[STM32F1] TFTLCD无法显示的问题
3309|7
 楼主| cllmxdsdo 发表于 2018-12-30 21:00 | 显示全部楼层 |阅读模式
这个问题已经困扰我好几个星期了,恳请大佬能够抽空助我一臂之力。小弟近来打算用stm32f103VET6,通过FSMC总线去驱动2.8寸TFTLCD. LCD的CS,WR,RS,RD等配置如下图所示(具体原理图请下载文件)
现在的情况是代码烧进去,LCD的背光都无法点亮,整个显示屏一片漆黑。背光的引脚LCD_BL在代码LCD_Init()里面,应该是LCD根本就没有初始化成功吧???还是说FSMC配置错误也会影响到LCD背光的工作???  以下我给出了FSMC配置的部分代码,具体代码请下载文件
        FSMC_NORSRAMInitTypeDef  FSMC_NORSRAMInitStructure;
        FSMC_NORSRAMTimingInitTypeDef  readWriteTiming;
        FSMC_NORSRAMTimingInitTypeDef  writeTiming;
        RCC_AHBPeriphClockCmd(RCC_AHBPeriph_FSMC,ENABLE);        //使能FSMC时钟
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOE|RCC_APB2Periph_GPIOD ,ENABLE);//使能PORTE,PORTD
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1;                                 //PE1 推挽输出 背光
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;                  //推挽输出
        GPIO_Init(GPIOE, &GPIO_InitStructure);
        //PORTD复用推挽输出
        GPIO_InitStructure.GPIO_Pin =                    GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_10|GPIO_Pin_14|GPIO_Pin_15;
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;                  //复用推挽输出
        GPIO_Init(GPIOD, &GPIO_InitStructure);
        //PORTE复用推挽输出
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_10|GPIO_Pin_11|GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14|GPIO_Pin_15;
          //PORTD12复用推挽输出 A16
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_7|GPIO_Pin_11;         //        //PORTD复用推挽输出
        readWriteTiming.FSMC_AddressSetupTime = 0x01;         //地址建立时间(ADDSET)为2个HCLK 1/36M=27ns
        readWriteTiming.FSMC_AddressHoldTime = 0x00;         //地址保持时间(ADDHLD)模式A未用到
        readWriteTiming.FSMC_DataSetupTime = 0x0f;// 数据保存时间为16个HCLK,因为液晶驱动IC的读数据的时候,速度不能太快。
        readWriteTiming.FSMC_BusTurnAroundDuration = 0x00;
        readWriteTiming.FSMC_CLKDivision = 0x00;
        readWriteTiming.FSMC_DataLatency = 0x00;
        readWriteTiming.FSMC_AccessMode = FSMC_AccessMode_A;         //模式A
        writeTiming.FSMC_AddressSetupTime = 0x00;         //地址建立时间(ADDSET)为1个HCLK
        writeTiming.FSMC_AddressHoldTime = 0x00;         //地址保持时间(A
        writeTiming.FSMC_DataSetupTime = 0x03;                 ////数据保存时间为4个HCLK
        writeTiming.FSMC_BusTurnAroundDuration = 0x00;
        writeTiming.FSMC_CLKDivision = 0x00;
        writeTiming.FSMC_DataLatency = 0x00;
        writeTiming.FSMC_AccessMode = FSMC_AccessMode_A;         //模式A
  FSMC_NORSRAMInitStructure.FSMC_Bank = FSMC_Bank1_NORSRAM1;//  这里我们使用NE1 。
  FSMC_NORSRAMInitStructure.FSMC_DataAddressMux = FSMC_DataAddressMux_Disable; // 不复用数据地址
  FSMC_NORSRAMInitStructure.FSMC_MemoryType =FSMC_MemoryType_SRAM;// FSMC_MemoryType_SRAM;  //SRAM
  FSMC_NORSRAMInitStructure.FSMC_MemoryDataWidth = FSMC_MemoryDataWidth_16b;//存储器数据宽度为16bit
  FSMC_NORSRAMInitStructure.FSMC_BurstAccessMode =FSMC_BurstAccessMode_Disable;// FSMC_BurstAccessMode_Disable;
  FSMC_NORSRAMInitStructure.FSMC_WaitSignalPolarity = FSMC_WaitSignalPolarity_Low;
  FSMC_NORSRAMInitStructure.FSMC_AsynchronousWait=FSMC_AsynchronousWait_Disable;
  FSMC_NORSRAMInitStructure.FSMC_WrapMode = FSMC_WrapMode_Disable;
  FSMC_NORSRAMInitStructure.FSMC_WaitSignalActive = FSMC_WaitSignalActive_BeforeWaitState;
  FSMC_NORSRAMInitStructure.FSMC_WriteOperation = FSMC_WriteOperation_Enable;        //  存储器写使能
  FSMC_NORSRAMInitStructure.FSMC_WaitSignal = FSMC_WaitSignal_Disable;
  FSMC_NORSRAMInitStructure.FSMC_ExtendedMode = FSMC_ExtendedMode_Enable; // 读写使用不同的时序
  FSMC_NORSRAMInitStructure.FSMC_WriteBurst = FSMC_WriteBurst_Disable;
  FSMC_NORSRAMInitStructure.FSMC_ReadWriteTimingStruct = &readWriteTiming; //读写时序
  FSMC_NORSRAMInitStructure.FSMC_WriteTimingStruct = &writeTiming;  //写时序
  FSMC_NORSRAMInit(&FSMC_NORSRAMInitStructure);  //初始化FSMC配置
  FSMC_NORSRAMCmd(FSMC_Bank1_NORSRAM1, ENABLE);  // 使能BANK1
我把LCD_BL拿出LCD_Init()函数去重新配置就可以点亮LCD的背光。我现在已经开始怀疑是不是硬件有问题了。。。。
MP3播放器原理图.rar
42.29 KB, 下载次数: 6
基于是stm32的MP3播放器code1.rar
333.76 KB, 下载次数: 2
mmuuss586 发表于 2018-12-31 22:23 | 显示全部楼层
感谢楼主分享
740071911 发表于 2018-12-31 22:48 | 显示全部楼层
FSMC肯定的告诉你,FSMC不会影响背光灯,直接把TFT背光引脚连个2~3欧电阻直接接到3.3v上面,可以得到验证
stm32xiaobai 发表于 2019-1-2 13:20 | 显示全部楼层
你背光引脚没接对哦,背光就只是相当于点灯作用,程序不会影响的哈,设置为上拉输出,然后程序里引脚置高就可以了
 楼主| cllmxdsdo 发表于 2019-1-4 10:33 | 显示全部楼层
已解决,卡死在LCD初始化函数里了,printf函数注释掉就好了
wakayi 发表于 2019-1-4 12:51 | 显示全部楼层
fsms的程序看着没有问题
xiaoqizi 发表于 2019-1-4 12:59 | 显示全部楼层
貌似是代码问题哦
木木guainv 发表于 2019-1-4 13:02 | 显示全部楼层
恭喜楼主解决问题了 我也长知识了
