- %% Animation demo for Lissajous curve
- close all;clear;clc;
- % Create a new figure window,
- % Background color is white
- % MenuBar is hidden
- % Image size is 480*480
- figure('Color','w','MenuBar','none','InnerPosition',[0 0 480 480]);
- co = [65/255, 131/255, 196/255]; % specify the color
- % Create animated line object
- headMarker = animatedline('LineStyle','none','Marker','o','Color',co,'MarkerFaceColor',co);
- body = animatedline('LineStyle','-','LineWidth',1.3,'Color',co); % trajectory
- axis([-1,1,-1,1]); axis off; % hide axis
- % Parameters
- a = 13;
- b = 18;
- phi = pi * 0;
- % Parametric Equation of Lissajous Curve
- t = linspace(0,2*pi,1000); % generate 1000 linearly equally spaced points
- x = sin(a*t);
- y = sin(b*t+ phi);
- % Display
- for idx = 1:length(t)
- addpoints(headMarker,x(idx),y(idx));
- addpoints(body,x(idx),y(idx));
- drawnow
- % Capture the current plot
- frame = getframe; % snapshot of the current axes
- im{idx} = frame2im(frame); % write image data to `im`
- % Remove previous head marker except for the last one
- if idx~=length(t)
- clearpoints(headMarker);
- end
- end
- % figure;
- % for idx = 1:9
- % subplot(3,3,idx)
- % imshow(im{idx});
- % end
- % Save images into a GIF file.
- % Because three-dimensional data is not supported for GIF files,
- % call rgb2ind to convert the RGB data in the image to an indexed image A with a colormap map.
- filename = 'Lissajous.gif'; % specify the output file name
- [A,map] = rgb2ind(im{idx},256);
- if idx == 1
- % Set DelayTime = 0 to display next images as fast as your hardware allows
- imwrite(A,map,filename,'gif','LoopCount',Inf,'DelayTime',0);
- else
- % To append multiple images to the first image
- imwrite(A,map,filename,'gif','WriteMode','append','DelayTime',0);
- end
- end
