| keil中不能通过编译
 出现以下样子:
 * RESTRICTED VERSION WITH 0800H BYTE CODE SIZE LIMIT; USED: 0DF7H BYTE (174%) *
 Program Size: data=21.0 xdata=0 code=3647
 LINK/LOCATE RUN COMPLETE.  1 WARNING(S),  0 ERROR(S)
 *** WARNING L16: UNCALLED SEGMENT, IGNORED FOR OVERLAY PROCESS
 SEGMENT: ?PR?_CLR_LCD?LM4229_0805
 *** FATAL ERROR L250: CODE SIZE LIMIT IN RESTRICTED VERSION EXCEEDED
 MODULE:  D:\KEIL\C51\LIB\C51S.LIB (-----)
 LIMIT:   0800H BYTES
 Target not created
 我认为是程序的代码太长了,不知道在那个地方修改以下设置,请高手指教!
