = CK_IHRCO
    //Select IHRCO = 12M
    //Select CK_MAIN Source = CK_HS
    //Configure PLL->Select APB Prescaler = CK_MAIN/1
    //Configure Peripheral On Mode Clock->TM16 = Enable
    //Configure Peripheral On Mode Clock->Port B = Enable
    //==Set GPIO init
    //TM16_CKO pin config:
    //MG32x02z_GPIO_Init.h(Configuration Wizard)->Use GPIOB->PB2
    //GPIO port initial is 0xFFFF
    //PB2 mode is PPO
    //PB2 function TM16_CKO
    TM_TimeBaseStruct_Init(&TM_TimeBase_InitStruct);
    TM_TimeBase_InitStruct.TM_Period = Simple_CKO_Number - 1;
    TM_TimeBase_InitStruct.TM_Prescaler = Simple_CKO_Period - 1;
    TM_TimeBase_InitStruct.TM_CounterMode = Cascade;
    TM_TimeBase_Init(TM16, &TM_TimeBase_InitStruct);
    TM_ClearFlag(TM16, TMx_TOF);
    TM_ClockOutSource_Select(TM16, PrescalerCKO);
    TM_ClockOut_Cmd(TM16, ENABLE);
    TM_CKOOutputState_Init(TM16, CLR);
    TM_AutoStop_Cmd(TM16, ENABLE);
    TM_Timer_Cmd(TM16, ENABLE);
    return;
void Sample_GPIO_RWInit(void)
                                uint16_t  ReadData;
                                PIN_InitTypeDef PINX_InitStruct;
                                //Select CK_HS source = CK_IHRCO ÄÚ²¿Ê±ÖÓ
                                //Select IHRCO = 11.0592M
                                //Configure Peripheral On Mode Clock->Port A = Enable
                                //===GPIO Port Initial====
                                PINX_InitStruct.PINX_Mode                                  = PINX_Mode_OpenDrain_O;            //Ñ¡ÔñIOģʽ        //     1.QB: Quasi-Bidirection mode only for PC )
                                PINX_InitStruct.PINX_PUResistant        = PINX_PUResistant_Enable;          //ÄÚ²¿ÉÏÀ­
                                PINX_InitStruct.PINX_Speed              = PINX_Speed_Low;                   //ÉèÖÃËÙ¶È
                                PINX_InitStruct.PINX_OUTDrive           = PINX_OUTDrive_Level0;             //Êä³öÄÜÁ¦ÉèÖà
                                PINX_InitStruct.PINX_FilterDivider      = PINX_FilterDivider_Bypass;        //Ñ¡ÔñÊäÈëµÄÂ˲¨·ÖƵÆ÷
                                PINX_InitStruct.PINX_Inverse            = PINX_Inverse_Disable;             //ÊäÈëÐźÅÊÇ·ñ·´×ª
                                PINX_InitStruct.PINX_Alternate_Function = 5;                                //cko
                                GPIO_PinMode_Config(PINB(2),&PINX_InitStruct);                              //PA0 ÅäÖà
int main()
    ChipInit();
          Sample_GPIO_RWInit();
    Sample_TM16_AutoStop();
    while(1)
