- * [url=home.php?mod=space&uid=288409]@file[/url] main.c
- * [url=home.php?mod=space&uid=895143]@version[/url] V1.00
- * $Revision: 2 $
- * $Date: 15/04/13 10:05a $
- * [url=home.php?mod=space&uid=247401]@brief[/url] Implement CRC in CRC-8 mode and get the CRC checksum result.
- * @note
- * Copyright (C) 2011 Nuvoton Technology Corp. All rights reserved.
- #include <stdio.h>
- #include <string.h>
- #include "NUC100Series.h"
- #define PLL_CLOCK 50000000
- void SYS_Init(void)
- /* Init System Clock */
- /* Enable Internal RC 22.1184MHz clock */
- CLK_EnableXtalRC(CLK_PWRCON_OSC22M_EN_Msk);
- /* Waiting for Internal RC clock ready */
- CLK_WaitClockReady(CLK_CLKSTATUS_OSC22M_STB_Msk);
- /* Switch HCLK clock source to Internal RC and HCLK source divide 1 */
- CLK_SetHCLK(CLK_CLKSEL0_HCLK_S_HIRC, CLK_CLKDIV_HCLK(1));
- /* Enable external XTAL 12MHz clock */
- CLK_EnableXtalRC(CLK_PWRCON_XTL12M_EN_Msk);
- /* Waiting for clock ready */
- CLK_WaitClockReady(CLK_CLKSTATUS_XTL12M_STB_Msk);
- /* Set core clock as PLL_CLOCK from PLL */
- CLK_SetCoreClock(PLL_CLOCK);
- /* Enable UART module clock */
- CLK_EnableModuleClock(UART0_MODULE);
- /* Select UART module clock source */
- CLK_SetModuleClock(UART0_MODULE, CLK_CLKSEL1_UART_S_HXT, CLK_CLKDIV_UART(1));
- /* Enable PDMA module clock for CRC operation */
- CLK_EnableModuleClock(PDMA_MODULE);
- /* Init I/O Multi-function */
- /* Set PB multi-function pins for UART0 RXD, TXD */
- SYS->GPB_MFP = SYS_GPB_MFP_PB0_UART0_RXD | SYS_GPB_MFP_PB1_UART0_TXD;
- void UART0_Init(void)
- /* Init UART */
- /* Reset UART0 */
- SYS_ResetModule(UART0_RST);
- /* Configure UART0 and set UART0 Baudrate */
- UART_Open(UART0, 115200);
- /* MAIN function */
- int main(void)
- const uint8_t acCRCSrcPattern[] = "123456789";
- uint32_t i, u32TargetChecksum = 0x58, u32CalChecksum = 0;
- uint8_t *p8SrcAddr;
- /* Unlock protected registers */
- SYS_UnlockReg();
- /* Init System, peripheral clock and multi-function I/O */
- SYS_Init();
- /* Lock protected registers */
- SYS_LockReg();
- /* Init UART0 for printf */
- UART0_Init();
- printf("\n\nCPU [url=home.php?mod=space&uid=72445]@[/url] %dHz\n", SystemCoreClock);
- printf("+---------------------------------+\n");
- printf("| CRC CRC-8 Mode Sample Code |\n");
- printf("+---------------------------------+\n\n");
- printf("# Calculate string "123456789" CRC-8 checksum value by CRC CPU mode.\n");
- printf(" - Seed value is 0x5A \n");
- printf(" - CPU Write Length is 8-bit \n");
- printf(" - Checksum Complement disable \n");
- printf(" - Checksum Reverse disable \n");
- printf(" - Write Data Complement disable \n");
- printf(" - Write Data Reverse disable \n");
- printf(" - Checksum should be 0x%X \n\n", u32TargetChecksum);
- /* Set CRC source buffer address for CRC-8 CPU mode */
- p8SrcAddr = (uint8_t *)acCRCSrcPattern;
- /* Configure CRC operation settings for CRC-8 CPU mode */
- CRC_Open(CRC_8, 0, 0x5A, CRC_CPU_WDATA_8);
- /* Start to execute CRC-8 CPU operation */
- for(i = 0; i < strlen((char *)acCRCSrcPattern); i++)
- CRC_WRITE_DATA((p8SrcAddr[i] & 0xFF));
- /* Get CRC-8 checksum value */
- u32CalChecksum = CRC_GetChecksum();
- printf("CRC checksum is 0x%X ... %s.\n", u32CalChecksum, (u32CalChecksum == u32TargetChecksum) ? "PASS" : "FAIL");
- /* Disable CRC function */
- CRC->CTL &= ~CRC_CTL_CRCCEN_Msk;
- while(1);
- /*** (C) COPYRIGHT 2013 Nuvoton Technology Corp. ***/
