二楼附个代码
- #include "MG32x02z_DRV.H"
- #include "MG32x02z_ADC_DRV.h"
- #include "MG32x02z_PW_DRV.h"
- #include <stdio.h>
- typedef uint8_t u8;
- typedef uint16_t u16;
- typedef uint32_t u32;
- typedef uint64_t u64;
- void CSC_Init (void)
- CSC_PLL_TyprDef CSC_PLL_CFG;
- UnProtectModuleReg(MEMprotect); // Setting flash wait state
- MEM_SetFlashWaitState(MEM_FWAIT_ONE); // 50MHz> Sysclk >=25MHz
- ProtectModuleReg(MEMprotect);
- UnProtectModuleReg(CSCprotect);
- CSC_CK_APB_Divider_Select(APB_DIV_1); // Modify CK_APB divider APB=CK_MAIN/1
- CSC_CK_AHB_Divider_Select(AHB_DIV_1); // Modify CK_AHB divider AHB=APB/1
- /* CK_HS selection */
- CSC_IHRCO_Select(IHRCO_12MHz); // IHRCO Sel 12MHz
- CSC_IHRCO_Cmd(ENABLE);
- while(CSC_GetSingleFlagStatus(CSC_IHRCOF) == DRV_Normal);
- CSC_ClearFlag(CSC_IHRCOF);
- CSC_CK_HS_Select(HS_CK_IHRCO); // CK_HS select IHRCO
- /* PLL */
- CSC_PLL_CFG.InputDivider=PLLI_DIV_2; // 12M/2=6M
- CSC_PLL_CFG.Multiplication=PLLIx16; // 6M*16=96M
- CSC_PLL_CFG.OutputDivider=PLLO_DIV_2; // PLLO=96M/2=48M
- CSC_PLL_Config(&CSC_PLL_CFG);
- CSC_PLL_Cmd(ENABLE);
- while(CSC_GetSingleFlagStatus(CSC_PLLF) == DRV_Normal);
- CSC_ClearFlag(CSC_PLLF);
- /* CK_MAIN */
- CSC_CK_MAIN_Select(MAIN_CK_HS);
- /* Configure ICKO function */
- /* Configure peripheral clock */
- CSC_PeriphOnModeClock_Config(CSC_ON_PortE,ENABLE);
- ProtectModuleReg(CSCprotect);
- int main()
- int i,j;
- double x,y;
- PIN_InitTypeDef PINX_InitStruct;
- CSC_Init();
- PINX_InitStruct.PINX_Mode = PINX_Mode_PushPull_O; // Pin select digital input mode
- PINX_InitStruct.PINX_PUResistant = PINX_PUResistant_Enable; // Enable pull up resistor
- PINX_InitStruct.PINX_Speed = PINX_Speed_Low;
- PINX_InitStruct.PINX_OUTDrive = PINX_OUTDrive_Level0; // Pin output driver full strength.
- PINX_InitStruct.PINX_FilterDivider = PINX_FilterDivider_Bypass;// Pin input deglitch filter clock divider bypass
- PINX_InitStruct.PINX_Inverse = PINX_Inverse_Disable; // Pin input data not inverse
- PINX_InitStruct.PINX_Alternate_Function = 0; // Pin AFS = 0
- GPIO_PinMode_Config(PINE(15),&PINX_InitStruct); // D6 setup at PE15
- i=0;
- j=0;
- while(1)
- i++;
- if(i>=500000){
- i=0;
- PE15=~PE15;
- j++;
- if(j>10)
- PE15=1;
- SCB->SCR = (SCB_SCR_SLEEPDEEP_Msk); //into stop
- __WFI(); //This is the command of cmsis_arm.cc. __WFI();is wait for interrupt while __WFE();is wait for event();
- j=0;
