[PIC®/AVR®/dsPIC®产品] dspic33fj128gp706 关于IO控制
1632|2
 楼主| jxwhf2007 发表于 2018-11-11 17:13 | 显示全部楼层 |阅读模式
dspic33fj128gp706,RB0,RB1,RB2,RB3,端口会相互影响,对RB3单独控制无效,附上代码,请大神帮忙看下。
#include<p33Fxxxx.h>
//#include<p33fj128gp706a.h>
// DSPIC33FJ128GP706 Configuration Bit Settings
// 'C' source line config statements
// FBS
#pragma config BWRP = WRPROTECT_OFF     // Boot Segment Write Protect (Boot Segment may be written)
#pragma config BSS = NO_FLASH           // Boot Segment Program Flash Code Protection (No Boot program Flash segment)
#pragma config RBS = NO_RAM             // Boot Segment RAM Protection (No Boot RAM)
// FSS
#pragma config SWRP = WRPROTECT_OFF     // Secure Segment Program Write Protect (Secure Segment may be written)
#pragma config SSS = NO_FLASH           // Secure Segment Program Flash Code Protection (No Secure Segment)
#pragma config RSS = NO_RAM             // Secure Segment Data RAM Protection (No Secure RAM)
// FGS
#pragma config GWRP = OFF               // General Code Segment Write Protect (User program memory is not write-protected)
#pragma config GSS = OFF                // General Segment Code Protection (User program memory is not code-protected)
// FOSCSEL
#pragma config FNOSC = FRCPLL           // Oscillator Mode (Internal Fast RC (FRC) w/ PLL)
#pragma config IESO = ON                // Two-speed Oscillator Start-Up Enable (Start up with FRC, then switch)
// FOSC
#pragma config POSCMD = NONE            // Primary Oscillator Source (Primary Oscillator Disabled)
#pragma config OSCIOFNC = ON            // OSC2 Pin Function (OSC2 pin has digital I/O function)
#pragma config FCKSM = CSDCMD           // Clock Switching and Monitor (Both Clock Switching and Fail-Safe Clock Monitor are disabled)
// FWDT
#pragma config WDTPOST = PS32768        // Watchdog Timer Postscaler (1:32,768)
#pragma config WDTPRE = PR128           // WDT Prescaler (1:128)
#pragma config WINDIS = OFF             // Watchdog Timer Window (Watchdog Timer in Non-Window mode)
#pragma config FWDTEN = OFF             // Watchdog Timer Enable (Watchdog timer enabled/disabled by user software)
// FPOR
#pragma config FPWRT = PWR128           // POR Timer Value (128ms)
// FICD
#pragma config ICS = PGD1               // Comm Channel Select (Communicate on PGC1/EMUC1 and PGD1/EMUD1)
#pragma config JTAGEN = OFF             // JTAG Port Enable (JTAG is Disabled)
// #pragma config statements should precede project file includes.
// Use project enums instead of #define for ON and OFF.
#include <xc.h>
void Delay1ms()                //@10MHz
        unsigned char i, j;
        i = 10;
        j = 183;
        do
                while (--j);
        } while (--i);
void Delay_ms(unsigned int nms)
    while(nms--)
       Delay1ms();
void SYS_Init()
    TRISB = 0X0000;
    LATB = 0Xffff;
    PORTB = 0Xffff;
    TRISC = 0X0000;
    LATC = 0Xffff;
    PORTC = 0Xffff;
void ADC_Init()
    AD1PCFGH = 0XFFFF;
    AD1PCFGL = 0XFFFF;
    AD2PCFGL = 0XFFFF;
void Time1_Init()
    TMR1 = 15536;
    T1CON = 0X0000;
    T1CONbits.TCKPS = 2;
    _T1IE = 1;
    _TON = 0;
void OSC_Init()        //晶振配置 FCY = 7370000M*41/2/2/2 = 37 771250
        // Configure PLL prescaler, PLL postscaler, PLL divisor
        PLLFBD = 41;    // M = 43
        _PLLPOST=0;         // N2 = 2
        _PLLPRE=0;      // N1 = 2
        // Initiate Clock Switch to Internal FRC with PLL (NOSC = 0b001)
        __builtin_write_OSCCONH(0x01);
        __builtin_write_OSCCONL(0x01);
        // Wait for Clock switch to occur
        while (_COSC!= 0b001);
        // Wait for PLL to lock
        while(_LOCK != 1) {};
void __attribute__((__interrupt__,no_auto_psv)) _T1Interrupt(void)
    _T1IF = 0;
    TMR1 = 15536;
    _LATB0 = !_LATB0;
int main()
    OSC_Init();
    ADC_Init();
    SYS_Init();
    Time1_Init();
    _TON = 1;
        while(1)
        _LATB3 = !_LATB3;
        Delay_ms(500);
        Delay_ms(500);
 楼主| jxwhf2007 发表于 2018-11-19 14:42 | 显示全部楼层
低级问题  硬件存在短路
